angled frame slugs - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > angled frame slugs
Old Streetfighter Motorcycle Forum Post 10-06-2019, 02:52 PM   #1
remfanuk
Senior Member
Fighter
Local Time: 04:37 AM
remfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to all
Default angled frame slugs
are there angled frame insert slugs out there folks? plenty of straight ones with differing diameters but wonder if there was like a 20 degree bend slug? cheers.
remfanuk is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-06-2019, 03:50 PM   #2
yantosh
Local Time: 09:37 AM
Flip Offs: 14
Default Re: angled frame slugs
reckon it,ll be straight slugs with the bend in the subframe
Old Streetfighter Motorcycle Forum Post 10-06-2019, 04:24 PM   #3
a_morti
Local Time: 10:37 AM
Flip Offs: 24
Would it be asking for trouble to get a straight one, cut it at an angle and weld the two halves as required? Like a piecut.
Old Streetfighter Motorcycle Forum Post 10-06-2019, 05:57 PM   #4
yantosh
Flip Offs: 14
just bend a bit of tube, weld one end to frame t,other to slug
Old Streetfighter Motorcycle Forum Post 10-07-2019, 02:20 PM   #5
remfanuk
Senior Member
Fighter
i did think the easiest solution would be to bend the tubing but thought i would ask the question. however, on that subject...would you guys advocate bending pipe at home. i am only looking at 20 degrees for instance and don't have a pipe bender. was thinking about the sand filled tube bending method or is that a bit too ghetto to be safe?
cheers lads.
Old Streetfighter Motorcycle Forum Post 10-07-2019, 02:31 PM   #6
shinyribs
Flip Offs: 58
As long as the tube doesn't get a kink in it you'll be fine. If it flattens a touch you'll still be fine provided it isn't a super critical piece.
OEM's never slug when they tee pieces of tubing together, like on a subframe.
Old Streetfighter Motorcycle Forum Post 10-07-2019, 02:52 PM   #7
remfanuk
Senior Member
Fighter
how has it become the go to option for custom subframes? my bandit seems to have like a twin wall construction on the tube coming away from the main spar for a few cm. i guess frame slugs are belt and braces?
Old Streetfighter Motorcycle Forum Post 10-07-2019, 03:55 PM   #8
yantosh
Flip Offs: 14
custom builders usually don.t have the software to stress test structures, just build it strong
Old Streetfighter Motorcycle Forum Post 10-07-2019, 06:48 PM   #9
sebwiers
lɐʇuǝɯᴉɹǝdxǝ
sebwiers's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:37 AM
Flip Offs: 21
Flipped Off 36 Times in 19 Posts
sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!sebwiers is an amazingly helpful member with a good attitude!
Using slugs also make it easier to align the parts and produce a welded part that looks like one solid piece (allowing you to safely grind the weld down). It may even be necessary for strength in some applications. I'd wager if converting a Hog to a hard tail, slugging the connections is a legit requirement; vibration could fatigue crack anything less.
It may just have passed on from there as "the right / best way to do it" even if overkill in most cases.
sebwiers is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived sebwiers!
Old Streetfighter Motorcycle Forum Post 10-07-2019, 08:59 PM   #10
beezwiz
Local Time: 03:37 AM
Flip Offs: 7
Flipped Off 15 Times in 9 Posts
beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!
Hardtail a Harley or Triumph using slugs at the welds for strength... same as when you rake or de-rake the frame in the frame down tubes. Not over-kill at all. Also as Sebwiers stated this method will allow you to safely grind down the welds for aesthetic reasons.
So for a sub-frame well... If your a big-un like myself, I would use slugs.
My .02
Beez
The best memories come from bad ideas done with best friends.
This user High Fived beezwiz!
Thank you for viewing angled frame slugs in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - angled frame slugs on Custom Fighters Streetfighter Motorcycle Forum
