SUKATI....until i get a better name - Page 27 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > SUKATI....until i get a better name
Old Streetfighter Motorcycle Forum Post 07-04-2020, 01:43 PM   #261
Cookie2000ad
Persuasion Engineered
Cookie2000ad's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 03:25 PM
Flip Offs: 166
Flipped Off 59 Times in 27 Posts
Cookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CKCookie2000ad must be ROBBO or CK
Default Medal Burnout Contest Winner Fighter of the Month
Default Re: SUKATI....until i get a better name
Originally Posted by yantosh View Post
spring hooks arrived
That's smart! I bent all mine by hand like a f'in mug.
Cookie2000ad is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 07-04-2020, 02:38 PM   #262
yantosh
Flip Offs: 14
chain is good , already annealed
time to get a grip ..... nice n cheap too
spring is in the air
lambda boss in place
exhaust all welded up
started pulling bike to bits too
Old Streetfighter Motorcycle Forum Post 07-06-2020, 03:52 PM   #263
yantosh
Flip Offs: 14
had a proper busy day , really wasn,t in the mood for bike work.... so off to the shed I went anyway
got a pair of oil lines made up, will have them crimped properly
can,t properly fit them as the engine needs drilled and tapped once back out the frame
Old Streetfighter Motorcycle Forum Post 07-12-2020, 03:49 PM   #264
yantosh
Flip Offs: 14
started today with the card tube from a toilet roll
chopped it into two sections, coated with tape and wax
if these were going to be visible i would have moulded around the form and glue on, but they are hidden, so went for a much larger contact area , not as pretty, but strong and will do the job
also on the other side there was a sizable piece of damage that could be covered with the aramid fibre
IAT sensor was removed from the airbox i bought and mounted on a bracket
MAP sensor too
started the strip down in earnest, loading the box my wifes new hoover arrived in with pieces of Hypertard
(not sexist, it,s her hoover, she bought it )
started rubbing the paint off of the water pump housing, get it to match the clutch cover
back to skinny again
stop there until i check the fit of the front coil with its modified bracket, noticed last night that the HT lead was stopping full opening of the TB,s
Old Streetfighter Motorcycle Forum Post 07-13-2020, 03:50 PM   #265
yantosh
Flip Offs: 14
looks like a perfectly safe setup to me ....
and BOOM..... its in bits
Old Streetfighter Motorcycle Forum Post 07-14-2020, 04:02 PM   #266
yantosh
Flip Offs: 14
a little steel tube
and a hole
tube in the hole
just needs a little silver solder then its ready for powder
Old Streetfighter Motorcycle Forum Post 07-18-2020, 11:38 AM   #267
yantosh
Flip Offs: 14
a no pics update, seat is now in Devon for re-covering, carbon panels are in Edinburgh for clear coat
normal service ,ie. with pictures, will be resumed shortly
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 07-19-2020, 12:41 PM   #268
yantosh
Flip Offs: 14
frame done, ready for powder
Old Streetfighter Motorcycle Forum Post 07-22-2020, 01:10 PM   #269
yantosh
Flip Offs: 14
i take no credit for this at all
its pretty cool tho
lines crimped and nice new pots waiting for when I find a set of master cylinders
Old Streetfighter Motorcycle Forum Post 07-25-2020, 04:48 PM   #270
yantosh
Flip Offs: 14
been to the powder coaters n dropped my stuff off, matte bronze for engine covers and anthracite for the frame
but thats something else thats out of my hands
so off to the shed
fans were looking a bit scabby, so rubbed down and painted
the fins on the rad are a bit ropey, I can get a new one for 90 bangers , but i,ll give this one a chance
got the tiger bond out and glued the inner tank panel cover thingies on
and since the tiger bond was out figured i,d cobble together the indicators
yes they are a wee bit rough, but they will get tidied up and be fabulous , but on the plus side, they do light up (pulled the 9v battery from my scales to try them
engine is back in the engine room at bike shop, i,ll pull it apart and reacquaint it withe parts washer next week
Thank you for viewing SUKATI....until i get a better name in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - SUKATI....until i get a better name on Custom Fighters Streetfighter Motorcycle Forum
