A noobís 93gsxr build - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > A noobís 93gsxr build
Old Streetfighter Motorcycle Forum Post 11-24-2018, 02:40 PM   #1
93gsxr
Fighter In Training
Local Time: 01:56 AM
93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all93gsxr is a name known to all
Default A noobís 93gsxr build
Always wanted a streetfighter and just picked up a 93 gsxr. Not new to motorcycles but new to a streetfighter build.
It came with the following parts as extra:
- a second set of fairings
- 2 extra sets of carbs
- a second wiring harness
- a second exhaust pipe and header
- a second gas tank
- a second radiator
- a second cylinder head missing one valve
- a bunch of other stuff
It has been sitting for 1 and half years but was running before being parked. I will make sure to go through the
Beginnerís guide for whatís needed to get done but will probably need some help along the way.
This is going to be a slow build and the goal is:
- strip it down
- Remove the whole current subframe and build a shorty one seater setup
- riser and handle bars
- Possibly lift the whole bike (front and rear) just a little
I have a couple of questions
1- for riser handle bars, do I need or is it better to get a different triple tree?
2 - how can I lift the front of the bike?
3 - how can I lift the rear? Is it a matter of using a longer shock? Is so which one would you recommend?
4- for the subframe design I have in mind, I could use a flat seat. Suggestions?
5- should I look into replacing the rear swing arm with a braced one?
6- anything worth looking into while itís apart?
5- any other suggestions?
Any help is truly appreciated! Thanks!
93gsxr is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived 93gsxr!
Old Streetfighter Motorcycle Forum Post 12-01-2018, 03:21 AM   #2
Casper
The friendly Ghost.
Local Time: 11:56 PM
Flip Offs: 189
Default Re: A noobís 93gsxr build
Easiest to use generic risers that you bolt to newly drilled holes in the upper triple to give yourself a more upright position. Shouldn't be necessary to get a new triple tree.
Longer forks, not necessarily easy. Taller tire, farily easy if you're running something small.
I forget if this is a dog bone set up, in which case a shorter set will usually lift the rear. One of our GSXR folks should know better on this.
A little curve up in the back helps hold you on the bike... definitely up to you and how you plan on riding her.
No need unless you want the looks.
Worth while to clean everything and check for damaged parts so you have a baseline of what you're working with. If you can spare a hundred or so dollars, replace the bearings in the wheels, swingarm and steering stem. Check the rubber components of the fuel and air induction system. Replace your fluids and filters. Once you have her back together, ride the piss out of her.
Post LOTS of pictures!
Casper is online now   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 12-01-2018, 05:29 AM   #3
rex_saugerty
V four honda whore
Local Time: 09:56 AM
Flip Offs: 3
XR69 should be your inspiration
rex_saugerty is online now   Reply With Quote on our streetfighter motorcycle forum
This user High Fived rex_saugerty!
Old Streetfighter Motorcycle Forum Post 12-01-2018, 11:17 AM   #4
93gsxr
Fighter In Training
Thanks Casper!
Old Streetfighter Motorcycle Forum Post 12-01-2018, 11:20 AM   #5
93gsxr
Fighter In Training
The XR69 looks great indeed but Iím thinking about going for a bare bone strictly necessary look.
Old Streetfighter Motorcycle Forum Post 12-01-2018, 01:16 PM   #6
rex_saugerty
V four honda whore
Flip Offs: 3
Kinda like guy martins martek?
Old Streetfighter Motorcycle Forum Post 12-02-2018, 09:12 AM   #7
93gsxr
Fighter In Training
Kinda, but not as complexe.
Old Streetfighter Motorcycle Forum Post 12-06-2018, 08:33 PM   #8
93gsxr
Fighter In Training
Started taking the bike apart and seeing what I would need. Will post pics later.
Apologies for the noob questions below.
1- where do I find a good set of new left and right throttle assembly that will fit.
2- what newer rear shock with integrated expansion chamber would filt?
3- recommendation for risers?
4- recommendation for handlebars?
5- what special tool (and size) do I need to remove the swing arm and top triple tree?
6- which extended front brake line is a direct fit?
As always, thank you for any help!
Old Streetfighter Motorcycle Forum Post 12-07-2018, 12:24 AM   #9
Casper
The friendly Ghost.
Flip Offs: 189
Ebay is the easiest place to source parts, you can get your model specific versions or many other handlebar controls are easily adapted to work with a little wiring work.
I use a set of ebay specials for $30 and they have been sufficient, I just had to drill the triple to install them. You can go very fancy and have a set machined or go on the cheap.
BikeMaster makes steel bars for $30 with many different bends, I have been through several of them and they held up to a crash well enough to ride home everytime.
A drift and a hammer to remove the castle nut or make a castle nut socket using a massive socket and an angle grinder (or file) and patience. I have used the hammer and drift method many times without ill effects other than slight marring on the castle nut faces.
If you have a local hydraulic equipment supplier near you, I would go ask them how much it would cost to get a set of pvc coated stainless braided brake lines crimped to your specs. A local shop did mine for $30 each with my desired banjo fittings, angles and length.
Hopefully someone with more specific knowledge of your year GSXR comes in and answers with units from specific models.
Old Streetfighter Motorcycle Forum Post 12-07-2018, 01:48 PM   #10
ROBBO
MAJOR FOOKIN' CATASTROPHY
Flip Offs: 643
Good man Casper ! Reps for you matey .
ROBBO' 2009
These people High Fived ROBBO!
Thank you for viewing A noobís 93gsxr build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - A noobís 93gsxr build on Custom Fighters Streetfighter Motorcycle Forum
