antigravity battery swelling - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Electrical and Lights
Electrical and Lights Anything related to the fabrication of lights and other electrical components goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > antigravity battery swelling
Old Streetfighter Motorcycle Forum Post 07-15-2019, 12:37 PM   #1
rabies
time is running out......
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:01 AM
Flip Offs: 1,393
Flipped Off 39 Times in 35 Posts
rabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to beholdrabies is a splendid one to behold
Default antigravity battery swelling
4 cell. worked fine. fit in a metal "oil" container. was not air tight.
it swelled. not even a month of use.
normal? not vented enough?
was $100 from lowbrocustoms
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-15-2019, 12:47 PM   #2
a_morti
Local Time: 06:01 PM
Flipped Off 24 Times in 14 Posts
a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!
Default Re: antigravity battery swelling
That's not looking happy! They can catch fire so not sure if you even could return for inspection.
Check the charging voltage, maybe your bike is voer charging? Is the regulator somewhere without adequate cooling?
Aaron, living in Gibraltar and riding a 2014 MSX125 (Grom) with a bunch of shiny shite on it. Slow n loud!
a_morti is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-15-2019, 01:19 PM   #3
rabies
Flip Offs: 1,393
mounted right on the side of the box. plenty of air.
its not the same reg that's on my 78 kz650.
this reg has 3 yellow wires. 1 black wire. 1 red wire. and a brown wire that is snipped.
my 78 kz650 has 2 yellow wires and 1 yellowblack
this is a 79 kz650
Old Streetfighter Motorcycle Forum Post 07-15-2019, 01:57 PM   #4
Local Time: 09:01 AM
check the voltage with the bike running, overcharging them can do that
Old Streetfighter Motorcycle Forum Post 07-15-2019, 02:06 PM   #5
rabies
Flip Offs: 1,393
dang..
I found this
https://ricksmotorsportelectrics.com...fierregulator/
Old Streetfighter Motorcycle Forum Post 07-15-2019, 02:58 PM   #6
Local Time: 07:01 PM
Flipped Off 40 Times in 39 Posts
One of lithium cells is dead or going to die
Old Streetfighter Motorcycle Forum Post 07-15-2019, 03:11 PM   #7
rabies
Flip Offs: 1,393
says it has warranty
Old Streetfighter Motorcycle Forum Post 08-13-2019, 11:12 AM   #8
Local Time: 12:01 PM
just a heads up, lion batteries like that can decided to give way at any time, and create a lot of fire that does not go out easily.
These people High Fived tldave!
Old Streetfighter Motorcycle Forum Post 08-14-2019, 09:29 PM   #9
Yeah. Rabies, get that battery out of your shop if you haven't already.
Old Streetfighter Motorcycle Forum Post 08-14-2019, 10:10 PM   #10
Zweihammer
Misfit
Zweihammer's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!Zweihammer is an amazingly helpful member with a good attitude!
Had two of those exact batteries fail spectacularly. One was on a charger in my shop, came out to find a hole burned through the case. I was lucky nothing flammable was near by as I had pulled it from the bike to charge it. The second one was me being a dumb ass, I put it in my riding mower when it’s battery was dead and I was impatient to get the lawn mowed. I ran it for half an hour and when I lifted the seat to swap it back out it was very swollen, hot, and starting to smoke. Overcharged, I imagine from the crude system in the mower. I cut the wires and tossed it in a steel bucket in the driveway, it was still hot to the touch an hour later.
I guess I am not sophisticated enough for the fancy stuff.
2019 Winter Build Off Bike
2019 Winter Build Off Chit Chat
Bones heal, chicks dig scars, pain is temporary, glory is forever. E. Knievel
Zweihammer is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Zweihammer!
Thank you for viewing antigravity battery swelling in the Electrical and Lights section of our streetfighter motorcycle forum. I hope you found it useful!
Electrical and Lights - antigravity battery swelling on Custom Fighters Streetfighter Motorcycle Forum
