3vvvfr Speziale by Boneheedio - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > CF Streetfighter Forum Contests > Streetfighter Buildoff > 2020 Winter Build-off > 2020 Winter Build-off Build Threads
2020 Winter Build-off Build Threads Only post here if you are the builder! Comments in the Discussion threads please.
CustomFighters.com Streetfighter Motorcycle Forum > 3vvvfr Speziale by Boneheedio
Old Streetfighter Motorcycle Forum Post 11-09-2019, 09:48 PM   #1
bonehead
Fucking Retard
Local Time: 03:32 AM
Flipped Off 5 Times in 3 Posts
bonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond reputebonehead has a reputation beyond repute
Default 3vvvfr Speziale by Boneheedio
I enjoyed and was very pleased with the bike that I built last year in the 2019 build off, so I am throwing my hat into the ring to have another go.
The bike.
The plan, throw a shed full parts at it and hope something sticks.
The shed.
And what would a build off be, without a VFR, best intentions to all
bonehead is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 12-02-2019, 03:21 AM   #2
bonehead
Fucking Retard
Default Re: 3vvvfr Speziale by Boneheedio
Looking (lacking) for motivation
These people High Fived bonehead!
Old Streetfighter Motorcycle Forum Post 01-13-2020, 04:18 AM   #3
bonehead
Fucking Retard
I am in substantial awe of a couple of builds currently underway here at CF........
Leroys T.L is coming on nicely and is going to look great,
Sebsmokers swingarm is setting the bar to a new even higher high,
awesome design, awesome concept, awesome workmanship
There's also a couple of other builds warming up for hopefully a most excellant finish.
And then there is mine.
Name:	CF WBO 20 2-2.jpg
So I pulled the motor outa this
Name:  CF WBO 20 2-3.jpg
Whilst they were side by side the light bulb went off!!
Name:  CF WBO 20 2-4.jpg
V8 rear wheel drive independent rear suspension
Still have a few issues to iron out, how to join the two frames together, oh and a front end, steering, seating, controls, getting the motors in sync so it wont spin in circles...etc etc
Minor details but maybe enough to get back in the runnung
Old Streetfighter Motorcycle Forum Post 01-13-2020, 04:35 AM   #4
bonehead
Fucking Retard
Who am I kidding.....
I just wanted some fancy new wheels and a braced swingarm
[ATTACH]107142[/ATTACH
Name:	CF WBO 20 3-2.jpg
might have to paint them white though
Old Streetfighter Motorcycle Forum Post 01-13-2020, 04:57 AM   #5
bonehead
Fucking Retard
So I put a 2014 gen 8 engine into a 2006 gen frame.
Name:  CF WBO 20 2-6.jpg
Name:  CF WBO 20 2-7.jpg
I'll use the 2006 gen 6 throttle bodies and ECM and see if it will work on the gen 8 motor.
The front wheel will need some spacers and fortunatelly the gen 8 wheel has 310mm rotors which are the same as the CBR1100xx rotors that I used on the gen 6 wheel.
Old Streetfighter Motorcycle Forum Post 01-19-2020, 04:19 AM   #6
bonehead
Fucking Retard
Drilled out the inner bearing race so the the larger CBR 954 axle can fit.
Put some bearings in and I have a new front wheel.
Name:	CF WBO 5-1.jpg
Gen 8 vfr motor has 3 neutral type switches for the gear indicator display
https://www.vfrdiscussion.com/upload...5c4bc99abd.JPG
I figure if I short then all together that they will one neutral light
Name:	CF WBO 5-2.jpg
Apart from the throttle bodies electrical connections, thats why I've used the original throttle bodies, the other electrical connections plug into the 6 gen loom.
The front sprocket on the 6 gen has the speedo drive and looks exactly the same as the 8 gen, thougt I would just make the speedo drive fit the newer sprocket cover...they look identical bar speedo drive......but they are not, pic pending.
I'll see if this things going to working before drilling out 8 gen cover.
Old Streetfighter Motorcycle Forum Post 02-02-2020, 05:00 AM   #7
bonehead
Fucking Retard
I got the 8 gen motor to start with the 6 gen wire harness, ecm, throttle bodies
....and it runs
It ticks over at idle and sounds ok, got a short video that I may up load
But......
After it had warmed up and I started to give it some berries it didn't sound right,
it would not rev cleanly above 9-10 thousand rpm's and when shifting up thru the gears it stalled between random shifts, particularly 5-6, I had all the neutrals shorted, I am guessing some timing changes between generations
Considered grafting the 8 gen wire harness and ecm onto this bike, but I would rather leave those two pieces of pie together for another possible project.and it has all this additional associated accessories, heated grips, self canceling indicators, ABS, traction control.
So I am calling it out of this years build off.... best of luck to all remaining.
Discovered coolant in the inlet of the previous motor...see new thread
cheers
This user High Fived bonehead!
Thank you for viewing 3vvvfr Speziale by Boneheedio in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - 3vvvfr Speziale by Boneheedio on Custom Fighters Streetfighter Motorcycle Forum
