throttle cable question. - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Streetfighter Motorcycle Discussion > General Streetfighter Discussion
General Streetfighter Discussion Discussions about streetfighter riding.
CustomFighters.com Streetfighter Motorcycle Forum > throttle cable question.
Old Streetfighter Motorcycle Forum Post 04-24-2019, 09:55 AM   #1
rabies
time is running out......
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:58 PM
Flip Offs: 1,382
Flipped Off 37 Times in 33 Posts
rabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to all
Default throttle cable question.
i have a 78 kz650.
2 throttle cables. push/pull
can I rig it up to use a mini bike throttle cable(single cable)
is there a way to convert it to single cable?
carbs do have a heavy spring that flips back so idk why I couldn't. idk
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-24-2019, 10:38 AM   #2
Local Time: 12:58 PM
Junkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to all
Default Re: throttle cable question.
it's fairly common to convert push/pull to pull only
Bikes: naked SV1000 with all the possible bling, WR450SM street legal, 450XCF SM trackbike
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 04-24-2019, 12:52 PM   #3
rabies
Flip Offs: 1,382
so just buy one of those universal minibike throttle cable and twisty dealy at the handbars?
rig it to pull only? massive spring on carb pulls it back? simple enough. why didn't they do that junk from factory?
Old Streetfighter Motorcycle Forum Post 04-24-2019, 01:12 PM   #4
Local Time: 03:58 PM
Flipped Off 116 Times in 103 Posts
I reckon it eliminates any chance of a stuck throttle since you have the "push" cable to back you up.
Any reason you want a single cable over push/pull? Lots of those old bikes had helacious return springs that would wear you out. No worries putting on a light spring with a push/pull setup.
Old Streetfighter Motorcycle Forum Post 04-24-2019, 01:20 PM   #5
rabies
Flip Offs: 1,382
less "stuff"
lighter.
my cables broke
my hand twisty is garb
Old Streetfighter Motorcycle Forum Post 04-24-2019, 01:57 PM   #6
you might need a custom cable due to the difference between mounting it on your stock throttle tube housing vs the mini bike one but that's about it
Old Streetfighter Motorcycle Forum Post 04-24-2019, 02:19 PM   #7
rabies
Flip Offs: 1,382
yea I figured. I bought something with a cable. might have to rig a dif spring up on the carb.
Old Streetfighter Motorcycle Forum Post 04-24-2019, 07:35 PM   #8
There is some math involed to get it right.. Stroke.. Diameter.. Degree of twist etc... So.. Best find out what you need then go from there
Mongoose is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-24-2019, 09:45 PM   #9
beezwiz
beezwiz's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flipped Off 14 Times in 8 Posts
beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!beezwiz is an amazingly helpful member with a good attitude!
Google "Motion Pro" they make cables for anything.
You learn a lot about people... when they don't get what they want.
beezwiz is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 04-24-2019, 10:32 PM   #10
Local Time: 01:58 PM
I put a Motion Pro Revolver on one of my bikes. Works pretty well, the cam thing is neat, can be had for relatively cheap on ebay.
I couldn't get both cables to lay right and it kept binding halfway through closing, so I took the closing cable out. Works fine without it.
Thank you for viewing throttle cable question. in the General Streetfighter Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
General Streetfighter Discussion - throttle cable question. on Custom Fighters Streetfighter Motorcycle Forum
