gs1175, "time slip" retro build - Page 13 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > gs1175, "time slip" retro build
Old Streetfighter Motorcycle Forum Post 08-13-2015, 10:16 PM   #121
Wrexz
Noobie
Local Time: 01:55 PM
Wrexz is really niceWrexz is really niceWrexz is really niceWrexz is really niceWrexz is really niceWrexz is really niceWrexz is really nice
Default Re: gs1175, "time slip" retro build
You should see if you can get replacement rubber boots for the coils, I know they make them for coil on plug cars so they should be available somewhere for bikes as well
Wrexz is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Wrexz!
Old Streetfighter Motorcycle Forum Post 08-14-2015, 03:44 AM   #122
370steve
old fart
Local Time: 06:55 PM
Flip Offs: 33
cheers for that Wrexz, but its not a problem with the rubbers, more a case of the small metal clip that grips the threaded piece on top ot the plug being worn out, thus not gripping the plug as positivly as it should.
I have now changed out all of the worn sticks, so have fingers crossed that i have cured that problem
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-14-2015, 10:05 PM   #123
Wrexz
Noobie
Would it be the piece labeled #2?
Old Streetfighter Motorcycle Forum Post 08-15-2015, 06:21 AM   #124
370steve
old fart
Flip Offs: 33
No mate the sticks that i have use a small "C" clip fitted inside the bottom of the stick body, it is that that is worn out.
I will post some pics later
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-15-2015, 09:02 AM   #125
tsukuyomi79
0.o i didn't do it
tsukuyomi79's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 2
Flipped Off 11 Times in 9 Posts
tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!tsukuyomi79 is an amazingly helpful member with a good attitude!
Is there no way to get to the clip and squeeze it closed a little bit?
tsukuyomi79 is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived tsukuyomi79!
Old Streetfighter Motorcycle Forum Post 08-15-2015, 11:15 AM   #126
370steve
old fart
Flip Offs: 33
tried that mate, but clips seem to be very worn and weak
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-15-2015, 12:51 PM   #127
tsukuyomi79
0.o i didn't do it
Flip Offs: 2
That's poop
Old Streetfighter Motorcycle Forum Post 08-17-2015, 04:10 AM   #128
370steve
old fart
Flip Offs: 33
took the forks apart last week to change the oil seals, but found that one of the slider bushes was badly worn, so ordered a set of bushes.
got all the bits needed to sort the fork legs out on Friday.
went over to my mate Stu's and used his seal drivers, now forks have seals and bushes, just waiting on the fork cap extenders so i can get
everything re built.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-21-2015, 05:07 AM   #129
370steve
old fart
Flip Offs: 33
took her out for a quick test ride, still got a very lumpy idle, carb bowles still flooding/overflowing if left with tap in the on position and engine not running even after fitting new fuel needles and seats FFS. I am going to re visit the setting of the floats, but made sure that they were spot on to the Mikuni reccomended 17mm, might try setting them 18mm or more to see what that does, got a feeling that it isnt helping me get the low throttle settings sorted.
first problem i am having is from idle (closed throttle) to 1/4 throttle, she is very lumpy and stuttering, have played around with pilot screws, but as of now have not made a lot of difference! if it happens when riding it clears if i shut the throttle and then open up again slowly, once over 1/3 throttle she goes like fuck, just low throttle transition probs at the moment
i have just adjusted the accelerater pump to see if that will make any difference.
second problem is that i seem to be loosing one cylinder at idle, but then comes back in again with slight throttle? have checked coils and ignition (cant find any probs), have an idea that it is linked to backfiring through carbs and holding revs on closed throttle. gives all the symptoms of having an air leak somewhere in the carb to head fitment area, so i have taken the carb rubbers off and given the rubbers a good coat of Honda bond to make sure that they are air tight.
will take extra care when replacing the carbs to make sure they seat propperly in the rubbers before tightening.
got the fuel feed sorted now and not suffering from starvation through lack of flow.
anyone got any experience of setting up Mikuni RS carbs? any advice would be very much appreciated
see how i get on with ride later this afternoon.
SHIT HAPPENS!!!!!
Old Streetfighter Motorcycle Forum Post 08-21-2015, 10:11 AM   #130
shinyribs
Flip Offs: 58
Nothing is more annoying then when carburetors refuse to cooperate and you're doing everything right.
Hang in there bud.
Thank you for viewing gs1175, "time slip" retro build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - gs1175, "time slip" retro build on Custom Fighters Streetfighter Motorcycle Forum
