GOLDEN TRASH 78 KZ650 - Page 5 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > GOLDEN TRASH 78 KZ650
Old Streetfighter Motorcycle Forum Post 05-17-2019, 12:45 PM   #41
rabies
time is running out......
rabies's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 02:17 PM
Flip Offs: 1,382
Flipped Off 37 Times in 33 Posts
rabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to allrabies is a name known to all
Default Re: GOLDEN TRASH 78 KZ650
i see what you mean. so the rectifier casing itself needs grounded? if so il note that and sand
down the grounding contact area
rabies is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-17-2019, 01:16 PM   #42
Local Time: 12:17 PM
Junkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to all
I don't know, but there needs to be some way for it to ground and I don't see any other options.
the RRs I remember using have all been 5 wire (3 phase in, + out, ground)
Bikes: naked SV1000 with all the possible bling, WR450SM street legal, 450XCF SM trackbike
Old Streetfighter Motorcycle Forum Post 05-20-2019, 09:47 AM   #43
rabies
Flip Offs: 1,382
still undecided on the shock/seat setup.
I do know that I don't like all the frameage in the back.
need longer shocks and weld top bolt at lower angle or mono/Siamese.
will weld a brace and go from there.
about to buy a ninja 250 swingarm setup(it fits old KZ bike easy)
if I remember right its a tad longer. disc brake wider tire. and mono shock mounts.
I like wire wheels but these are junk. tire is too skinny.
anyways........................................... ...
pods for air/fuel mixy thingies
tank is coming along nicely........
mono shocketa brace?
crude temporary fender (swingarm is temporary)
what is contact patch for 200 alex
I keep snipping away at the seat hoping magically it will just be perfect one night.
I have this café racer rear subframe with taillight thing. waiting on swing arm setup to get decided on so I can start chopping rear.
Old Streetfighter Motorcycle Forum Post 05-20-2019, 09:53 AM   #44
rabies
Flip Offs: 1,382
kinda ish.
not so much the vintage aspect
Old Streetfighter Motorcycle Forum Post 05-21-2019, 09:41 AM   #45
rabies
Flip Offs: 1,382
Default wiring journey
i would say my wiring journey is going well just questions I need answered if anyone can halp.
POINTS: has 2 wires. green and black.
#1. does it matter what side of coils goes to what color?
#2. if 2 wires. what is the blue wire? goes to a sensor behind points thingy.
#3. toggle on button has 3 wires. 1 for points. 1 for rectifier. and 1 for??? and how do I know what toggle wire to use?
on with the low buck amateur show...
look worn??? by dyna stuff?
what is this???
I think I'm doing this right
going off of this wire diagram. use capacitor? where do I wire that in?
fancy toggle
has 3 wires though.
Old Streetfighter Motorcycle Forum Post 05-21-2019, 09:45 AM   #46
rabies
Flip Offs: 1,382
Default Carbs
seller sold me cracked boots. when I even asked if they were cracked.
heavy carbs sagged would crack anyboot.
so I made a carb cane.....lol
...and I cut this *only need to buy a proper welder though..irritating*
Old Streetfighter Motorcycle Forum Post 05-21-2019, 11:18 AM   #47
Default Re: wiring journey
#1) It will make a difference. You can test easy enough once it’s all together. Get ot wrong and cylinder 1&4 will fire when 2&3 should (180° off). Easy enough to swap the wires though.
#2) The blue wire goes to the oil pressure sending unit. From what I remember it is normally closed and opens under pressure.
#3) I don’t know what you’re using the toggle for? Main shut-off switch? Any diagram come with it?
‘74 Kawasaki H1-500
‘76 Kawasaki Kz900 Stripfighter
‘78 Kawasaki Kz1000
‘83 Kawasaki Gpz750 (Turbo Converted)
Streetfighterkz is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-21-2019, 12:03 PM   #48
rabies
Flip Offs: 1,382
cool. easy enough.
do I need that blue wire? its just a sensor? I have no gauges.
no dagram for it. it is the "on-kill" switch. its not momentary.
Old Streetfighter Motorcycle Forum Post 05-23-2019, 10:09 AM   #49
rabies
Flip Offs: 1,382
worked on the seat the other day. not much done.
I think I don't want a cushion..
and tank filler cap came in. need to cut a larger hole for it to fit in.
is there a fuel friendly putting I can under the lip of this filler thing?
plumbers putty fails when touchs fuel?
waiting on a wiring pan. got a strange idea. but would fit nice.
Thank you for viewing GOLDEN TRASH 78 KZ650 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - GOLDEN TRASH 78 KZ650 on Custom Fighters Streetfighter Motorcycle Forum
