Is mt-03 headlight plug and play for 2005 r1? - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Beginner Streetfighter Questions
Beginner Streetfighter Questions This is the place to ask all beginner questions with no fear of being flamed. This section will be HEAVILY MODERATED! Any fighter related question is allowed, no matter how simple!
CustomFighters.com Streetfighter Motorcycle Forum > Is mt-03 headlight plug and play for 2005 r1?
Old Streetfighter Motorcycle Forum Post 05-18-2019, 06:51 PM   #1
bowtieguy04
NoObie
Noobie
Local Time: 02:46 PM
bowtieguy04 is a NOOB
Default Is mt-03 headlight plug and play for 2005 r1?
new to the site as of today. After 2 weeks im almost finished with my first street fighter build. I bought the mt-03 headlight to put on my 2005 r1. My r1 has 2 h4 plugs ( right side high and low, left side high and low). Is it just plug and play using one h4 socket or do i need to break the harness down and wire it a certain way? i searched and found tons of info on mounting but didnt find any info on if its plug and play or wires need cut. figured id ask before i cut the harness apart. i can post pics of harness and healight if needed.
bowtieguy04 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 05-20-2019, 11:56 AM   #2
Junkie
re-tarded
Local Time: 12:46 PM
Flip Offs: 3
Default Re: Is mt-03 headlight plug and play for 2005 r1?
If the bike has 2 H4 plugs you'll be fine just using one of them. You can remove the other if you want.
Old Streetfighter Motorcycle Forum Post 05-20-2019, 01:49 PM   #3
bowtieguy04
NoObie
Noobie
Default
Ok. I tested the socket. Got 14.2 on the blue side(high beam with switch on) for both plugs. I get nothing on the green side(low beam with switch off) for both plugs. I know I'll have to add a ground wire to the top terminal. What am I missing to get the low beams to work? Do highs and lows have seperate fuses?
ID:	105094   Click image for larger version
Old Streetfighter Motorcycle Forum Post 05-20-2019, 03:01 PM   #4
Mongoose
the green is the ground no?
Mongoose is offline   Reply With Quote on our streetfighter motorcycle forum
Tags
2005 yamaha r1, mt-03, wiring
Thank you for viewing Is mt-03 headlight plug and play for 2005 r1? in the Beginner Streetfighter Questions section of our streetfighter motorcycle forum. I hope you found it useful!
Beginner Streetfighter Questions - Is mt-03 headlight plug and play for 2005 r1? on Custom Fighters Streetfighter Motorcycle Forum
