Frankie Honda. Street neo cafe fighter - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Frankie Honda. Street neo cafe fighter
Old Streetfighter Motorcycle Forum Post 08-13-2019, 04:22 PM   #1
luxuser
NoObie
Noobie
luxuser's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 08:07 AM
luxuser is a NOOB
Default Frankie Honda. Street neo cafe fighter
Hi guys. Im starting with a new project. I called it "Frankie".
Mostly it will be Honda. The frame comes from CB-1 Honda 89-90.
I fitted the Aprilia SXV 450/550 swingarm with rear wheel spindle. Fits perfectly (frame and swingarm are 215mm wide) but it need to make some new bushings (different axles diameters).
On this moment Frankie looking for a supermoto wheelz. Rear 5.5x17" and 3.5x17" front. Gold hubs and Black rims and spokes. My rear gold Talon hub comes from Husq 450rr.
In the next step I'll try to find and mount front end. Looking for CBR900rr forks, I like their massive look.
Wysłane z mojego moto g(6) plus przy użyciu Tapatalka
luxuser is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived luxuser!
Old Streetfighter Motorcycle Forum Post 08-13-2019, 04:24 PM   #2
luxuser
NoObie
Noobie
luxuser is a NOOB
https://r.tapatalk.com/shareLink?url...9&share_type=t
Old Streetfighter Motorcycle Forum Post 08-13-2019, 04:33 PM   #3
a_morti
Flip Offs: 24
Default Re: Frankie Honda. Street neo cafe fighter
Czsecsz! Or something like that.
I love the cb-1, here is my last one which I recently moved on to a good home.
https://www.therevcounter.co.uk/thre...-s-Second-CB-1
If you have any questions on what fits, I may know. Particularly if you're looking at RWU Fireblade forks, guess I can save you some time.
This user High Fived a_morti!
Old Streetfighter Motorcycle Forum Post 08-13-2019, 04:44 PM   #4
luxuser
NoObie
Noobie
luxuser is a NOOB
Man... Great timing
It'll be very helpfully.
But I've a few questions.
1. Brake rotors are 310mm or 296(298)?
2. What year are these forks?
3. Its stock 900rr rim or cbr600 f3?
Oh if You mean Polish "hi", then You should write "Cześć" hi5.
Actually i bought 900rr 98-99 triple clamps.
Old Streetfighter Motorcycle Forum Post 08-13-2019, 04:47 PM   #5
luxuser
NoObie
Noobie
luxuser is a NOOB
Discussion thread.
Old Streetfighter Motorcycle Forum Post 08-13-2019, 05:02 PM   #6
Streetfighterkz
Capt Oblivious
Streetfighterkz's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:07 AM
Flipped Off 11 Times in 7 Posts
Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!Streetfighterkz is an amazingly helpful member with a good attitude!
Im merging this thread and the discussion threads then moving them to the general projects section as the contest is over.
Later, Doug
74 Kawasaki H1-500 Project
76 Kawasaki Kz900 'Strip-fighter Project
77 Kawasaki Kz1000
78 Kawasaki Kz1000 Project
'80 Cx500 Cafe/Brat Project
83 Kawasaki Gpz750 (Turbo Converted) Project
Streetfighterkz is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 08-13-2019, 06:59 PM   #7
a_morti
Flip Offs: 24
98-99 triples are good because the lower is aluminium. The legs are 10mm wider apart than earlier types which may help you out with disc/caliper clearance when using laced wheels. If you're using 98-99 triples, means you need the same year spindle as it's 10mm longer than earlier models. However they're bad because the fork is 5mm nearer to the frame than stock, which I heard can give screwy handling. Idk how that plays out as I haven't tried it myself.
92-97 lower triple is steel which is bad, but the offset is correct for the cb-1. Also the the steering stops work 100%, and you only need to grind some metal off the top triple so the ignition lines up and even the steering lock works. But I wanted to use original speedometer, so had a CNC top yoke made.
I used 96-97 forks. They take 296mm discs which are fitted on an f3 wheel (actually nc29 but same). 96-97 has more adjustment than earlier types, but didn't go to 310mm discs which are harder to find. Depending on how you're doing it with laced wheels (one or two discs?), maybe an OEM cb-1 310mm disc can work for you with 98-99 forks.
Old Streetfighter Motorcycle Forum Post 08-14-2019, 10:34 AM   #8
Junkie
re-tarded
Local Time: 10:07 PM
Flip Offs: 3
with spoked wheels, I'm assuming (yeah...) you'll be using a hub from a dirtbike or SM. 320 will be the easiest size rotor to find in that case, and it'll only have a mounting provision for a single rotor. yes, there are exceptions (the big KTMs for example), but the overwhelming majority only have a single rotor.
given the power output of the CB1, if you put a good rotor (with plenty of meat and full floating, not the really skinny Warp9 I sometimes see), good caliper, good master the right size for said caliper, and good pads, it'll be plenty for spirited riding. Probably enough for trackdays even. Modern SMs make more than the ~50hp to the tire I'm seeing on a dyno sheet via google. Of course, in some cases there are clearance problems between the spokes and the caliper, so I'd advise doing some research before spending a bunch of money on a caliper - look at what the SM guys use, clearance is a big part of why. But maybe your forks are far enough apart that you can put a spacer between the wheel and rotor and not need to worry about that.
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 08-14-2019, 11:45 AM   #9
a_morti
Flip Offs: 24
Agree with all that ^
My tip assuming budget build is a single OEM CB-1 rotor because it's floating, thicker than most dual setup discs, and at 310mm it matches the 98-99 CBR900 forks which match his triples. Plus he might have one lying about. Would go together with a single Gold Nissin caliper from a 929/954 which works great with a 1/2" master cylinder from an f2 or f3, or from a 599 hornet if you want to use a mirror. Brembo master cylinders such as from a KTM also good, but don't always clear Honda switches.
I've had one CB-1 with twin gold nissin calipers on 296mm discs and it was over braked.
I've had one with a single Brembo goldline (basically same as that nissin) on stock CB-1 310mm disc and it worked great.
Old Streetfighter Motorcycle Forum Post 08-14-2019, 12:49 PM   #10
Junkie
re-tarded
Flip Offs: 3
I was just assuming that it'd be easier to deal with spacing a rotor out than it would be to make an adapter to mount a rotor to a different hub. I'd worry about having enough thread engagement with a rotor adapter unless it was awfully thick.
An EBC rotor for a Yamaha WR450 supermoto is $220ish on eBay, or a China rotor that looks decent is $120. Not saying that's the way to go, just an example. I imagine you can get rotors for other brands for similar prices.
Thank you for viewing Frankie Honda. Street neo cafe fighter in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Frankie Honda. Street neo cafe fighter on Custom Fighters Streetfighter Motorcycle Forum
