RZV500 Two-Stroke Roller - Page 56 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > RZV500 Two-Stroke Roller
Old Streetfighter Motorcycle Forum Post 01-13-2020, 10:49 AM   #551
929_adam
929_adam's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 07:35 PM
Flip Offs: 501
Flipped Off 166 Times in 132 Posts
929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!
Default Re: RZV500 Two-Stroke Roller
You can run them internally...
Gavin Wayne Butts - Greencheezeeta - 10/5/83 - 9/8/09 RIP My Brother
Originally Posted by mpls|cafe|racer
"Knowledge is knowing that you know nothing." That's a motto to live by. There's always someone out there better, more knowledgable, faster, etc. and you can always learn and improve...
AFF.COM
929_adam is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived 929_adam!
Old Streetfighter Motorcycle Forum Post 01-13-2020, 11:06 AM   #552
Local Time: 04:35 PM
damnit, you beat me to it
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 01-13-2020, 01:16 PM   #553
Smoker
BLACK BELT
Smoker's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 34
Flipped Off 13 Times in 12 Posts
Smoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on here
Yep.
Sebastian mentioned it, and I've been looking at all options.
First choice atm is an internal run, but I don't like the idea of drilling holes in the 1.5 inch tubing. Also some functional issues to work out.
The most difficult part of this project is that the bike is about 3,000 miles away from the custom swingarm.
Smoker is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-25-2020, 11:00 PM   #554
Smoker
BLACK BELT
Flip Offs: 34
Been working on brake line ideas again.
I only have the R6 arm to use for mockup.
Line will run basically like this. Will try to keep it close to the tubing.
Line will run to the inside of the swingarm, not outside.
Old Streetfighter Motorcycle Forum Post 01-25-2020, 11:21 PM   #555
Smoker
BLACK BELT
Flip Offs: 34
Brake line will run directly under the aluminum tubing and move to the inside of the arm forward of the tire.
Would like to put a dry break in this location. Need dimensions of the dry break & fittings, and need to figure out the best size to use.
Will also need 1 or 2 brackets for brake line anchors.
These people High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 01-26-2020, 01:11 AM   #556
Smoker
BLACK BELT
Flip Offs: 34
Looking at hydraulic dry break connectors.
One of the choices is bore size. Looks like the smallest size is 3mm bore.
Searched, but didn't find info on brake line bore sizes.
Grabbed a brake line and eyeballed the banjo bore size. Looks like 2mm, or less. Based on that, I'm guessing the 3mm bore dry break connector will work fine.
Any opinions?
Generic dry break photo:
Old Streetfighter Motorcycle Forum Post 01-26-2020, 05:42 AM   #557
Local Time: 12:35 AM
https://www.ebay.co.uk/itm/VENHILL-Q...8AAOSwC~Bb4Wso
they,re what I have
Old Streetfighter Motorcycle Forum Post 01-26-2020, 07:15 AM   #558
Smoker
BLACK BELT
Flip Offs: 34
Just posting a pic of the OEM rear master location.
Old Streetfighter Motorcycle Forum Post 01-26-2020, 07:43 AM   #559
Smoker
BLACK BELT
Flip Offs: 34
Originally Posted by yantosh View Post
Thanks.
Been looking at Staubli SPH/BA 03 type.
Venhill is a good name. Trying to avoid Made in China quality.
Old Streetfighter Motorcycle Forum Post 01-26-2020, 10:09 AM   #560
Hel stopped selling theirs because they leaked, venhill are good,Staubli make quality stuff
Thank you for viewing RZV500 Two-Stroke Roller in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - RZV500 Two-Stroke Roller on Custom Fighters Streetfighter Motorcycle Forum
