I know people on here have set it up but for some of us electrically retarded people like me simple things can turn into nightmares. If any of you electrical gurus would like to throw up how you set it up I would be forever thankful.
^^ like he said just bust out the DMM and measure each one of the lines for voltage when the key is turned on and then you will know what you need. I'm totally doing this to my 01 r6 I cant wait to convince people I'm magically turning on my bike!
So i set it all up like my picture showed except with a 100ohm resistor between the O/Y wire and the yellow wire and it works! Ill see if i can post a video when i figure out how to hold my camera, pull in my clutch, and push the starter button all at the same time. Thanks for all the help guys
Yeah I just kind of forgot about that. Ill see if I can get it up soon sorry. Also since both the transponder and the switch are sitting on my engine what would be a good thing to use to protect them from the heat?
I'll be doing mine next week for spring break and I just want to make sure the parts list only consists of the reader unit and the solid state latch correct?
Really like where this is going - I'll probably do something similar myself, to try and get rid of the non-working key.
Is there anyway to improve the RFID range, so that it works more like a Smart Key (perhaps it's not even RFID technology at this point)?
My car has the smart key and I can start with the key just inside the car - Maybe they have a huge antenna?
they make them but in order to get that type of range out of the rfid the price goes way up. so must just use the ones that don't have very much range.
Just in case you didn't read the product description "But really guys, it's not for use inside your body. Please don't implant this thing into yourselves."
But hey I'm all for you sticking it in your body somewhere! Let me know how that works out for you.
Ya I saw that too but I really think it is just something to cover their asses. Plus to try to make this thing approved for implantation would be 10X the price of the actual unit. I'll let everyone know how it goes! Should be interesting!
10mm is a pretty short distance for the implantable fob, but it's pretty cheap, so I guess you can just test it out before your dad implants it in you. Please post video if you go through with it.
there was a guy on the news here recently that has one in his hand, he has his house and car rigged up so he no longer has to carry keys to any thing.
im having trouble just getting my readers to work, i can wire them up, the LED flashes when the fob is passed but the relay wont switch. im not sure if its the relay needs more current than the reader is putting out or what. Im going to give it another try with a different relay and see what happens. its a brand new relay though so it should work!!
Thanks for all of the replies guys!! But ya the procedure was pretty custom and unfourunately makes it much more difficult for others to replicate because going to a get the procedure specifically meant for it would not be too cheap or easy to find. Second I don't even know where one would go about getting a "for human implantation" RFID chip and I'm sure it would cost a bit more than $5.
But ya all in the name of being unique!
Well I think the main difference would be that the one meant for implantation would come sterile. And that is another thing that I am curious about as well. I squeezed the chip pretty firmly before it was implanted just to make sure it was not damaged or the integrity of the glass compromised after autoclaving, so far so good!
Thought about this one as well but I would really really recommended against it. Those chips are coated in "bio-glass". What this means is that over time your cells will bond to the chip and prevent it from moving. However, this coating has been linked to several cases of pet cancers and if you ever want it removed expect to remove a whole big chunk of tissues along with it. By putting it in a place that does not give it much of a chance to move around, such as the wrist or the area between your thumb and pointer finger, eliminates the need for bio glass. Oh and pet sterilization is far from that of human sterilization so thats another no no for the pet chip.
Related Threads
1.6M posts
40.4K members
Since 2006
