Italianeze build off thread - Page 6 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Italianeze build off thread
Old Streetfighter Motorcycle Forum Post 01-01-2020, 12:48 PM   #51
yantosh
Local Time: 01:20 PM
Flip Offs: 14
must be something I can be doing...
hunt out some stuff ,make sure I actually have it
master cylinders, ZX10r ..... check
galfer wavy discs ..... check
GSXR 1000 ignition barrel , gotta be able to make it fit TL loom surely, ?
it,ll live here
found this cool rear caliper in my box of brakes, dunno what its off, but I know where its going
thought i might as well pull the loom out the bag , see whats what
oh look ... scotchlocks
and a shitty alarm
won,t be needing all this shit
even tagged a bit
i,ll need to go grab the wiring diagram, start tagging the rest
fuckin hate wires
hardly progress, but its a bit
Old Streetfighter Motorcycle Forum Post 01-02-2020, 02:10 PM   #52
yantosh
Flip Offs: 14
there appears to be a lack of visibility around here
but i got a mock up wheel now
and can confirm the original suspension mount won,t work
so chop chop
Old Streetfighter Motorcycle Forum Post 01-02-2020, 07:20 PM   #53
yantosh
Flip Offs: 14
sittin on the floor, wiring diagram,masking tape and rum
so far i missing a MAP sensor, fuse box, reg/rec, tip over sensor .... messaged the guy i been getting stuff from, offered him a deal with some gsxr 1000 bits .... see what he says
found a cheap TL ignition barrel on ebay, easier than trying to graft the 4 wire gsxr one into a 6 wire plug
Old Streetfighter Motorcycle Forum Post 01-04-2020, 12:11 PM   #54
yantosh
Flip Offs: 14
draw up some top shock mounts
start machining them
yeah, I do everything wit computers and CNC machines
this tube will have to be re-positioned, not dropping the motor to possibly be able to squeeze the thermostat housing in
time for mince n tatties, back to this later
Old Streetfighter Motorcycle Forum Post 01-04-2020, 05:07 PM   #55
yantosh
Flip Offs: 14
thermostat housing fits, i,ll fit a new cross tube at a slightly dif angle
shock mounts are all shaped and welded to a new tube, the tube is tacked in place,
the new tube will be braced to the one behind it too.
built back up, takes less space,
TL rad being posted next week, see how close it is to fitting inside the panels
Old Streetfighter Motorcycle Forum Post 01-08-2020, 05:32 PM   #56
yantosh
Flip Offs: 14
most I,ve managed on this this week, couple of frame plugs
I,m about out of argon and need to get some stuff done on the gsx for my mate... more progress soon I hope
Old Streetfighter Motorcycle Forum Post 01-09-2020, 04:59 PM   #57
yantosh
Flip Offs: 14
got the first plug in, no gas to weld tho
picked up an ignition barrel with 6 wires , found a drive sprocket for at least set up dooties
standard TL switchgear, plug n play ,
roughly hung, id much rather run without fans... but dunno how that,d go
with the fans the panels will need cut , no room to mount one centrally
this a moulding of the front hugger, the start of a one off split headlight unit
be shaped more like this
away to research no fans and thin fans
Old Streetfighter Motorcycle Forum Post 01-10-2020, 05:43 PM   #58
yantosh
Flip Offs: 14
another day, another bite of the elephant
re-purposed one of the cut out cross braces to make a mounting bar for the rad
It,ll be welded on here abouts, but think it will wait until the bike is off the bench and I can get about it
looking at the idea of widening the bodywork about an inch per side, let it sit better with rad
pair of mounting bosses for the ignition barrel
once the top tank cover is finalised tube will connect them in a similar manner to the Hyper
got the detail work onto the bottom yoke, Suzuki in a Ducati frame
Old Streetfighter Motorcycle Forum Post 01-11-2020, 10:33 AM   #59
yantosh
Flip Offs: 14
my old mill was pressed into service today, bottom yoke has all its clamp holes drilled and tapped
Old Streetfighter Motorcycle Forum Post 01-15-2020, 03:40 PM   #60
yantosh
Flip Offs: 14
it fits, thought i,d made a cunt of it,but the forks had sat squinty
headed slightly north from Italy,up to Austria
tail piece will need a bit of fitting n chopping
scuse the mess, bit short on space
Thank you for viewing Italianeze build off thread in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - Italianeze build off thread on Custom Fighters Streetfighter Motorcycle Forum
