Eeeeeeeeee FE - Page 42 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Eeeeeeeeee FE
Old Streetfighter Motorcycle Forum Post 08-26-2020, 07:28 AM   #411
370steve
old fart
Local Time: 07:29 AM
Flip Offs: 33
Default Re: Eeeeeeeeee FE
more pics from Ralph at Component Engineering, swing arm and rear wheel spindles done,
hoping to to finish off the front wheel spindle today and get them in the post.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-26-2020, 08:47 AM   #412
370steve
old fart
Flip Offs: 33
as i have a set of Gilles paddock stand lifters and crash bungs left over from the TL1000R swing arm change, i will be looking at making an adaptor bracket so i can fit them to the new Martek arm, waste not, want not lol
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-26-2020, 09:52 AM   #413
370steve
old fart
Flip Offs: 33
job job'd
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-27-2020, 06:41 AM   #414
MDM
Procrastinator
Local Time: 01:29 AM
Flip Offs: 3
Given the expense and effort gone towards reducing unsprung weight with the titanium spindles, why put some of that weight back on with the paddock stand parts? It seems something of a retrograde step to me?...
This user High Fived MDM!
Old Streetfighter Motorcycle Forum Post 08-27-2020, 07:12 AM   #415
370steve
old fart
Flip Offs: 33
wasnt all about reducing weight overall, but definitely was about the wheel spindle, i just did the rest at the same time.
saved a total of 3.07Lb so the addition of a few grams from the paddock stand lifters (which i wanted anyway) wont be a big deal.
i was wanting the Martek paddock stand lifters, but i think i will be saving weight/matching over them with the Gilles lifters when you see how "sturdy" the Martek ones are!!
if Mark sends me some i can always compare them for weight.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-27-2020, 12:07 PM   #416
370steve
old fart
Flip Offs: 33
spent a little time shoving bits back together again to check fitment if new bits.
fitted wheel & swing arm spindle, fitted spot on. wheel still needs to move 5mm (machining of wheel spacer required) to the left for 100% wheel centering and sprocket/chain run.
had a test fit of m-unit and Ignitech, happy with their placement, fitted hose to catch tank breather outlet.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 09-01-2020, 12:52 PM   #417
370steve
old fart
Flip Offs: 33
went to work on fitting the Gilles GP paddock stand lifters and crash bungs
made a cardboard template, transferred the dimensions onto a piece of 8mm alloy plate, which i have drilled and
ruff fitted, needs more shaping yet before being a full blown "pattern" for making out of some strong alloy, as the stuff i have used is soft as shite!!
then will get them anodized black to match the lifters.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 09-02-2020, 08:25 AM   #418
370steve
old fart
Flip Offs: 33
slight bit more work done on the paddock stand lifter bracket, removed some metal, shaped a little more to the swing arm outline, smoothed off few of the edges.
need to do some radius work on couple of the corners yet.
but i think it is getting there *
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 09-03-2020, 04:10 AM   #419
370steve
old fart
Flip Offs: 33
having sat and thought about it, MDM was correct, the idea i was using was overly complicated, i needed to simplify things which would also make it neater, there was two ways to go.
1) drill swing arm and fit Gilles lifters
2) find some other lifters, that will fit the mountings on the swing arm!
I went for a look see on the web, found all sorts, but none seemed to fit the bill, then came across these fine lifters of rather good breeding and pedigree, they also have the same mounting hole center measurements as the holes on the swing arm. ordered a set but in black anodize.
see how we get on with these.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 09-03-2020, 12:03 PM   #420
370steve
old fart
Flip Offs: 33
thanks to Nick at SPS (suzuki Performance Spares) for the swift service, i received the throttle spring that i needed to finish off the throttle conversion
on my TMR's.
just a few small things to do, like dust caps on the throttle bar end openings, throttle stop screw and "bench"balance.
SHIT HAPPENS!!!!!
Thank you for viewing Eeeeeeeeee FE in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Eeeeeeeeee FE on Custom Fighters Streetfighter Motorcycle Forum
