What would you do? - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > What would you do?
Old Streetfighter Motorcycle Forum Post 10-24-2019, 12:11 PM   #1
remfanuk
Senior Member
Fighter
Local Time: 12:18 AM
remfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to allremfanuk is a name known to all
Default What would you do?
So i have a mk2 bandit 1200 frame and tank and will be fitting the pretty common ducati monster/evo1098 seat unit. There will be a new welded in subframe at some point also.
I have been advised to make a "goalpost" type bridge at the back of the tank so that the seat lugs can be secured at the front of the seat. The seat is a bit narrower than the rear of the tank.
So...do i taps some calculated dents into the tank to allow the front of th seat to be closer to the rear of the tank or somehow trim away and possibly bollocks up the plastic seat?
Sent from my SM-G960F using Tapatalk
remfanuk is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-24-2019, 12:52 PM   #2
Junkie
re-tarded
Local Time: 09:18 PM
Flip Offs: 3
Default Re: What would you do?
I'd probably cut the tabs that stick forward off the front of the seat. I bet if you do that, the seat can be stretched to fit around the tank.
Old Streetfighter Motorcycle Forum Post 10-24-2019, 01:20 PM   #3
remfanuk
Senior Member
Fighter
i think that would definitely sort it...not sure how i would mount the front of the seat to the frame then.
Old Streetfighter Motorcycle Forum Post 10-24-2019, 02:23 PM   #4
yantosh
Local Time: 06:18 AM
Flip Offs: 14
just trim them enough, may be enough left to still secure the seat, if not,work out something
Old Streetfighter Motorcycle Forum Post 10-24-2019, 03:06 PM   #5
remfanuk
Senior Member
Fighter
Its the work out something else i aint too hot on...desparate not to fuck the seat...will see when i get the subby on.
Old Streetfighter Motorcycle Forum Post 10-24-2019, 03:18 PM   #6
yantosh
Flip Offs: 14
https://www.customfighters.com/forum...t=63165&page=5
drop seat front
Old Streetfighter Motorcycle Forum Post 10-24-2019, 05:03 PM   #7
titan
hooligan quads
titan's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 3
Flipped Off 14 Times in 2 Posts
titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!
Originally Posted by yantosh View Post
oh bandikat thread, in for a re-read, evenings entertainment sorted
ride it like you stole it
Customization not Restoration
Originally Posted by Albert Einstein
I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.
H Designs
2020 build off - build - chat
titan is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived titan!
Old Streetfighter Motorcycle Forum Post 10-25-2019, 02:53 AM   #8
remfanuk
Senior Member
Fighter
By angling the seat rear upwards it does lessen the gap at the front...so that will help. Have to see what would be gained through trimming the tabs. I have had the bandikat thread open for a few days now...will look to see how you did your seat Yan. Thanks.
wondering whether it is viable/safe to maybe screw a couple of L brackets to the front sides of the seat from underneath that could bolt to the insides of the top frame rails? Or will the ABS plastic not be sufficiently strong to take a bracket being screwed to it?
Old Streetfighter Motorcycle Forum Post 10-25-2019, 06:29 AM   #9
a_morti
Local Time: 07:18 AM
Flip Offs: 24
If you knock the tank, you'll let off any plating on the inside and may open yourself up to it rusting from the inside out.
I'd modify the seat.
These people High Fived a_morti!
Old Streetfighter Motorcycle Forum Post 10-25-2019, 06:33 AM   #10
remfanuk
Senior Member
Fighter
Good point. Will re-evaluate when the subby done
Thank you for viewing What would you do? in the Heavy Metal section of our streetfighter motorcycle forum. I hope you found it useful!
Heavy Metal - What would you do? on Custom Fighters Streetfighter Motorcycle Forum
