Kat's Volty two-fiddy Street Tracker - Page 5 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Kat's Volty two-fiddy Street Tracker
Old Streetfighter Motorcycle Forum Post 07-25-2018, 12:28 PM   #41
a_morti
Local Time: 12:22 PM
Flip Offs: 24
Default Re: Kat's Volty two-fiddy Street Tracker
Any particular reason to use the rs50 parts over parts from an rs125? Idk in your part of the world but in UK, the 125 parts are much more common, so cheaper. I guess the 125 is also heavier so would come with heavier springs. Or spring, I know the mito 125 used a single fork spring with the other leg just for the damping so maybe others are same.
Best bet is just get the wheels and make them fit. If you're doing a whole front end swap, there are very few combinations that can't be made to work with a big enough hammer.
Old Streetfighter Motorcycle Forum Post 07-25-2018, 12:33 PM   #42
GoodKat
Mr. Good Kat
Fighterer
GoodKat's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:22 AM
GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!GoodKat is an amazingly helpful member with a good attitude!
Hey @a_morti! Where do I live - Eastern Europe - RS 125 parts and RS50 are costing roughly the same. The downside for RS125 is that the wheels are too wide 110 for the front and 150 for the rear.
GoodKat is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 09-05-2018, 06:40 AM   #43
GoodKat
Mr. Good Kat
Fighterer
Slow updates:
Set a 21.3 degrees upward bend on the rear frame loop to have enough clearance for the rear wheel, even though the current shocks are 6 cm taller than the standard ones.
Old Streetfighter Motorcycle Forum Post 09-05-2018, 06:43 AM   #44
GoodKat
Mr. Good Kat
Fighterer
Also, I need some enlightment regarding the rear wheel cush drive.
I want to change the spoked wheels with alloys but I hit a wall regarding the selection of wheels.
First I said that I'm going to use Aprilia RS 125 wheels ...then I noticed that the sprocket and disc are on the wrong sides, flipping the rear wheel is not a solution...plus, the tires are too wide for my project.
Then I said that I'm going to use Aprilia RS 50 wheels...seemed nice until I noticed that there is no rubber cush drive on the rear wheel.
AFAIK, the role of the cush drive is to protect the transmission from the shocks of the rear wheel.
Now...the wheels I am aiming are from a HONDA NSR 125 (2000). They look nice but the rear wheel has some cylindrical rubber bushings instead of the triangular rubber cush drive.
Anyone knows if there is a problem regarding the transmission if I decide on using the NSR wheels?
Important notice: the bikes above are all 2 strokes, my project is a 4 stroke, I don't know if this matters.
I am looking for a pair of alloy wheels, with the sprocket on the left, brake disc on the right, not too expensive (preferably around the year 2000-2005 to get a good price) front tire width between 90-110 and rear between 110-130. If you got any other suggestions, let me hear.
...OR IF YOU GOT A SET OF ALLOY WHEELS FROM A 125cc BIKE THAT MEETS THE CONDITIONS MENTIONED ABOVE, TO THROW AWAY FOR BEER MONEY, LET ME KNOW.
Old Streetfighter Motorcycle Forum Post 09-05-2018, 10:28 AM   #45
GoodKat
Mr. Good Kat
Fighterer
New pictures with the frame almost finished:
The sidestand mount is tack welded, need to add a gap filler between the mount and the vertical frame rail and some welds on the rear hoop.
These people High Fived GoodKat!
Old Streetfighter Motorcycle Forum Post 09-10-2018, 03:57 AM   #46
rex_saugerty
V four honda whore
Local Time: 01:22 PM
Flip Offs: 3
there are sprockets with rubbers. you can scoop around JT sprocket homepage for options
Old Streetfighter Motorcycle Forum Post 09-10-2018, 04:43 AM   #47
GoodKat
Mr. Good Kat
Fighterer
Regarding wheel's I've set my mind to Yamaha MT125 wheels. Nice alloy spoked wheels, perfect dimensions AFAIK and not too expensive.
But first I need to get the bike back from the shop and fix it for ITP (the equivalent of MOT here).
This user High Fived GoodKat!
Old Streetfighter Motorcycle Forum Post 10-05-2018, 06:07 AM   #48
GoodKat
Mr. Good Kat
Fighterer
And here is the freshly painted gas tank.
The knee dents turned out better than I thought. For the first time I'm hammering some knee dents on a gas tank, i think they turned out pretty well.
Old Streetfighter Motorcycle Forum Post 10-05-2018, 06:09 AM   #49
GoodKat
Mr. Good Kat
Fighterer
The paint code was sourced from an Opel color catalog. I forgot the code but turned out pretty nice. First I was thinking to paint it in British Racing Green but then I said to myself that it needs some bling and so, some glitter was added.
Old Streetfighter Motorcycle Forum Post 10-05-2018, 11:55 AM   #50
ZeroFret
Noobie
ZeroFret's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:22 AM
ZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to allZeroFret is a name known to all
Default
Cool project! I’m digging it, and excited to see where it goes.
ZeroFret is offline   Reply With Quote on our streetfighter motorcycle forum
Tags
250, custom, suzuki, tracker, volty
Thank you for viewing Kat's Volty two-fiddy Street Tracker in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Kat's Volty two-fiddy Street Tracker on Custom Fighters Streetfighter Motorcycle Forum
