Name This Wiring Terminal - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Technical Section > Electrical and Lights
Electrical and Lights Anything related to the fabrication of lights and other electrical components goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Name This Wiring Terminal
Old Streetfighter Motorcycle Forum Post 10-20-2019, 12:36 PM   #1
Smoker
BLACK BELT
Smoker's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 01:37 PM
Flip Offs: 36
Flipped Off 13 Times in 12 Posts
Smoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on hereSmoker spends too much time on here
Default Name This Wiring Terminal
Just a longshot.
Hoping someone might know what type of terminal this is.
Can't find it anywhere. OEM terminal on the RZ350 Neutral Sensor. Grips tightly onto a 4mm bolt. I think the ring is split so the bolt doesn't have to be removed to install the wire.
May have to find an appropriate ring connector and cut it myself. Or, reuse this cooked terminal.
Smoker is online now   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 10-20-2019, 12:52 PM   #2
Local Time: 03:37 PM
Default Re: Name This Wiring Terminal
It’s called a “fork ring terminal”. Go to EasternBeaver.com then Motorcycle Electrical Products > Terminals > 1/4-1/3 way down. They have them for M4, M5 and M6 bolts.
‘74 Kawasaki H1-500 Project
‘76 Kawasaki Kz900 'Strip-fighter Project
‘78 Kawasaki Kz1000 Project
'80 Cx500 Cafe/Brat Project
‘83 Kawasaki Gpz750 (Turbo Converted) Project
Streetfighterkz is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Streetfighterkz!
Old Streetfighter Motorcycle Forum Post 10-20-2019, 04:33 PM   #3
Smoker
BLACK BELT
Flip Offs: 36
Thanks, Doug. I'm amazed.
When I search for "fork ring terminal," there are zero results.
When I search all terminals, I don't see them anywhere.
Website says they're made by Mitsubishi and Hero in Japan. Trying to figure out if there's another name for them.
The hole size on my OEM piece is 3.5mm. Holds tight on 3.8mm threads. Maybe I need a 3mm size terminal.
Website says 6mm terminal has 6.4mm hole. Website says 4mm terminal has 6.4mm hole. Hard to figure out the sizing.
Old Streetfighter Motorcycle Forum Post 10-20-2019, 10:08 PM   #4
Larry02ACR
Larry02ACR's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!Larry02ACR is an amazingly helpful member with a good attitude!
If you don't want to wait on the shipping from Japan, I've found this guy to be most excellent, although Eastern Beaver is good as well:
http://www.cycleterminal.com/ring-terminals.html
That's where I've gotten most of my crimping tools, and a bunch of the connectors to replace the fried ones on a GSXR I'm rebuilding...
Larry02ACR is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Larry02ACR!
Old Streetfighter Motorcycle Forum Post 10-20-2019, 10:11 PM   #5
Larry02ACR
Sorry, just realized he has no stock on the split rings.
Still a good source for connectors and terminals though.
Old Streetfighter Motorcycle Forum Post 10-21-2019, 10:32 AM   #6
if you can't find the right part, I doubt it'd take too long to modify from a full ring terminal.
Old Streetfighter Motorcycle Forum Post 10-23-2019, 08:44 AM   #7
Local Time: 04:37 PM
Hmm, used to see those on coil wiring on old cars. Like from the 40's and 50's. Doubt that helps you much. I never did understand them. It just seems like a weakened version of a ring. Unless there's a nub they lock in to to keep the terminal from spinning? I think Junkie has the right idea.
Old Streetfighter Motorcycle Forum Post 10-25-2019, 01:19 PM   #8
646 Sycamore
81XV750
646 Sycamore is really nice646 Sycamore is really nice646 Sycamore is really nice646 Sycamore is really nice646 Sycamore is really nice646 Sycamore is really nice646 Sycamore is really nice646 Sycamore is really nice
Take a look at https://www.restorationstuff.com/featured4.html.
646 Sycamore is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived 646 Sycamore!
Thank you for viewing Name This Wiring Terminal in the Electrical and Lights section of our streetfighter motorcycle forum. I hope you found it useful!
Electrical and Lights - Name This Wiring Terminal on Custom Fighters Streetfighter Motorcycle Forum
