SUKATI....until i get a better name - Page 23 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > SUKATI....until i get a better name
Old Streetfighter Motorcycle Forum Post 05-22-2020, 01:37 AM   #221
yantosh
Local Time: 04:26 PM
Flip Offs: 14
ohhhh...its a bit fixed... lets try again
water hoses.... i,ll see your SAMCO and raise you some loominum
Old Streetfighter Motorcycle Forum Post 05-22-2020, 02:22 PM   #222
yantosh
Flip Offs: 14
if I click on the unavailable pics it takes me to them in photobucket, this work for anyone else, or just me?
Old Streetfighter Motorcycle Forum Post 05-22-2020, 06:02 PM   #223
yantosh
Flip Offs: 14
spent ages cutting pie today
then found the hose off my GSXR that nearly fitted, the bit of ally tube you can see will be replaced with the temp sensor, the front part has still to be finalised
there have been, and still are, far better weldors than me on here, but this is my build and the only way i,ll get better is to do it , so while this isn,t the prettiest pipe .... its mine ... and the full set of headers will prob owe me 50
clears frame and engine
front pipe needs some assembley
Coco nipped into Hel and picked up a rear brake line
routed quite nice
Old Streetfighter Motorcycle Forum Post 05-23-2020, 10:55 AM   #224
yantosh
Flip Offs: 14
front header weldimicated
nice n snug
now to get them both to a 2 into 1 position
after coffee
Old Streetfighter Motorcycle Forum Post 05-24-2020, 12:45 PM   #225
yantosh
Flip Offs: 14
front pipe extended to link pipe area
rear pipe too
peek a boo
two slip ons are tacked together
i,ll get the top of them flattened and set about making the link pipe
started on the water pipe, then run out of gas, gas not been lasting long as it should, put new bottle in and i hear a hiss....think regulator cracked, no more welding till I replace it
Old Streetfighter Motorcycle Forum Post 05-25-2020, 04:04 PM   #226
yantosh
Flip Offs: 14
think we got this now, been hours and nothing has lifted , ready for resin tomorrow after work
think my toddler levels of patience were the root of my issues
skinned the second attempt while i was at it, and started a glass one to send to Murica
the tank panels in the background are being modified too....but thats for another day
Old Streetfighter Motorcycle Forum Post 05-26-2020, 05:34 PM   #227
yantosh
Flip Offs: 14
glass one popped out the mould, mould has a little damage and gel coat sticks, i sort it out
kevlar stuck fine now , will need a few more coats of resin and much rubbing, but itll work
new regulator but food delivery to the oldies tonight, so no time to fit
springs arrived, but the 4 packs of two were four packs of one ...arseholes.... messaged them, no joy then ebay will be messaged
mocked up the number board graphics
Old Streetfighter Motorcycle Forum Post 05-27-2020, 03:19 PM   #228
yantosh
Flip Offs: 14
had the option to use a plastic moulded temp sensor housing......or make a bit of an effort
i like mine better
better than a simple joining piece
left hand water pipe done and fitted , minus clips
cut out a bracket
temp display will stick to it
after its welded here abouts
nearly got the left hand water pipe done, but left one end of the ally pipe a couple of mm too big in dia
cut off and fix tomorow
Old Streetfighter Motorcycle Forum Post 05-28-2020, 03:13 PM   #229
yantosh
Flip Offs: 14
fixed the water pipe, but to be fair its as ugly as sin , this one proves a point, but i,ll weld up another later
got the little recessed areas skinned in carbon , i will be fitting led,s in the holes for indicators
got an old indicators lens to chop up and glue in place
the clutch actuator looks like it should have a cover on it.... I didn,t have one ... I do now
i,ll make up a pin spanner to tighten it
pop it on
and all the way from the U S of A ...... cheers Mcanter , the right hand inner panel
Old Streetfighter Motorcycle Forum Post 05-29-2020, 04:21 PM   #230
yantosh
Flip Offs: 14
evenin peeps,
on reflection , the actuator cover needs work, looks like a 1990,s billet tax disc holder...... i,ll sort it next week
this pic of the side pod wouldn't load last night
you,ll no doubt all be glad to hear ( alternatively, you might not give a toot cah hoot) but i finished wet rubbing the bodywork, so these be the last pics of it till clearcoat
i cheated with the pics, bucket of water just out of sight
made a start on the 2 into 1 collector too
tomorrows list is written , see y,all in the morn
Thank you for viewing SUKATI....until i get a better name in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - SUKATI....until i get a better name on Custom Fighters Streetfighter Motorcycle Forum
