370steve goes EFeeeeeeeeeeeee - Page 17 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > 370steve goes EFeeeeeeeeeeeee
Old Streetfighter Motorcycle Forum Post 05-06-2020, 07:25 AM   #161
370steve
old fart
Local Time: 08:07 AM
Flip Offs: 30
Default Re: 370steve goes EFeeeeeeeeeeeee
not much done over the last couple of days, ordered some more bits and bobs, still waiting on bits back from*
coating, Brian said he had finished head and cam cover yesterday and will be getting packed up today.
need oil cooler brackets back from Taff, so i can sort mounting of fan (arrived yesterday) and then frame needs to go back down to Mick (Redsix) for
welding fan mounts, some small plates, pillion foot peg mountings and lock stops, still waiting on battery box, top has been machined, just needs other half doing.
awaiting word from Martek on Swing arm.
getting there slowly.
Onwards.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-06-2020, 11:23 AM   #162
370steve
old fart
Flip Offs: 30
managed to find a pucker Ohlins pre load adjuster bracket when i was browsing the web, came this afternoon,changed *out the bracket i made out of a fork clamp.
I know some will say "why"
but i wanted one*for the build, if i could find one. now sorted
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-07-2020, 07:23 AM   #163
370steve
old fart
Flip Offs: 30
Its the little bits that count, so i have been told, well in line with that thinking i had some more Ti goodness turned
up in the post today
thought has entered my head into getting a Ti shock spring, can get one made for a reasonable price, but was wandering if anyone had any links
or contacts for one to fit 57 x 160 x 130Nm?
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-07-2020, 03:36 PM   #164
370steve
old fart
Flip Offs: 30
got the h/lamp done, M blaze pins mounted with alloy spacers, wire exiting through the rear, will drill some small holes through the webs on the rear of the lamp and feed the wire
through to where the harness plugs in.
sorted the Ducati radiator mounts onto the oil cooler brackets,**will look at mounting the oil cooler tomorrow, going to use some rivnuts into the frame down tubes.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-07-2020, 04:06 PM   #165
370steve
old fart
Flip Offs: 30
Pics through from Brian at Centurion, head and cam cover sorted
clean and vapor blasted.
then after coating, great job again
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-08-2020, 11:09 AM   #166
370steve
old fart
Flip Offs: 30
very productive day so far, got oil cooler mounted to frame.
then took frame out into the sun for some hot grinder action,
cut the web*away from the lower steering stem plating to give the required clearance
for the cooling fan, almost happy with its fitment, but might try to get it a little higher so it will sit almost central to the cooler.
once happy i will make a plate and get the bottom of the web welded up. and some tabs welded on to mount the fan.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-09-2020, 11:38 AM   #167
370steve
old fart
Flip Offs: 30
after sitting and thinking about the oil cooler/fan layout, and getting pictures of Blubbers EFE frame mod, i have changed the design,
it removes some of the webs from under the steering head, replaces it with a cross brace and allows the fan to sit higher on the cooler.
has the added advantage of allowing better air flow through the cooler matrix with the webs not blocking air flow.
so out with the grinder again.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-10-2020, 04:28 PM   #168
370steve
old fart
Flip Offs: 30
did some more cutting and grinding today, made some lock stop plates to weld to the lower head stock, small plate to patch a hole,
pillion peg mounting plates and finish off with making some brackets for the oil cooler fan to get welded.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-12-2020, 03:12 PM   #169
370steve
old fart
Flip Offs: 30
Quick trip down to Redsix for some thermal joining howkus powkus by Mick.
sorted the fitment of oil cooler fan, pillion pegs, lock stops, small plate and lower mid engine mount insert.
once i have the battery box sorted, i can plan the fitment of the electronics tray, which should be the end of the cutting/welding of the frame.
had a bit of a play with the rear shock, have ordered a next weight down spring, 130 down from the 140 i have now, got a 120 if i need to go further.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 05-13-2020, 03:01 PM   #170
370steve
old fart
Flip Offs: 30
finished off grinding off unwanted tabs, ruff bits and weld splats, and smoothing any bits i dont like.
sorted the lock stops, need a little bit more "adjustment" but almost there, then just need some stop bodies making.
SHIT HAPPENS!!!!!
Thank you for viewing 370steve goes EFeeeeeeeeeeeee in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - 370steve goes EFeeeeeeeeeeeee on Custom Fighters Streetfighter Motorcycle Forum
