Daily Street SuMo - Page 46 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Daily Street SuMo
Old Streetfighter Motorcycle Forum Post 02-14-2019, 02:00 AM   #451
shinyribs
Local Time: 06:17 AM
Flip Offs: 58
Default Re: Daily Street SuMo
Originally Posted by Larry02ACR View Post
Well, to be the odd man out, I've run NGK iridiums in my KX250, now a 295 for years without problems. It is what Kawi specs on this bike.
Since Kawi specs this plug as standard I wonder if something in the ignition system is specifically designed to work with it? My old CB had what was a notoriously weak ignition system so I figured I'd give the Iridium's a chance as it might help the old dog out. Looking back, it may have just exposed that system's shortcoming even more. Perhaps your bike's ignition is hot enough to make good use of them. Kawi obviously thought so.
Been tempted to try them again in the FZ. That bike can eat up a standard plug in about 8k miles.
Old Streetfighter Motorcycle Forum Post 07-27-2019, 06:20 AM   #452
Smoker
BLACK BELT
Local Time: 03:17 AM
Flip Offs: 34
Started stripping off the crashed parts.
Still moving slow, but made some progress.
Bars took a hit, even with the handguards. Bars are slightly bent, anyway.
Both mirrors are damaged, now. The machine shop hasn't wanted to make me another set. Will try again.
Shifter tip got grinded. Already have the replacement.
Front fender is toast.
Half the titanium footpeg is gone.
Enough for now. More damage to post tomorrow.
Old Streetfighter Motorcycle Forum Post 07-27-2019, 09:56 AM   #453
shinyribs
Flip Offs: 58
That's crazy how the peg just snapped off.
Old Streetfighter Motorcycle Forum Post 07-27-2019, 11:13 AM   #454
Smoker
BLACK BELT
Flip Offs: 34
I read it's very common with these particular footpegs.
They're factory Yamaha for the YZ series, but they're CAST titanium - so very brittle.
Old Streetfighter Motorcycle Forum Post 07-29-2019, 11:25 AM   #455
Junkie
re-tarded
Flip Offs: 3
wow, you went down HARD if you bent fatbars
Old Streetfighter Motorcycle Forum Post 08-04-2019, 07:45 AM   #456
Smoker
BLACK BELT
Flip Offs: 34
Had thick aluminum bash bars bolted to the handlebar ends and to the forks.
Bent those, too.
Old Streetfighter Motorcycle Forum Post 08-04-2019, 08:13 AM   #457
Smoker
BLACK BELT
Flip Offs: 34
Trying to pull the front end, so I can install the billet triples.
Not sure how to proceed. May be best to purchase a new ignition switch.
Was going cut a slot in the safety bolts with a dremel, but they're recessed into the ignition. Can do it, but won't be easy. Bolts are locktited in, so would probably need an impact driver, as well.
Old Streetfighter Motorcycle Forum Post 08-04-2019, 09:43 AM   #458
AgentOrange
Aspiring Hooligan
Fighterer
AgentOrange's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 1 Time in 1 Post
AgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to allAgentOrange is a name known to all
Center punch and drill the heads off? I did that on an old Kawasaki, not sure if the Yamaha has hardened bolts or not. once the heads are drilled out you can get some vise grips on the shank.
Edit:You could also use a screw extractor, same sort of thing but no vise grips needed.
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs.
AgentOrange is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived AgentOrange!
Old Streetfighter Motorcycle Forum Post 08-04-2019, 08:25 PM   #459
Casper
The friendly Ghost.
Flip Offs: 188
Second the drill the heads off.
Old Streetfighter Motorcycle Forum Post 08-05-2019, 06:38 AM   #460
RS_Raz
Dickhead
Senior Fighterer
Local Time: 11:17 AM
Flip Offs: 10
I did this a couple of weeks ago on an FZR triple, and an FZS. Centre punched, pilot drilled a little and then 1/4" on one til the heads came off and 5/16" on the other (one had M6 & one M8). Then went to wind nuts onto what was left to tack on but they were loose and wound out by hand.
Thank you for viewing Daily Street SuMo in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Daily Street SuMo on Custom Fighters Streetfighter Motorcycle Forum
