FZR 600 RR Build - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > FZR 600 RR Build
Old Streetfighter Motorcycle Forum Post 06-24-2019, 04:56 PM   #21
RS_Raz
Chief Bodger
Senior Fighterer
Local Time: 05:56 AM
Flip Offs: 9
Default Re: FZR 600 RR Build
Valves cleaned & lapped. Had to replace one intake valve. New seals & gaskets:
Valve clearances are all within spec. Everything is torqued up to book spec.
These people High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 06-25-2019, 11:39 AM   #22
Dman1320
Here to F stuff up
Fighter
Dman1320's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:56 PM
Flip Offs: 1
Dman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud ofDman1320 has much to be proud of
Originally Posted by Junkie View Post
660 is YZF jugs/pistons with FZR crank. Using FZR rods means deck height is correct without a spacer IIRC, but you need to enlarge the small end a bit. You can use either set of cases IIRC. YZF rods can be made to work but then you need to run a spacer under the jug.
and that's pretty much the exact front end I'd run, it's been a long time since I looked at swingarms so I'm not sure there.
As for the 660, the two most common way I saw of doing it that keep you from needing a 3mm base gasket was either to bore the fzr rods small end to fit the wrist pin for the YZF pistons, supposedly 1mm.
The other way was to get Fazer 600 rods, or FZH if I remember correctly, which were supposedly the right length and wrist pin bore without needing any machining. Never did come across a successful case of that being done though since that was a europe only bike, could be worth looking at if you ever go down that road.
Dman1320 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Dman1320!
Old Streetfighter Motorcycle Forum Post 06-25-2019, 05:24 PM   #23
RS_Raz
Chief Bodger
Senior Fighterer
Flip Offs: 9
Thank you for that. I will keep it in mind & keep a look out for these bits
Old Streetfighter Motorcycle Forum Post 06-26-2019, 04:58 PM   #24
RS_Raz
Chief Bodger
Senior Fighterer
Flip Offs: 9
Got Thundercat clocks:
Cable-driven speedo got the chop:
FZR1k pivot narrowed:
Cat air box doesn't fit the frame:
Apparently there isn't enough room above the 600 engine for the 3TJ box and it doesn't fit the carbs anyways... so pods or custom I guess. I suppose this was always gonna need custom jetting.
Got silver spot calipers:
They're in good shape but.......:
They're missing the anti-rattle pads springs
I can't find any and Yamaha wants stupid money. Any idea on aftermarket ones???
This user High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 06-26-2019, 05:29 PM   #25
Junkie
re-tarded
Local Time: 09:56 PM
Flip Offs: 3
Junkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to all
I don't run them on mine and don't notice any rattles
Bikes: naked SV1000 with all the possible bling, WR450SM street legal, 450XCF SM trackbike
Old Streetfighter Motorcycle Forum Post 06-27-2019, 02:53 PM   #26
XxGRYMMxX
Breaking shit...
Local Time: 12:56 AM
Flip Offs: 8
on most of the cars I work on, they come with a new set of pads (at least the decent ones). Maybe check to see if a new set has them included?
Old Streetfighter Motorcycle Forum Post 06-27-2019, 03:02 PM   #27
RS_Raz
Chief Bodger
Senior Fighterer
Flip Offs: 9
Why not? Coz you don't have them either? I'll run without until I find some then
Good point. I will investigate that when I'm pad shopping.
Pressed in some riser spacer bits I had made up by UltraTurn:
(bars may vary)
Lookin pretty good I think. Then I suddenly thought Oh Shit! What if the forks don't fit?
Shishkebabs it's close.
Oh Shit! Will there be enough room for the stem nut???? Maybe.
Old Streetfighter Motorcycle Forum Post 06-27-2019, 05:50 PM   #28
Junkie
re-tarded
Flip Offs: 3
they were being a PITA to get back in so I tried it without them and didn't see any downsides
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 06-29-2019, 04:48 PM   #29
RS_Raz
Chief Bodger
Senior Fighterer
Flip Offs: 9
Chopped and stretched the R6 exhaust:
Got the rear light I wanted:
I'm hoping it will look a bit better than the 3TJ one which looks like this:
I'm not into it.
Old Streetfighter Motorcycle Forum Post 06-29-2019, 04:54 PM   #30
yantosh
Flip Offs: 13
weld a new balance pipe in with down pipes clamped in head ?
Thank you for viewing FZR 600 RR Build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - FZR 600 RR Build on Custom Fighters Streetfighter Motorcycle Forum
