Chat with an ASE Master Technician - Page 27 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Off Topic > Open Discussion
Open Discussion Anything non-motorcycle related goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Chat with an ASE Master Technician
Old Streetfighter Motorcycle Forum Post 08-21-2018, 11:33 AM   #261
Casper
The friendly Ghost.
Local Time: 10:35 PM
Flip Offs: 188
Default Re: Chat with an ASE Master Technician
Link to a problem that I am having.
https://www.customfighters.com/forum...0&postcount=24
Casper is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-21-2018, 02:37 PM   #262
XxGRYMMxX
Breaking shit...
Local Time: 01:35 AM
Flip Offs: 8
just responded, Ill hit yopu up a little later when I have a few min.
Old Streetfighter Motorcycle Forum Post 11-05-2018, 11:36 AM   #263
Mongoose
https://youtu.be/OY8F6w1N_kw
Dunno if you can actually hear anything.. Its a weird sound.. Not sure what goes bad on these 4.6's.. I know it has a header leak, small.. But this is something else.. Low load, 1000 rpm tick.. Doesnt really sound like a rod either.. 110k miles.. On an 09 f150
Hell could it be the trans? Its almost a crunchy tick.. If you know what i mean
Old Streetfighter Motorcycle Forum Post 11-05-2018, 01:45 PM   #264
Casper
The friendly Ghost.
Flip Offs: 188
The sound reflecting off the walls has phaser written all over it, they are just noisy.
There is play in the cams with the Ford modular engines due to the phasers and the tensioners.
Clean oil and filter?
Old Streetfighter Motorcycle Forum Post 11-05-2018, 03:27 PM   #265
XxGRYMMxX
Breaking shit...
Flip Offs: 8
vid sounds more of a clatter than knocking. Casper is right about the cam phasers (he would know about those now!), they def will make noise when low on oil or if oil pressure gets low. Check your oil and change it if its been a while and see if the noise is still there. if it is, an oil pressure test with a gauge is next on your list of stuff to do.
Old Streetfighter Motorcycle Forum Post 11-05-2018, 06:32 PM   #266
Mongoose
Oil is good.. Has been a while since ive changed it tho ill have to try that... Yeah its a weird noise never really heard it before..
I looked at a lock out kit... And fuck me 800 bucks
Old Streetfighter Motorcycle Forum Post 11-08-2018, 12:27 PM   #267
Mongoose
Got a bit worse..
https://youtu.be/uEfHWui-yas
Old Streetfighter Motorcycle Forum Post 11-08-2018, 03:17 PM   #268
XxGRYMMxX
Breaking shit...
Flip Offs: 8
I would check that oil pressure ASAP. if its low there's a good chance is leaking from the timing chain tensioners and allowing the chain to go slack. Same thing happened to Caspers truck and it didnt take long to go from a little noise to an engine rebuild.
Old Streetfighter Motorcycle Forum Post 11-08-2018, 04:08 PM   #269
Mongoose
Yeah i think im driving it home and parking it. Its never had a timing set in it, or oil pump anything...
I started it up again after it cooled off and was fine.. So id deffo say hot oil/pressure issue.. Something getting sucked up the coil slot of an oil pick up also crossed my mind.. Is it a mos to cut it out to a normal size?
1000 miles into the ownership, couple grand on the table.
Old Streetfighter Motorcycle Forum Post 11-08-2018, 08:18 PM   #270
Mongoose
Wheres a good/ez place to get oil pressure from?
Didnt do it all on the way home which is weird need to scope the pan.
Thank you for viewing Chat with an ASE Master Technician in the Open Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
Open Discussion - Chat with an ASE Master Technician on Custom Fighters Streetfighter Motorcycle Forum
