Italianeze build off thread - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Italianeze build off thread
Old Streetfighter Motorcycle Forum Post 11-25-2019, 07:53 AM   #21
yantosh
Local Time: 01:47 PM
Flip Offs: 14
rear tank support, yes I could have made it, but would still have had to buy pads, work out heights etc, so worth the 18
Old Streetfighter Motorcycle Forum Post 11-30-2019, 10:22 AM   #22
yantosh
Flip Offs: 14
made a start to the top yoke , again, it still needs finishing
Old Streetfighter Motorcycle Forum Post 11-30-2019, 03:08 PM   #23
yantosh
Flip Offs: 14
no photos yet of the butchery that ensued to get that engine in there
once i get the engine more secure i,ll look a swingarm pivot
Old Streetfighter Motorcycle Forum Post 12-01-2019, 07:49 AM   #24
yantosh
Flip Offs: 14
possibly to be re-purposed Ducati frame tube
sharp raggies removed , half finished risers fitted to top yoke, just need the M14 cap screws and i can get them finished finished
lock stops will wait till its on the ground, the underside of the top yoke may be thinned down, if needed later in the game
clamp holes and slots next
Old Streetfighter Motorcycle Forum Post 12-01-2019, 12:14 PM   #25
yantosh
Flip Offs: 14
i had an old TL frame in the loft, insurance right off, can,t be used
lets chop the pivot end off
offered it up , on the off chance it would look ok..... yes i could make it work, but it isn,t what i want
what it does do is give a pivot point to suit the engine
I had the top rear mounts drawn up, forgetting its a twin and the exhaust hangs out back, I,ll nip into shop and collect the bit of rear pipe i have for a check
turns out its an R motor I have , not an S as i thought, that,ll explain the R throttle bodies , the give away is the blanked off oil cooler feeds and water feeds at the oil filter
Old Streetfighter Motorcycle Forum Post 12-01-2019, 02:29 PM   #26
yantosh
Flip Offs: 14
leaving some notes here for my own convenience
front engine mounts - steel , 35 long, 28 OD, 10.5 ID
aluminium 5 long, 28 OD, 10.5 ID
mid engine mount spacers - aluminium 32 OD, 12.5 ID , one off 42 long, one off 14 long
top rear bar - 28 OD, M12 tapped in either end, 205.85 long
skim 3mm from bottom of jig posts
need 28 x 2 tube and 22 x 2 tube
rear lower mount spacers - aluminium , 25 OD, 11 ID, 5mm thick
lower rear mounts with 5mm clearance from 28mm tube
Old Streetfighter Motorcycle Forum Post 12-02-2019, 04:38 PM   #27
yantosh
Flip Offs: 14
trying to find out if this is an R or an S ecu
update mid post ... its an S .... pish
Old Streetfighter Motorcycle Forum Post 12-02-2019, 04:46 PM   #28
yantosh
Flip Offs: 14
the rear pipe and the cross tube I,m fitting are going interfere with each other, but I have a plan ...kinda
Old Streetfighter Motorcycle Forum Post 12-02-2019, 05:31 PM   #29
yantosh
Flip Offs: 14
R ecu paid for, part exchange with my S unit, guy going to message once loom is out of bike
another 40 spent
Old Streetfighter Motorcycle Forum Post 12-03-2019, 05:28 PM   #30
yantosh
Flip Offs: 14
from the free pile, Aprilia falco swingarm spindle, figure it was made for an Italian V twin
first bundle of frame conversion bits n bobs
proper bolts ordered to tie this on here, then it can be attached to frame
thats another 12
Thank you for viewing Italianeze build off thread in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - Italianeze build off thread on Custom Fighters Streetfighter Motorcycle Forum
