370steve goes EFeeeeeeeeeeeee - Page 7 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > 370steve goes EFeeeeeeeeeeeee
Old Streetfighter Motorcycle Forum Post 01-28-2020, 04:54 PM   #61
370steve
old fart
Local Time: 05:46 AM
Flip Offs: 33
Default Re: 370steve goes EFeeeeeeeeeeeee
test fit of pegs went well, feel comfatable and in the right place for me to start with, only problem so far is gear change lever to side stand clearance issues.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 01-29-2020, 04:25 AM   #62
370steve
old fart
Flip Offs: 33
New cunning plan is to rotate the mountings forward so the top mounting hole is in the web, this will give me more clearance on the side stand and also allow more room for the exhaust link pipe to sit between frame and swing arm. I will test it out and see if it is still comfortable on my legs and back.
also going to look at removing the side stand bracket and moving it in and under the frame loop so the side stand sits much closer to the frame and further under out of the way!
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 01-29-2020, 08:23 AM   #63
370steve
old fart
Flip Offs: 33
Just landed at SPS, will be sending them out soon as my hard welded rockers turn up from APE, should also be tomorrow.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 01-29-2020, 10:15 AM   #64
370steve
old fart
Flip Offs: 33
block and pistons turned up today from Warp Speed Racing, lovely job
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 01-31-2020, 09:34 AM   #65
370steve
old fart
Flip Offs: 33
more good stuff arrived today
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 02-02-2020, 06:04 AM   #66
370steve
old fart
Flip Offs: 33
and it is all going in a direction that i am very happy with, last night i did a second session on the peg fitment, i have concluded that the initial fitment of them is where they are going to live,* am going to have to move the side stand, i will cut it off and weld it back on where it is more tucked in and clear of the gear lever.
did the first test fit of the side pannels, they fitted better than i thought they were going to, as they seem to have warped slightly, having been sat in my hot shed in the summer. going to try warming them up with a hot air gun, see if they will adjust for better sit, if not i will add a very small screw at the bottom into the brece bar, to hold it in.
after fitting the rear light and good grab handle it became very obvious that something wasnt correct with alignment!**played around with it for a bit but couldnt get ti to sit correctly, swapped it for a second grab handle (that has split rubber so wasnt wanting to fit) and all fitted well, so looks like the "good" one is bent!
which leaves me with either trying to find a good condition straight handle, or attempting to bend the one i have without doing the rubber cover too much damage.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 02-02-2020, 10:48 AM   #67
370steve
old fart
Flip Offs: 33
removed the side stand bracket, came off a lot easier than i thought it would, so bit of re shaping and grinding and it will be going back on but slightly forward and inward to give me the required clearance on the gear lever.
how she was before i pulled her apart to remove the side stand
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 02-02-2020, 02:52 PM   #68
370steve
old fart
Flip Offs: 33
after cutting the stand bracket off I cleaned it up, shaped it and removed the blob from the end of the stand foot, looks like we have lift off
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 02-03-2020, 07:49 AM   #69
370steve
old fart
Flip Offs: 33
just ordered a set of GSXR K4 pillion pegs to fit. also ordered some Gilles adjustable pegs for them.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 02-03-2020, 01:29 PM   #70
370steve
old fart
Flip Offs: 33
parts came back from Taff, also sorted top shock brackets
test fit of shock brackets, look to be sat just where they need too
bearing hood and locking nut fit just as planned, yokes sit on them great, will just need a 3mm thick spacer making for the stem nut to sit on once all is assembled.
SHIT HAPPENS!!!!!
Thank you for viewing 370steve goes EFeeeeeeeeeeeee in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - 370steve goes EFeeeeeeeeeeeee on Custom Fighters Streetfighter Motorcycle Forum
