Italianeze build off thread - Page 12 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Italianeze build off thread
Old Streetfighter Motorcycle Forum Post 04-10-2020, 06:07 PM   #111
yantosh
Local Time: 07:41 PM
Flip Offs: 14
time to look at headlight set up
i,ll be using two of these
just for comparison i dug out the CB13 one
kind of ok from the front
but from the side its just too small, or possibly mounted too high, look again tomorrow
hung the new one
better but perhaps too huge? and makes muddie too skinny
side position better
thinking somewhere between the two, recessed centre section with lights in
Old Streetfighter Motorcycle Forum Post 04-11-2020, 11:27 AM   #112
yantosh
Flip Offs: 14
bit more messing with the number board, holes cut for lights
sits as i want with muddie
and i like it from the side
need to come up with nice mounts
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 04-11-2020, 02:58 PM   #113
yantosh
Flip Offs: 14
hoping this can will look right with this bike, I really want to use it
Old Streetfighter Motorcycle Forum Post 04-11-2020, 06:30 PM   #114
yantosh
Flip Offs: 14
set of genuine 20 levers just ordered , be here in a coupla weeks ... possibly, not sure how post from HK is just now
Old Streetfighter Motorcycle Forum Post 04-12-2020, 05:27 PM   #115
yantosh
Flip Offs: 14
steering damper has no spherical bearing, found this one after a bit of hunting, 8mm instead of 6, but I can deal with that
fucked about with angles on number board, bouncing ideas off of a couple of trusted friends
lines flow better like this
started sizing up for other things that need doing, but that was about an end to it as Mrs Yan requested my presence for the burning
did start card mock ups of headlight mounts , back on it tomorrow
Old Streetfighter Motorcycle Forum Post 04-13-2020, 03:24 PM   #116
yantosh
Flip Offs: 14
rough CAD headlight mount, loomynum next
Old Streetfighter Motorcycle Forum Post 04-14-2020, 04:15 PM   #117
yantosh
Flip Offs: 14
replaced the card with loomynum, not the prettiest ,but that can be dealt with
mounted the muddy on a bracket , i bent it a bit more after this photo, think it was too high, will see better if i can get it back out shed at weekend
once i,m happy with the angle of the lights I will refine the holes
started a damper mount, but its too far back, hits the key
vapor speedo unlikely to fit now, reckon it might be a motogadget mini job
all engine spacers in too
Old Streetfighter Motorcycle Forum Post 04-16-2020, 04:29 PM   #118
yantosh
Flip Offs: 14
made an other damper mount , went ahead and pressed in the bearing
it,ll fit here abouts
and the damper pops on here
more on that hopefully tomorrow
been pondering for a while how to mount the pegs, didnt want tabs and race rearsets
had a nose at how Ducati did it
came up with this
took a chance on my idea working and didnt mock up
I like it, just need a post to tie it onto to stop it rotating around the spindle
now need the opposite side
Old Streetfighter Motorcycle Forum Post 04-17-2020, 05:03 PM   #119
yantosh
Flip Offs: 14
swapped out the spindle for some threaded bar for now, let me tie the pegs on
in your best jedi voice these are not the spindle nuts you,re looking for
both are on, just need them at the same position and locking bosses welded
damper is on and I have full steering lock , post needs fully welded still
swingarm adjuster blocks finally finished
the reducing sleeve is about 1mm too long, i deal with that later
making progress
Old Streetfighter Motorcycle Forum Post 04-18-2020, 05:06 PM   #120
yantosh
Flip Offs: 14
foot rest plates are locked in place
made a couple of crappy top mounts for the number board, they will be replaced , but once I make the crappy bottom mount it,ll be plenty secure and I can replace them one at a time for nice ones
bottom light is a bit off to one side but it has spacers, so it can be shuffled
body filler ordered from Amazon to finish the front muddie , then I can take a mould from it
Thank you for viewing Italianeze build off thread in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - Italianeze build off thread on Custom Fighters Streetfighter Motorcycle Forum
