Buell XB12Scg 2009 - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Buell XB12Scg 2009
Old Streetfighter Motorcycle Forum Post 02-23-2015, 03:14 AM   #21
TPEHAK
Active Member
Fighter
Local Time: 12:08 PM
Flipped Off 1 Time in 1 Post
TPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud of
Fighter of the Month Fighter of the Month
Default Re: Buell XB12Scg 2009
Originally Posted by cpomeroy View Post
That's an awesome chain swap. Engineer by trade?
yup
TPEHAK is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-24-2015, 12:19 AM   #22
cpomeroy
Fighter In Training
cpomeroy's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
cpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of lightcpomeroy is a glorious beacon of light
Good to see what we do actually get put to work! I'm currently a senior in mechanical engineering
"In a car you're always in a compartment, and because you're used to it, you don't realize that through that car window everything you see is just more tv. You're a passive observer and it is all moving by you boringly in a frame. On a cycle the frame is gone. You're completely in contact with it all. You're in the scene, not just watching it anymore, and the sense of presence is overwhelming."
cpomeroy is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-24-2015, 06:28 PM   #23
F'dup
Hack in a barn
F'dup's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 35
F'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on here
Funny story, kinda related...
I was doing a job at an engineer's house. He was in the kitchen for 45 minutes applying three stick on numbers to his new mailbox. After he "finished" he saw me and asked, "Do those numbers look straight to you?" To which I replied, "Well... I think that. Sure they seem pretty straight from here."
2017 build off sv650 build thread <---Click here
SV650 b.s.'n and post build off progress on the bike thread thread <---Click here
DR650 supermoto build <--click
2000 R6 build <--click
A bit of vaseline should lube your bush up real nice though. Just make sure that your shaft is a good fit.
F'dup is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-27-2015, 03:05 AM   #24
TPEHAK
Active Member
Fighter
Here is how to connect the Motoscope and Motosign wires to the plug
These people High Fived TPEHAK!
Old Streetfighter Motorcycle Forum Post 03-01-2015, 01:09 AM   #25
TPEHAK
Active Member
Fighter
I've finished the wiring.
It works!
Here is the relocated parts
This user High Fived TPEHAK!
Old Streetfighter Motorcycle Forum Post 03-01-2015, 02:34 PM   #26
TPEHAK
Active Member
Fighter
The LSL Headlight and the Motogadget stuff have been attached. All works fine!
Here is the wire harness under the headlight
And here is the result
Old Streetfighter Motorcycle Forum Post 03-01-2015, 03:31 PM   #27
TPEHAK
Active Member
Fighter
The right side scoop kit has been installed
Old Streetfighter Motorcycle Forum Post 03-02-2015, 01:30 AM   #28
TPEHAK
Active Member
Fighter
The new turn signals have been installed. I cut the bracket from aluminum sheet.
After a test ride I've figured out that the lower edge of the headlight hits the front wheel fender on bumps. So I have to raise up the headlight.
Old Streetfighter Motorcycle Forum Post 03-03-2015, 10:18 PM   #29
TPEHAK
Active Member
Fighter
The LSL headlight has been raised up.
Old Streetfighter Motorcycle Forum Post 03-03-2015, 11:36 PM   #30
Casper
The friendly Ghost.
Local Time: 10:08 AM
Flip Offs: 190
Are the fork clamps showing a little fade or are they going to stay that deep purple color?
Can't leave them alone:2006 Suzuki SV650N, 1994 Yamaha XJ600S and 1979 Suzuki GS750LN
Time to find me a nice DRZ and VStrom...
Thank you for viewing Buell XB12Scg 2009 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Buell XB12Scg 2009 on Custom Fighters Streetfighter Motorcycle Forum
