The HyperRetard! - Page 7 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > The HyperRetard!
Old Streetfighter Motorcycle Forum Post 02-12-2020, 08:10 PM   #61
mcantar
Fuck it, let's do it live
Local Time: 06:27 PM
Flip Offs: 46
Flipped Off 22 Times in 21 Posts
Fighter of the Year Fighter of the Month
Default Re: The HyperRetard!
Found rotors with the correct offset for my triples and the proper bolt pattern for the wheels, ordered them on Monday. Got a notification this morning they were out for delivery today, so turned up some spacers on my lunch break. Hadn't planned ahead whatsoever, so hadn't properly measured anything, just knew that the calipers need moved out 7.5mm and the wheels needed 8mm per side. Google said axle was 25mm, spacer turned out a little loose, and the outer diameters were total guesses.
New rotors are on the left. I don't really like the gold.
And we have a mounted wheel! Fits up perfect. Curious to find out how the brakes will feel with the increased leverage from the wider diameter rotors.
Gonna need to remake them with a larger outer diameter on the caliper spacers and smaller on the wheels, and tighten up the ID a bit. Easy peasy.
I'm very excited to add yet another mismatched carbon weave to this thing.
Still figuring out the rear. The spokes are rubbing on the caliper. My bike and most post-2004 Duc's use a 245mm rotor, but older Duc's used a 220mm rotor with the same bolt pattern. Finding a rotor and caliper bracket is easy, and cheap, but the caliper bracket on the newer bikes has a mount built in for the speed sensor and the older ones don't.
So that'll add another issue... don't really give a fuck about seeing my speed, but I have a suspicion that if the ECU doesn't see any wheel speed then it might throw a code (at best) or lock me into 1st gear's fuel map (at worst).
One thing at a time though... need to figure out if the caliper bracket will even fit the axle spindle hub thingy first. If it does, I'll order the bits and figure out the speedo later.
If not... Plan B is to make a couple mm spacer for the wheel and shave down the caliper as much as I can and hope it's enough.
If all else fails I could ditch the rear caliper altogether, fuckin thing barely works anyway, but I'd rather not.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
These people High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 02-12-2020, 08:52 PM   #62
mcantar
Flip Offs: 46
OR!!!!
What if I just went with an entire S4R ass end?
Because uh... trellis.
Supposedly the wheels came off of one, I'd imagine they'd go back on one.
I wonder if it would fit at the pivot. And the shock mount.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 02-12-2020, 08:58 PM   #63
mcantar
Flip Offs: 46
Nope, dead end. Or lotsa-fabrication-end anyway. Seems the Hyper uses the narrow case so the swingarm bearings are in the swingarm, and Monsturds use a wide case with the bearings on the case itself. If I did that much work I may as well just make my own damn arm.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 02-12-2020, 09:11 PM   #64
XxGRYMMxX
Breaking shit...
Local Time: 08:27 PM
Flip Offs: 8
Well? Get crackin!! You can do it!
Old Streetfighter Motorcycle Forum Post 02-12-2020, 10:44 PM   #65
mcantar
Flip Offs: 46
Still hunting for a good base to make a frame jig with.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 02-13-2020, 01:37 AM   #66
yantosh
Local Time: 01:27 AM
Flip Offs: 14
Thats just stoopid
*NCR prices ... not the make your own arm bit
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 02-13-2020, 09:53 AM   #67
SEBSPEED
V4's FTW
Flip Offs: 53
Pics of speed sensor setup?
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 02-13-2020, 12:59 PM   #68
mcantar
Flip Offs: 46
Hyper bracket looks like this. Sensor doodad on top, probably hall effect reads nubs on the rotor.
Then there is also this style used on S4R and maybe oher shit, sensor mount is under the swingarm instead of above for some reason. They're 245mm too though.
The 220mm bracket from the older bikes look like this. Pretty sure they have the speed sensor on the front wheel.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 02-13-2020, 01:24 PM   #69
MikeGyver
MikeGyver's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:27 PM
Flip Offs: 312
Flipped Off 173 Times in 149 Posts
MikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too muchMikeGyver plays with their repper too much
Default Medal Fighter of the Month
Yep, older bikes have the sensor on the front wheel
'98 Ducati 916
'00 Ducati 996
'03 SV650(sold)
Skully Stickers
Originally Posted by Danbuc View Post
yell, "Built not bought mother fucker!" in there face and then spit on their bike and walk off.
MikeGyver is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived MikeGyver!
Old Streetfighter Motorcycle Forum Post 02-13-2020, 10:15 PM   #70
mcantar
Flip Offs: 46
Got in touch with the previous owner of the wheels, asking what his setup was since his description was a bit convoluted talking about multiple bikes. He says they fit over a 2008 S2R 1000 caliper.
So, have one of those on the way.
Fingers crossed that a caliper swap is all that's needed here, but given that it's coming from a bike of the same year and same size rotor I'm not entirely confident the caliper will be that much smaller. Guess we'll find out.
Turbo Busa v1.1
This user High Fived mcantar!
Thank you for viewing The HyperRetard! in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - The HyperRetard! on Custom Fighters Streetfighter Motorcycle Forum
