97 Tarded YZ Build - Page 38 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Non-Streetfighter Motorcycle Discussion > Dirty Tards & Minis
Dirty Tards & Minis Everything about dirtbikes, motards and minis goes in here!
CustomFighters.com Streetfighter Motorcycle Forum > 97 Tarded YZ Build
Old Streetfighter Motorcycle Forum Post 01-12-2019, 12:18 PM   #371
busa1300
CF Lover
busa1300's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 04:27 PM
Flip Offs: 1
Flipped Off 5 Times in 3 Posts
busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!busa1300 is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month Fighter of the Month
Default Re: 97 Tarded YZ Build
Plugs...
My standard plug is a BR9ECM
But I have a set of R5184-10's in my VJ23 now, and they seem to make a positive difference
Not sure what version would work for your bike?
2019 winter build off bike RZV500R
https://www.customfighters.com/forum...d.php?t=136718
__________MY TWO STROKE ADDICTION_____________
RGV VJ21 L____________GT 750 J__sold _____
RGV VJ22 FL_________ GT 750 long term cafe project___
RGV VJ22 N ______________RS 250 Cup Bike_________
RGV VJ23 T__________And one for the water...SX-R 800_
RZ 350_______________The cherry popper...KD 80_____
___________________RZV500R____________________
busa1300 is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 01-12-2019, 12:29 PM   #372
RS_Raz
Dickhead
Senior Fighterer
Local Time: 09:27 PM
Flip Offs: 10
Stock for this engine was BR9ES but this cylinder wants a BR8ES.
Unfortunately I can't use the plug you posted because it will interfere with the Zeeltronic. I tried non resistor plugs before the zeel but my dash wouldn't work right. It just went crazy.
Old Streetfighter Motorcycle Forum Post 01-12-2019, 12:44 PM   #373
Smoker
BLACK BELT
Local Time: 01:27 PM
Flip Offs: 35
You could probably use the non-resistor plugs with resistor-type plug caps/wire.
Not sure if it would be better than resistor plugs and non-resistor wire.
Similar issues on the RZ350.
Old Streetfighter Motorcycle Forum Post 01-12-2019, 12:58 PM   #374
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
You can try it. I did already and had issues. I tried a Champion non resistor cap a while back and recently I crimped up a custom non-resistor terminal with a champion boot over it but I had running issues. I'm sure it was arcing on the head/thermostat housing. The last time I tried it, the mileage on my speedo jumped up over 16,000 miles with no way to reset it :'( I put this down to the speedo picking up a pulse from the HT lead and interpreting it as wheel rotations.
The Yamaha book for this engine specs a resistor plug and a resistor cap.
Borut says you can use a resistor or non-resistor cap but you must use resistor plugs.
I'm using resistor plug and cap and I'm still getting a blue spark so I'll have to leave it at that.
I was hoping to use non-resistor everything and widen the plug gap but it's not gonna happen on this bike.
Old Streetfighter Motorcycle Forum Post 01-12-2019, 03:19 PM   #375
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
Originally Posted by busa1300 View Post
putting a spacer there will now also mean that the needle will be 2mm lower that designed.
Could be an issue at the top end...?
Each clip position is 0.9mm apart. So I put the numbers into kyajet.de and calculated the jetting as if the needle is 2 clip positions lower (so 1.8mm - close enough to my 2mm) and it looks as though the main jet will be about 1.5% leaner at full throttle:
Obviously this is just theoretical. Definitely worth a plug chop
These people High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 01-13-2019, 11:36 AM   #376
Smoker
BLACK BELT
Flip Offs: 35
What about shaving 2mm off the end of the jet needle?
Old Streetfighter Motorcycle Forum Post 01-13-2019, 12:17 PM   #377
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
Won't be necessary to change anything else. The carb can only flow 33mm of air at full throttle. If the needle is able to move 2mm but the air flow remains unchanged, it will screw up the jetting.
Because whether I have the throttle pulled 33mm, 34mm or 35mm, the carb can only flow 33mm worth of air but the needle is allowing more fuel through the further it travels. This is creating a varying mixture and could cause a lean condition at just off full throttle.
So the way it is now is perfect. At wide open, the slide and needle are static. Better for jetting and less throttle travel at the bars
This user High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 01-13-2019, 04:50 PM   #378
Smoker
BLACK BELT
Flip Offs: 35
You can try it.
Yamaha manual specs a resistor plug and resistor cap for my RZ350.
Been using either resistor plugs or resister wire, but not both. For years, without issues.
Different bike, different parts.
This is what MK said about the slide mod:
"The RGV carbs have the same issue and reducing max. lift adds top end performance."
This user High Fived Smoker!
Old Streetfighter Motorcycle Forum Post 01-13-2019, 05:34 PM   #379
RS_Raz
Dickhead
Senior Fighterer
Flip Offs: 10
True that. If the slide isn't flush with the top of the bore it will increase the area inside the carb and reduce velocity. The gap will cause turbulence.
Butt dyno probs might not notice it but a real dyno could.
Old Streetfighter Motorcycle Forum Post 01-13-2019, 07:21 PM   #380
busa1300
CF Lover
Flip Offs: 1
I have a Zeel in my VJ23 and have no problems with the race plugs.
They work great in town and out beating the hell out of it.
Using stock plug wires and cap.
Thank you for viewing 97 Tarded YZ Build in the Dirty Tards & Minis section of our streetfighter motorcycle forum. I hope you found it useful!
Dirty Tards & Minis - 97 Tarded YZ Build on Custom Fighters Streetfighter Motorcycle Forum
