titans project skip build - Page 6 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > titans project skip build
Old Streetfighter Motorcycle Forum Post 02-04-2020, 03:59 PM   #51
titan
hooligan quads
titan's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 08:38 AM
Flip Offs: 3
Flipped Off 14 Times in 2 Posts
titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!titan is an amazingly helpful member with a good attitude!
Default Re: titans project skip build
As I blow all my build budget this month on a 3d printer I best get some stuff designed to print.
So first up is a rear light bracket. Now I have no idea what I'm doing or if I'm doing it right but all the measurements are right. What I do have is time through the week (work away) to play on fusion so making the most of it.
Printer is somewhere in the Netherlands so not long now
Sent from my SM-G973F using Tapatalk
ride it like you stole it
Customization not Restoration
Originally Posted by Albert Einstein
I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.
H Designs
2020 build off - build - chat
titan is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived titan!
Old Streetfighter Motorcycle Forum Post 02-08-2020, 10:01 AM   #52
titan
hooligan quads
Flip Offs: 3
Always one to jump in with both feet. Printer running great so swap out the filament for some nice blue, and printed off the light bracket. Fits perfect so I'll get the lights ordered at some point and make sure they fit then I'll do final print in better filament (once I work out what that is).
H Designs
Old Streetfighter Motorcycle Forum Post 02-08-2020, 01:33 PM   #53
titan
hooligan quads
Flip Offs: 3
Front light all tacked up,and in place. Next job Speedo mount
H Designs
Old Streetfighter Motorcycle Forum Post 02-10-2020, 04:37 PM   #54
titan
hooligan quads
Flip Offs: 3
Originally Posted by XxGRYMMxX View Post
no support on the bottom?
Nope the light weights less then the mount lol. I will be adding two horizontal bolts taped into the top triple once I sorted out the Speedo bracket. Should be fine
If not should be easy enough to add something to the bottom
H Designs
Old Streetfighter Motorcycle Forum Post 02-13-2020, 06:55 PM   #55
titan
hooligan quads
Flip Offs: 3
need to relocate the speedo bracket, the orignal sides from the front, i need it to slide from the back so i can add a mounting point to the rear. so using my new skills to see if i can print one. this will be the test print, make sure all the dimentions work then i'll fine tune it and add the fixing point.
Name:	speedo bracket mk2.png
H Designs
Old Streetfighter Motorcycle Forum Post 02-14-2020, 06:44 PM   #56
titan
hooligan quads
Flip Offs: 3
Double failure tonight but it's to be expected.
Print was shit as for some reason I messed up the settings... And where I moved the point the wire goes through the bracket to the other side I had not calculated the point the wire was on the actual Speedo. But I'm now running off version two, the rest of the measurements look good but want to check then I can work out the bracket part.
H Designs
Old Streetfighter Motorcycle Forum Post 02-16-2020, 10:51 AM   #57
titan
hooligan quads
Flip Offs: 3
Weather is terrible, so I striped down the front end to work out what size spacers I'll need for the top yoke.
They should do it
H Designs
Old Streetfighter Motorcycle Forum Post 02-23-2020, 07:14 AM   #58
titan
hooligan quads
Flip Offs: 3
Speedo mount V5 in print
H Designs
Old Streetfighter Motorcycle Forum Post 02-23-2020, 05:05 PM   #59
titan
hooligan quads
Flip Offs: 3
Last few adjustments to make, I'll add a couple of 20mm spacers to the design and I should be able to drill the holes to mount it all together. Then I can move on to the ever increasing list.
This will get printed off in finale filament once I finish my enclosure for the printer.
H Designs
Old Streetfighter Motorcycle Forum Post 03-07-2020, 10:48 AM   #60
titan
hooligan quads
Flip Offs: 3
Final design, ready for printing in something a bit more substantial.
H Designs
Thank you for viewing titans project skip build in the 2020 Winter Build-off Build Threads section of our streetfighter motorcycle forum. I hope you found it useful!
2020 Winter Build-off Build Threads - titans project skip build on Custom Fighters Streetfighter Motorcycle Forum
