2008+ Hayabusa fork onto Bandit 1250. - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Street Fighter Swaps > Fork Swaps
Fork Swaps Fork and Front End Swap Discussion goes here
CustomFighters.com Streetfighter Motorcycle Forum > 2008+ Hayabusa fork onto Bandit 1250.
Old Streetfighter Motorcycle Forum Post 05-06-2014, 05:01 PM   #21
1CAMWNDR
Noobie
Local Time: 04:58 AM
Location: Northwest Florida, land of no 1/4 mile tracks
1CAMWNDR is a NOOB
Default Re: 2008+ Hayabusa fork onto Bandit 1250.
Well, went to the shop today and had the tires switched over. My Pilot Power 3 was nearly new so I had that put onto the Hayabusa rim.
But the steering stem was a disaster. Instead of pressing out it bent and now the bottom looks like an egg instead of a circle. And the Bandit lower tree bent also. Shit.
So now I need to find a steering stem. And the only ones for sale on ebay include a lower tree which I really do not need. Oh, and they are $325.
Maybe a custom built one?
2008 Suzuki Bandit 1250 Naked conversion and lots of Holeshot goodies
2009 Hayabusa front end conversion
1CAMWNDR is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 06-06-2014, 01:24 PM   #22
1CAMWNDR
Noobie
1CAMWNDR is a NOOB
Well I got ahold of a Bandit 1200 lower tree and steering stem. It is the same part number as the 1250. Made a narrow cut in the lower tree since I am not gonna use it, heated it up a bit with a propane torch, and tapped it out with a hammer.
I have been unsuccessful finding a shop to press out the Hayabusa stem and press in the Bandit one. And I am sick of waiting. Tomorrow I am going to Harbor Freight and buying a 20 ton shop press.
This user High Fived 1CAMWNDR!
Old Streetfighter Motorcycle Forum Post 06-06-2014, 01:32 PM   #23
Rob_0t
Hard Core Sledder
Rob_0t's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:58 AM
Flip Offs: 40
Flipped Off 35 Times in 27 Posts
Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!Rob_0t is an amazingly helpful member with a good attitude!
Whennall else fails... do it your damnnself ..
Props. !
Kill3rBaconRacing
Undead zed biggity build thred ( zx600c )
http://www.customfighters.com/forums...=1#post1137667
Rob_0t is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Rob_0t!
Old Streetfighter Motorcycle Forum Post 06-06-2014, 01:50 PM   #24
1CAMWNDR
Noobie
1CAMWNDR is a NOOB
Props. !
Indeed. This is why I have done all of the work to my Firebird over the last 15 years. Including engine, clutch, and rearend swaps in the driveway. Except mounting and balancing tires. Because I don't have the equipment.
Old Streetfighter Motorcycle Forum Post 06-12-2014, 11:48 AM   #25
1CAMWNDR
Noobie
1CAMWNDR is a NOOB
Purchased a 20 ton shop press. Got it loosly assembled but nothing lines up because the floor is uneven. It was too hot to keep at it so I left it loose. Will use some 1/8" steel plate for shims to get it even before I run everything tight with the impact wrench.
Old Streetfighter Motorcycle Forum Post 06-17-2014, 10:04 AM   #26
1CAMWNDR
Noobie
1CAMWNDR is a NOOB
Sunday I got the steering stems swapped, new bearings packed and pressed on, and the Hayabusa lower tree and steering stem installed on the frame. Now to make a bracket to mount the gauge cluster to the Hayabusa top tree. And change fork oil. And start reassembly!!!
Last night Last night I spent a little while making up new brackets for the gauge pod to mount to the Hayabusa top clamp, got the top clamp installed loose and managed to get the handle bars and 1" up/1" back risers on loose. That made the clutch hydraulic line a little tight.....so I might take those risers off......we will see. But it is starting to look like a motorcycle again!
Will not be able to work on it today and maybe not Wed. but I will do a little Thur, Fri, Sat, and if needed Sun. I think the hardest part from here on in is going to be the new brake line routing and bleeding.
Oh, and wheel paint and clear does not appear to work in a fiberglass front fender. Sections of it just rubbed off like a stripper was working on it. More sanding and a different paint and clear needed....
Old Streetfighter Motorcycle Forum Post 06-19-2014, 06:12 PM   #27
1CAMWNDR
Noobie
1CAMWNDR is a NOOB
Progress and a set back....
Forks installed, triple clamps installed, handle bar and gauge pod installed, tire installed. Went to put the brake calipers on and the right (throttle side) caliper is resting on the disc .
Turns out there is a spacer for the right side of the axle that was left out of my order.
Here are a few pics of the progress..
ID:	49857   Click image for larger version
ID:	49865   Click image for larger version
Name:	wire routing.jpg
ID:	49873   Click image for larger version
Old Streetfighter Motorcycle Forum Post 06-25-2014, 02:02 AM   #28
1CAMWNDR
Noobie
1CAMWNDR is a NOOB
FINISHED!!! (Sort of). The front fender needs a repaint, and I need the correct spacer for the front axle instead of the slightly too big axle bearing race I had laying around from an axle swap and ground down, and the brass brake pad spring clips. But it puts around the neighborhood fine.
The forks are too stiff. But there are adjustments for that. Might need to take out some fork oil. But that can all be dealt with.
Now, PICS!
Name:	Finished(sort of) close.jpg
ID:	50042   Click image for larger version
Name:	Finished(sort of) handle bar-top clamp.jpg
ID:	50050   Click image for larger version
Name:	Finished(sort of)34 front.jpg
ID:	50058   Click image for larger version
Name:	Finished(sort of) whole bike.jpg
Old Streetfighter Motorcycle Forum Post 06-30-2014, 06:58 PM   #29
1CAMWNDR
Noobie
1CAMWNDR is a NOOB
FINISHED!!!
Got the correct axle spacer and brake pad spring clips installed. Also took out 20cc of fork oil from each fork. MUCH more compliant ride. And the compression adjusters are in the center of the range...so I can go softer or stiffer if I want to!
Happy Bandit Hybrid Owner!!
Old Streetfighter Motorcycle Forum Post 02-11-2016, 05:13 PM   #30
daags
NoObie
Noobie
Local Time: 10:58 AM
daags is a NOOB
I was checking your thread and could you please explain or post some more picture about closer view of fork extensions ? I m going on a same way, to install busa front end and at the moment thinking which will be the best and strongest way to keep the original height of the bandit.
daags is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing 2008+ Hayabusa fork onto Bandit 1250. in the Fork Swaps section of our streetfighter motorcycle forum. I hope you found it useful!
Fork Swaps - 2008+ Hayabusa fork onto Bandit 1250. on Custom Fighters Streetfighter Motorcycle Forum
