The HyperRetard! - Page 9 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > The HyperRetard!
Old Streetfighter Motorcycle Forum Post 04-13-2020, 02:04 PM   #81
SEBSPEED
V4's FTW
Local Time: 09:08 PM
Flip Offs: 53
Default Re: The HyperRetard!
Crack the banjos while under slight pressure, air gets trapped there sometimes. I hate doing that, but sometimes the configuration doesn't leave another choice.
I'd crack the master banjo first, then remove the rear caliper and suspend it so the bleeder is the high point. Roll it around gently to work any air bubbles over to the bleeder. Tap the brake line with a plastic screwdriver end or your bleeder wrench starting at the master and working your way to the caliper, tap on the caliper too. Then do another few pump/bleed cycles on the caliper while it is suspended. Stick a piece of wood/plastic/clean scrap metal etc between the pads to prevent the pistons popping out.
Using that method has solved every troublesome brake bleed job I ever had.
One other thing you'll want to check is the piston sizes in the new vs old rear caliper. If there is a mismatch in piston ratio between caliper and m/cyl piston this can cause a spongy (or very acute) rear brake feel/response.
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 04-13-2020, 03:06 PM   #82
yantosh
Local Time: 02:08 AM
Flip Offs: 14
i always crack the banjos
Old Streetfighter Motorcycle Forum Post 04-13-2020, 04:19 PM   #83
Leroy
Leroy's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:08 AM
Flip Offs: 1
Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!
Tried bleeding the rear again. Fluid comes out clean, no air. I don't fucking know anymore.
Did you try to feed the fluids from the bleeding niple? Works every time for me. Push the fluid with a syringe and a thin hose to the niple. 40-50ml should be fine and then bleed the system with the normal way
Leroy is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-13-2020, 04:26 PM   #84
Leroy
Flip Offs: 1
My browser didn't take me to the 3rd page and I saw the last post after I wrote my post. Any way you are done with it
Old Streetfighter Motorcycle Forum Post 04-25-2020, 11:09 PM   #85
mcantar
Fuck it, let's do it live
Local Time: 07:08 PM
Flip Offs: 46
Flipped Off 22 Times in 21 Posts
This pic kinda shows the alternated brush direction. Perforated backplate shines differently than the face. Looks more better in person.
Made some brackets.
Held it up and sharpied the bracket locations.
Welded and riveted.
Some quick spacers.
And then the gauge.
Tadaaa.
Still gotta align it and wire up the light. Plate will sit parallel to the forks.
Also still gotta sort that brake bleed. And scrounge up 2 more Ti fasteners for the rotors. And some for the front calipers +5mm over stock.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 04-26-2020, 01:26 AM   #86
Gixooligan
Visions of Grandeur
Fighterer
Gixooligan's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 3 Times in 3 Posts
Gixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to beholdGixooligan is a splendid one to behold
Looks great. Nice work!
Gixooligan is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-26-2020, 04:09 AM   #87
yantosh
Flip Offs: 14
nice work on the brackets
Old Streetfighter Motorcycle Forum Post 04-26-2020, 10:36 PM   #88
SEBSPEED
V4's FTW
Flip Offs: 53
Those rivets look like M4 dash 4 or 5's... how far off am I?
ETA: no wet install? Shim check the heads? Locking rings all seated properly?
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 04-27-2020, 10:06 AM   #89
mcantar
Flip Offs: 46
Thanks guys.
Dunno Seb... took it to the assembly guys and asked for rivets that fit lol. Not my area of competence there.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 05-13-2020, 11:25 PM   #90
mcantar
Flip Offs: 46
Current state of affairs
Turbo Busa v1.1
These people High Fived mcantar!
Thank you for viewing The HyperRetard! in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - The HyperRetard! on Custom Fighters Streetfighter Motorcycle Forum
