SV1000Reptilia - Page 7 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > SV1000Reptilia
Old Streetfighter Motorcycle Forum Post 11-17-2019, 06:51 PM   #61
Leroy
Leroy's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:45 AM
Flip Offs: 1
Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!
Winter Buildoff Winner Fighter of the Month
Default Re: SV1000Reptilia
Last Friday arrived a pair of H4 1.5 inch bi-led projector bulbs I've ordered.
Those are smal enough to fit to my headlight. The opening of the cowl is 2 inch at the widest point.
So the 2.5 inch projectors woulden't fit good enough. Βought just a pair to see how good those are.
Those bulbs have low-hi but the hi led works with the existing lens of your headlight. The low lights have a great output
Ordered already an other pair to use it for the hi lights.
Also I've started to build the fuel tank. This is the first time that I've done this procedure.
I don't know with how many liters i will end up with it or even if I make it to finish this tank considering that it's a very complex design for a first-timer but I will give it a go.
Started with this last Friday
Here is my wife helping me to take some pictures of the tank on the bike
I have an other one pic from the front side but imgur doesn't let me to upload any other
And this is what I've managed so far
Done it. Here is the front side
Leroy is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Leroy!
Old Streetfighter Motorcycle Forum Post 11-18-2019, 01:41 AM   #62
yantosh
Local Time: 12:45 AM
Flip Offs: 14
if all suzuki fuel pumps have the same mount I can send you the hole pitch. one hole is 3 degree out of pitch
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 11-18-2019, 03:44 AM   #63
Leroy
Flip Offs: 1
That would be great! The fuel pump from the K3 1000 and my SV 1000 K4 are interchangeable. I'm not very sure but I think K5 and K7 are interchangeable too. Send it and I will check it.
Old Streetfighter Motorcycle Forum Post 11-24-2019, 06:04 PM   #64
Leroy
Flip Offs: 1
Ok here we go for the version 2 of the tank.
I did some changes to fit the fuel pump
It's a tight fit but it doesn't touch the walls at all
Tuked two tabs to support it to the upper section and two from cardboard for the bottom
After that I thought that I should make some more room for the fuell
I have ordered the fiberglass tank cover and waiting to arrive. It will help me to use all the hidden space under it and make the tank as big as it takes.
This user High Fived Leroy!
Old Streetfighter Motorcycle Forum Post 11-24-2019, 11:05 PM   #65
mcantar
Fuck it, let's do it live
Local Time: 05:45 PM
Flip Offs: 46
Flipped Off 22 Times in 21 Posts
Why not just put a bulkhead fitting on the tank and run an external pump? Easier tank design and more fuel capacity.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 11-25-2019, 12:42 AM   #66
Leroy
Flip Offs: 1
That's a great idea but would the sv work with an external pump? I've got no idea about
Old Streetfighter Motorcycle Forum Post 11-25-2019, 02:52 AM   #67
yantosh
Flip Offs: 14
internal, external, pump is a pump, as long as spec is ok
Old Streetfighter Motorcycle Forum Post 11-25-2019, 03:19 AM   #68
Leroy
Flip Offs: 1
So external it is! I have to redisign the tank, but loosing the pump I will gain at least 1/2 litre. Thank you guys! Rep'd for the help
Old Streetfighter Motorcycle Forum Post 11-28-2019, 03:12 PM   #69
tldave
Local Time: 06:45 PM
Flip Offs: 5
external pumps run hotter, so while a pump is a pump, they are more prone to burning out due to this. In tank is nice and coolio. Also why its not good to run your vehicles low on gas in hot places.
Old Streetfighter Motorcycle Forum Post 11-28-2019, 03:55 PM   #70
Auser6guy
Active Member
Fighter
Auser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to all
Default
I was under the impression pumps designed for external use used the fuel running through them for cooling ? The old external Bosch 044 I had on my old car lasted years. Say what you want about Germans they make some stout electrics 🙂
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
Thank you for viewing SV1000Reptilia in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - SV1000Reptilia on Custom Fighters Streetfighter Motorcycle Forum
