Member Project Bikes Project progress threads of members streetfighters. |
Thread Tools |
#11 | |
![]() Quote:
MSVA is really no more than a big MoT, if its too big a hassle then what else will you compromise on ? Just seems daunting at the start http://www.facebook.com/BluntforcetraumaInc 2018 build off thread - http://www.customfighters.com/forums...94#post3051994 2018build off talky talky - http://www.customfighters.com/forums...70#post3052070 |
Advertisement | |
These advertisements only appear for guests, register now for free to remove these ads! |
Sponsored Links | |||
#12 |
stem will be spot on, bearings take all the strain
This user High Fived yantosh! |
#13 |
Dickhead
Senior Fighterer
Local Time: 06:14 PM
Flip Offs: 10
I was hoping you'd say that
![]() ![]() Striving to remain dynamic in an ever-evolving environment and shit like that.
#14 |
![]() CF Addict ![]()
Local Time: 07:14 PM
Flip Offs: 24
@Yan fair play, I've no idea how hard it is or isn't. Worst I've had to register was a modded cb-1 in Gibraltar, he barely looked at it long enough to check the brakes work. The bhp and wet weight figures for the logbook were taken from Wikipedia.
@Raz there's a few 400/600 on there, one guy fitted a 918 in there too. It's the kind of site worth putting WTB ad, people have sheds full of spares for bikes they don't race anymore. Aaron, living in Gibraltar and riding a 2014 MSX125 (Grom) with a bunch of shiny shite on it. Slow n loud! ![]() |
This user High Fived a_morti! |
#15 |
Dickhead
Senior Fighterer
Flip Offs: 10
Got swingarm & wheel now. FZR1000 EXUP:
![]() ![]() It looks just like the 3TJ arm but the caliper has a torque arm on this swinger whereas 3TJ has caliper bolted to a bracket. Also the pivot point is about an inch wider! So I'll hack it up and figure out how to make it work. I'll use the 3TJ shock and link for simplicity for now and maybe make up some dogbones to get the right height. Subframe has been better days. Needs to be repaired, blasted and coated really. I don't want to change it too much coz I need the pillion seat to fit & work. Will probably be cutting and welding little bits so I can have a nicer tail light. Also, the tail plastics are in 3 pieces on these but I'd like to stick them all together for a one-pieceness: ![]() Thundercat carbs: ![]() No idea on condition - the covers have been drilled off the mixture screws so they've been played with by someone. I've got no interest running the heating circuit so that will go. I've no clue what stock cat jetting is and no clue where I'll need to go with it because I don't know if I can run an airbox yet. A 3TJ airbox won't fit with the 600 lump. But I do have the cat airbox. Anyone know if this spigot is for the gearbox breather?: ![]() Also, what is this inside the front sprocket cover? The rubber bit that I've taken the metal plate off. Just a noise damper? ![]() If so, surely it has no place on a fighter? ![]() Striving to remain dynamic in an ever-evolving environment and shit like that.
#16 |
those exup arms are a great looking shape
#17 |
Dickhead
Senior Fighterer
Flip Offs: 10
I think that too. Clean, simple & beefy. ...just how I like my women.
This user High Fived RS_Raz! |
#18 |
Flip Offs: 24
If you found sound deadening in your airbox you'd remove it, you might decat your exhaust, but who wants a louder front sprocket?
#19 | |
Dickhead
Senior Fighterer
Flip Offs: 10
![]() Quote:
......... ![]() Striving to remain dynamic in an ever-evolving environment and shit like that.
#20 |
Dickhead
Senior Fighterer
Flip Offs: 10
Got the R6 5EB front end. 11 disc bolts came out, one rounded out so welded a nut on it:
![]() ![]() ![]() The forks look usable but looks like someone has been having trouble with the clickers: ![]() Yeah they're stuck. I've run out of Rost Off Ice too. They might have to stay like that for now. Risers came in: ![]() I tapped the threads a bit deeper and replaced the suspect looking bolts that came with them. Just need to have some spacers made up so I can bolt them together. Also got 5EB stock exhaust: ![]() Will need some work to fit but not too much. ![]() ![]() Striving to remain dynamic in an ever-evolving environment and shit like that.
These people High Fived RS_Raz! |
Bookmarks |
Thread Tools | |
