Caliper swap thread.. - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Brakes and Suspension
Brakes and Suspension Anything to do with fabricating and modifying brakes and suspension goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Caliper swap thread..
Old Streetfighter Motorcycle Forum Post 02-15-2011, 02:08 PM   #31
drugstation
fighter Bandit 1200
drugstation's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 10:23 AM
drugstation is a good noobiedrugstation is a good noobie
Default Re: Caliper swap thread..
awsome a really good + to the site
drugstation is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-13-2012, 12:29 PM   #32
a_morti
Local Time: 02:23 PM
Flipped Off 24 Times in 14 Posts
a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!a_morti is an amazingly helpful member with a good attitude!
From my own experiments...
group 17:
CBR900 92-97 (same as gold calipers from VTR1000f)
CBR900 98-99 (silver with steel pistons, these are same as 600F4i)
CBR900 00-03 (gold bodies with ally pistons)
CBR600RR3-4 (gold with ally pistons, biggest of this type)
GSXR600/750 K2, Bandit 650, 1250, etc Tokico 4-pots (but these are very poor build quality)
There are I believe some 6-pots which fit also, but the performance of these is poor in comparison. If you want to fit bigger/newer calipers to your VTR1000f you'll need to dremel on the forks mounting points but it's safe to do there is loads of meat there.
Always match piston sizes to master cylinder - if you calipers have 27/30mm pistons, get a 14mm master. If they have 30(32)/34mm pistons, you need a 5/8" master. If you get the RR3/4 calipers, you need the corresponding 11/16" master. If you get this wrong your brakes will be very poor, either wooden or spongey but certainly not right.
Good luck all
If anyone isn't sure as I am only a newbie, check pics here... the forks are all CBR900 96/7, you should recognise the bits if you're looking at the pics
http://s74.photobucket.com/albums/i2...0blade/Tokico/
http://s74.photobucket.com/albums/i2...%20new%20CB-1/
a_morti is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-14-2012, 09:14 PM   #33
Deftone
Deftone's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 06:23 AM
Deftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of lightDeftone is a glorious beacon of light
I have an '05 GSXR1000 for track/street with '05 750 forks, brakes, etc....
I put '04/05 R1/R6 calipers on it. The R1 calipers are mono block Sumitomo's, which are superior to the OEM two piece Tokico's. I also used '02 GSXR rotors, which are 320mm instead of the stock '05 750 300mm. This required a 2mm spacer from Zoran at TWF racing. He has different spacers for different brake/fork/rotor combinations.
The bike also has a Brembo master and SS lines. The R1/R6 master is much cheaper and works very well.
Braking is PHENOMENAL.
Zoran at TWF is extremely knowledgeable on brake swaps and very helpful. email him.
http://www.twfracing.com/images/zpar...20003%20bg.jpg
http://www.gixxer.com/forums/showthread.php?t=319033
http://www.gixxer.com/forums/showthread.php?t=197586
'17 FZ-10 - Daily Commuter/Sport Tourer/Track
'09 KTM 250XC-W 2stroke - Dirt
'07 KTM 525EXC Dirt/Street/Sumo
Originally Posted by ravage73 View Post
next time, dont spit on it, just slam it in........and then donkey punch.
Deftone is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Deftone!
Old Streetfighter Motorcycle Forum Post 10-15-2012, 07:18 PM   #34
Mustapha dump
Local Time: 01:23 PM
Flipped Off 42 Times in 21 Posts
Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!Mustapha dump is a wicked helpful, well liked member!
All the Japanese radial calipers are 108mm spacings with the exception of the 6 pot R1 calipers which are 130mm. european calipers are 100mm spacings.
Early K series wheels 600/750 upto inclusing K5 and 1000K1/K4 will take 300mm discs from the 1000K3/4 600/750K4/5, or 310mm SV1000 discs, or 320mm discs from the SRAD/TL/Busa/GSX14/1000K1'2/600/750 to K3
Radial calipers are easy to space out for larger diameter discs by the simple addition of spacers under the calipers and longer caliper bolts.
Some people are deserving candidates for postnatal abortion, the majority of the remainder are just idiots
Mustapha dump is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-23-2018, 04:21 AM   #35
Gacek
Local Time: 08:23 AM
Gacek is a NOOB
Can someone who have a 4 piston radial mounted caliper from brembo ( like in Ducati Monster 796 ), measure the width of it? I don't know if they would fit my bike. Thanks for help.
Gacek is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-24-2019, 05:41 PM   #36
Need to dig through this need calipers for srad front end... Posted to subscribe so I can find it after Christmas.
Sent from my SM-G973F using Tapatalk
Old Streetfighter Motorcycle Forum Post 12-24-2019, 05:59 PM   #37
Default Caliper swap thread..
88-99 Gsxr750
92-93 Gsxr600
97-00 Gsxr600
89-97 Gsxr1100
TL1000R
TL1000
Gsf1200
Hayabusa (1st gen)
96-03 Zx9
Zrx1100-1200
96-02 Zx7
Depends on the model and year but some are 4-piston Nissjn’s, 4-piston Tokico’s or 6-piston Tokico’s.
‘74 Kawasaki H1-500 Project
‘76 Kawasaki Kz900 'Strip-fighter Project
‘78 Kawasaki Kz1000 Project
'80 Cx500 Cafe/Brat Project
‘83 Kawasaki Gpz750 (Turbo Converted) Project
Streetfighterkz is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Streetfighterkz!
Old Streetfighter Motorcycle Forum Post 12-24-2019, 06:05 PM   #38
Originally Posted by Streetfighterkz View Post
88-99 Gsxr750
92-93 Gsxr600
97-00 Gsxr600
89-97 Gsxr1100
TL1000R
TL1000
Gsf1200
Hayabusa (1st gen)
96-03 Zx9
Zrx1100-1200
96-02 Zx7
Cheers Doug. Think I want 4 pots so narrow it a bit but let the searching begin
Old Streetfighter Motorcycle Forum Post 12-24-2019, 06:10 PM   #39
88-92 Gsxr750 (Nissin)
89-92 Gsxr1100 (Nissin)
TL1000S -Tokico
SRAD600 -Tokico
Don’t hold me to those though. :P
Old Streetfighter Motorcycle Forum Post 12-25-2019, 04:54 AM   #40
a_morti
I've usually found nissin calipers to be better build quality than tokico.
YMMV...
Aaron, living in Gibraltar and riding a 2014 MSX125 (Grom) with a bunch of shiny shite on it. Slow n loud!
This user High Fived a_morti!
Thank you for viewing Caliper swap thread.. in the Brakes and Suspension section of our streetfighter motorcycle forum. I hope you found it useful!
Brakes and Suspension - Caliper swap thread.. on Custom Fighters Streetfighter Motorcycle Forum
