GPX600R - 90 no spark on cyl. 1 & 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > Streetfighter Help Needed!
Streetfighter Help Needed! Need help with your 'fighter? Ask for help in here!
CustomFighters.com Streetfighter Motorcycle Forum > GPX600R - 90 no spark on cyl. 1 & 4
Old Streetfighter Motorcycle Forum Post 07-17-2020, 11:33 AM   #1
jonnywestin
Local Time: 12:43 AM
jonnywestin is a NOOB
Default GPX600R - 90 no spark on cyl. 1 & 4
Hi all.
I was wondering if anyone of you could help me.
I got a Kawasaki GPX600R - 90 that only has spark on cylinder 2 & 3 (right side ignition coil)
If I change the leads going to ignition coil 1 to coil 2 the other stops working and give no sparks on cylinder 2 & 3.
Meassured values in resistance on primary is within limits according to Haynes.
Also the resistance on pickup coils is within limits.
I have all sparkplugs new and the same model.
I swapped IC igniter, ignition coil and the pickup coils from another bike, but the problem is the same even with parts from my other bike.
Has anyone a clue why I don't get a spark on cylinder 1 & 4?
Wire diagram in link below
https://imgur.com/LhGMaEp
Thank you in advance.
/// Jonny
jonnywestin is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-17-2020, 03:02 PM   #2
XxGRYMMxX
Breaking shit...
XxGRYMMxX's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:43 AM
Flip Offs: 8
Flipped Off 13 Times in 10 Posts
XxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on here
Default Re: GPX600R - 90 no spark on cyl. 1 & 4
have you verified that there is power present at each coil with the ignition on? looks like they share a power source so if you check, and theres only power on one, follow the dead one back toward where it splices and look for a broken/chafed/burnt/etc wire. if both have power, then youll need to check the wiring between the IC Ign and the coils. this is the ground side of the circuit. coils are powered full time with the ignition on and use ground pulses to collapse their field and induce current into the secondary coil. the ground circ should pulse a ground signal while cranking/running. check those and report back if necessary.
They can ban, outlaw, and restrict whatever they please. I'll keep doing whatever the fuck I'm doing, because I don't really give a shit. The only thing that will change is that I'll be breaking their made up bullshit rules while doing it, and I'm comfortable with that.
My Build http://www.customfighters.com/forums...d.php?t=118649
XxGRYMMxX is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 07-22-2020, 04:10 PM   #3
RTharalson
Old, Bold Rider
RTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to allRTharalson is a name known to all
According to the wiring diagram the only difference between the circuitry for coils 1/4 and 2/3 is the tachometer is driven by the 1/4 coil circuit. There may be a problem with the tach circuit which is somehow affecting the trigger signal to that coil. To check unplug the instruments and give it another go.
Hopefully it's that simple.
Good luck.
Rob
RTharalson is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived RTharalson!
Tags
gpx, gpx600r, ignition, no spark
Thank you for viewing GPX600R - 90 no spark on cyl. 1 & 4 in the Streetfighter Help Needed! section of our streetfighter motorcycle forum. I hope you found it useful!
Streetfighter Help Needed! - GPX600R - 90 no spark on cyl. 1 & 4 on Custom Fighters Streetfighter Motorcycle Forum
