FZR 600 RR Build - Page 5 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > FZR 600 RR Build
Old Streetfighter Motorcycle Forum Post 07-16-2019, 04:54 AM   #41
RS_Raz
Dickhead
Senior Fighterer
Local Time: 08:20 PM
Flip Offs: 10
Default Re: FZR 600 RR Build
Originally Posted by a_morti View Post
My various cb-1s had a 1 piece tail stock. You had to flex it just a little to get it over the frame and regulator. Over time they always cracked in the corner where you have to flex them a bit. Never had that on a CBR900 with 3 piece tail.
Don't worry. I trimmed the subframe so the tail slides on without flexing. I imagine it might crack over time anyway but the rear piece was a mess (all mounting points cracked or missing), one side was cracked and the other had the locating tabs missing.
This user High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 07-16-2019, 04:53 PM   #42
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
These carbs are looking really good actually:
Needles 1 & 4 are different to 2 & 3. I'm guessing that's coz the ram air affects the outer cylinders differently as the non-ram air Foxeye and FZS use the same needles across all cylinders. That's my theory anyway. So as I'm not running ram air, I plan to use the same needle for each cylinder. Good idea?
Old Streetfighter Motorcycle Forum Post 07-17-2019, 05:29 PM   #43
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
Thought I was being clever when I bough an R1 rear master coz it looked the same as the 3TJ one but then I noticed how much longer the threaded bit on the plunger is:
So I swapped em:
These people High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 07-17-2019, 06:17 PM   #44
a_morti
Local Time: 09:20 PM
Flip Offs: 24
Plenty of il4 bikes have different jetting to run the middle two cylinders richer to keep them cool. Vfr400s ran the rear bank richer for same reason.
Ones 14mm, other 1/2" (12mm maybe), if I read it right?
May not matter but if you find the rear brake pedal travels too far or is squishy , that'll be why.
a_morti is online now   Reply With Quote on our streetfighter motorcycle forum
This user High Fived a_morti!
Old Streetfighter Motorcycle Forum Post 07-17-2019, 06:27 PM   #45
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
That's it, the R1 is 1/2" and 3TJ is 14mm. The plan is to use the R1 rear caliper which I have but I need to make a carrier for it as the disc I'm using is bigger than the R1. For now this setup will hopefully be OK.
Old Streetfighter Motorcycle Forum Post 07-17-2019, 06:45 PM   #46
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
So you reckon keep the needles as they are for now? The mains and pilots are the same for all cylinders and I was looking to sort of replicate the jetting of the non ram air bikes using basically the same engine but I totally take your point and am not looking to cook the engine.
Old Streetfighter Motorcycle Forum Post 07-18-2019, 02:16 AM   #47
a_morti
Flip Offs: 24
Not sure on that specific model, just saying he reason for the mismatch may not be ramair.
Old Streetfighter Motorcycle Forum Post 07-19-2019, 01:49 PM   #48
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
Got it. I'll rebuild the carbs all stock and go from there. If I can mod the airbox to fit then hopefully the jetting won't be too far off coz the only engine mod is the exhaust.
Old Streetfighter Motorcycle Forum Post 07-20-2019, 10:55 AM   #49
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
Got a minty Thundercat horn:
And I hope I can lift the frame onto the engine with the carbs fitted coz they're on there:
Just ignore the stator cover. Looks like I found it on the beach.
Old Streetfighter Motorcycle Forum Post 07-21-2019, 05:45 PM   #50
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
Thundercat radiator:
It's a bit bent but looks good otherwise. I can't use an FZR radiator coz the Tcat engine has oil cooler lines going to the rad whereas the FZR does not. So I gotta get this radiator to work with my frame. First problem is the top mounts are perpendicular to how I need them. 2nd is apparently the fan doesn't fit so I might need to move the rad forwards. And the bottom of the rad hits the front wheel so I need to move the rad backwards...... hm.
Thinking ahead, I plan to have a small overflow bottle from the nipple by the cap and block off the nipple below that which would usually go to a reservoir in the tail:
I think that's how it's done on a fighter, right?
Thank you for viewing FZR 600 RR Build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - FZR 600 RR Build on Custom Fighters Streetfighter Motorcycle Forum
