Advice on riser positioning - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Advice on riser positioning
Old Streetfighter Motorcycle Forum Post 10-23-2018, 11:34 AM   #1
remfanuk
Local Time: 10:23 PM
remfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to all
Default Advice on riser positioning
Before I drill my top yoke (triple tree) I thought I would ask the wisdom of CF first.
I am not sure whether to go for a single bolt riser or double bolt set up. If consensus is for a single bolt, which position should I drill, red or black? I would feel better with a two bolt solution and think that there is enough metal to accomodate that type of riser.
I will be purchasing some ally slab and cut it to fit into the pockets under the yoke to help spread the load of the riser bolt/s.
Advice appreciated guys. Thanks.
ID:	102792   Click image for larger version
remfanuk is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-24-2018, 05:59 AM   #2
Local Time: 03:23 AM
Default Re: Advice on riser positioning
I make mine with 2 bolts , if you were using one the ideal position is prob going to interfere with the rib on the underside
Old Streetfighter Motorcycle Forum Post 10-24-2018, 07:09 AM   #3
remfanuk
I shall take some measurements and go for two bolts as one can go in the red spot and one in the black spot, either side of the rib underneath, which looks to be the obvious solution and will place the bars practically in the middle of the yoke. Packed out underneath the top yoke with a carefully sculptured piece of ally JB welded to the yoke, washer, flanged Nyloc nut and the job should be a good'un.
Anything else I should be aware of as well as ensuring the bars don't foul the forks and the risers being sufficiently wide apart? Cheers.
This user High Fived remfanuk!
Old Streetfighter Motorcycle Forum Post 10-24-2018, 08:14 AM   #4
just be sure they sit high enough to not clip the fork tops i guess
These people High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 10-24-2018, 09:12 AM   #5
remfanuk
for a clean look...albeit underneath the top yoke...I could use single bolt risers through the clipon screw holes which are within the beefier part of the yoke. As riser bolts tend to be 12mm from what I have seen, drilling through the clipon screw hole will leave one side of it quite thin...is that an issue? Any other issues I am not seeing with that? cheers.
Old Streetfighter Motorcycle Forum Post 10-24-2018, 06:07 PM   #6
it'll set the risers quite far apart, check the centre of your bars is wide enough
Old Streetfighter Motorcycle Forum Post 10-25-2018, 09:37 AM   #7
remfanuk
I hadn't thought about that Yan...doh! I won't be drilling anything until I have the risers and bars, but need to take these things into consideration.
Old Streetfighter Motorcycle Forum Post 10-26-2018, 02:47 PM   #8
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 11:23 PM
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
I'd go 2 bolt, for reasons above. Also creates a lot less stress on the holes you drill; with a single bolt, you might get ovalization over time, have to clamp things tighter, etc. Clamping things down with two spaced bolts is always more durable than one (maybe fatter) bolt.
So the answer is both - you drill both red and black, assuming the risers line up.
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived sebwiers!
Thank you for viewing Advice on riser positioning in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - Advice on riser positioning on Custom Fighters Streetfighter Motorcycle Forum
