Should I buy a salvaged S1000R? - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > General Streetfighter Discussion
General Streetfighter Discussion Discussions about streetfighter riding.
CustomFighters.com Streetfighter Motorcycle Forum > Should I buy a salvaged S1000R?
Old Streetfighter Motorcycle Forum Post 10-30-2019, 08:51 PM   #31
titan
hooligan quads
titan's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 09:53 AM
Flip Offs: 3
Flipped Off 14 Times in 2 Posts
titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!
Default Re: Should I buy a salvaged S1000R?
Originally Posted by Junkie View Post
not sure how it will look, but my 1190 light is like daylight at night
ride it like you stole it
Customization not Restoration
Originally Posted by Albert Einstein
I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.
H Designs
2020 build off - build - chat
titan is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived titan!
Old Streetfighter Motorcycle Forum Post 10-30-2019, 11:23 PM   #32
tldave
Flip Offs: 5
If you intend to spend a lot of time riding in the heat, get an OE rad. The Chinese rads work great, but usually have shittier flow, and fewer fins. I have put a shitload of them on beater bikes, and seen them on sport bikes, but I wouldn't do it on my personal higher hp bike if I was tracking or summer riding it. For everything else they are usually great.
Old Streetfighter Motorcycle Forum Post 10-31-2019, 01:25 AM   #33
tldave
Flip Offs: 5
The radiator doesn't look messed up in the pics. I have run and sold some bent ass radiators. If it doesn't leak, it's fine .
Old Streetfighter Motorcycle Forum Post 10-31-2019, 10:56 AM   #34
Junkie
re-tarded
Local Time: 06:53 AM
Flip Offs: 3
the filler neck is snapped off of the end tank, I could try plastic welding it on but I don't really trust that. I'm holding the cap/filler down in this pic.
we can split lanes here so I'm not *too* worried about heat
Old Streetfighter Motorcycle Forum Post 10-31-2019, 10:58 AM   #35
Junkie
re-tarded
Flip Offs: 3
hmm... I wonder how it'd look fork mounted.
or I could hard mount it if I wanted, the frame has the bosses for the fairing they just didn't drill/tap them, I guess they use the same casting vs RR.
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 10-31-2019, 05:58 PM   #36
tldave
Flip Offs: 5
if you made a D shaped piece of alum, with the curved part going all the way to the bottom of the radiator for support, and the flat part of open for the fins, but the upper part fully enclosed, so the filler neck could slot over, I bet you could get it to seal. but that might be a lot of fucking around. Ive got a couple of bikes with jb welded cooling systems, and motor patches. I don't think youll have any issues if you do it right. I would also jb some plastic pieces around the outside of the seem too. overkill. If its abs you use methyl ethyl ketone to melt the plastic back together. I dunno what the fuck radiator plastic is. I also don't think you can effectively use both and not have some sort of cross contamination. but I not sure. just seems like the MEK woudl fuck with the JB cure.
Old Streetfighter Motorcycle Forum Post 10-31-2019, 06:18 PM   #37
yantosh
Local Time: 02:53 PM
Flip Offs: 14
we patch up rads with belzona1111 ,works great
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 10-31-2019, 06:21 PM   #38
tldave
Flip Offs: 5
what he said hes smrter than me.
Old Streetfighter Motorcycle Forum Post 10-31-2019, 08:56 PM   #39
Junkie
re-tarded
Flip Offs: 3
damn, I bought a China aluminum radiator prior to seeing Yantosh's post. oh well, it's only money.
still need to find a headlight.
Old Streetfighter Motorcycle Forum Post 10-31-2019, 10:20 PM   #40
tldave
Flip Offs: 5
lolol. check fb messages dude
Thank you for viewing Should I buy a salvaged S1000R? in the General Streetfighter Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
General Streetfighter Discussion - Should I buy a salvaged S1000R? on Custom Fighters Streetfighter Motorcycle Forum
