RZ350 the 2019 re-frame - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > RZ350 the 2019 re-frame
Old Streetfighter Motorcycle Forum Post 05-04-2019, 07:14 PM   #11
make that thing forkless
forks and valves... WTF?
Senior Fighterer
make that thing forkless's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:46 PM
Flipped Off 3 Times in 3 Posts
make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!make that thing forkless is an amazingly helpful member with a good attitude!
Fighter of the Month Fighter of the Month Fighter of the Month
Default Re: RZ350 the 2019 re-frame
Forkless is back!
Sorry for the long delay, but I got blocked by two work related trips to Suzhou, China and then a few weekends working on putting this little race bike back on the road...
[IMG]20190502_145554 by andbike, on Flickr[/IMG]
Anyway, I finally had some time to jump back into the RZ350 frame project. Put in some more effort on the CAD model. My focus was on getting the swignarm further developed. I added the right side main tube which will have an arc for pipe clearance. Also started adding brace tubes and modeled in a chain with 10mm offset from the stock position. This should allow clearance for using stock off-set or the 10mm off-set chain line. As mentioned in my previous post, the linkage and geometry is modeled off a TZR250 so the goal is to have options for either swingarm in the future. Here's some updates of the CAD...
[IMG]20190404 image 1.0 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]20190404 image 1.1 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]20190404 image 1.2 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]20190404 image 1.3 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]20190404 image 1.4 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
In addition to the CAD work, I've also started collecting parts...
Engine is actually a 350 Banshee, so essentially an RZ350 minus the powervalves. Since I plan to build this bike for this years DirtBag Challenge, I need to keep the budget close to or under $2000. So a Banshee engine will be plenty fun and this one was only $500 on CL. It came with an extra head and both were pretty beat from loose debris (likely a failed bearing cage), so my friend Brian Turfrey hooked me up with some machine work to surface the head and re-cut the combustion cambers, now with slightly higher compression. The engine was missing the carbs, so found a great deal on carbs, with manifolds, pod filters and boost bottle on eBay.
The cases are broken in a non functional area so I could use as-is, but I've got some RZ cases I'll swap and then be able to run a tach. I've also got boxes of side covers, so should be able to easily assembly a complete engine. I'm probably now at around $750 for the engine.
[IMG]20190504_143929 by andbike, on Flickr[/IMG]
[IMG]20190504_144046 by andbike, on Flickr[/IMG]
[IMG]20190504_144720 by andbike, on Flickr[/IMG]
I also found a good deal on this Toomey Racing filter and jet kit. I probably will run the dual pods to keep my budget lower, but will make sure the frame has ample clearance for the Toomey style filter.
[IMG]20190504_144538 by andbike, on Flickr[/IMG]
Next, I'll show a pile of pipes that I'll likely pull a set to chop up later. Second from the left is a set of John Lassak pipes that were given to me, so those are an obvious choice to modify to fit the new frame and not impact budget. On the far right are a crappy set of SpecII pipes, since I have minimal opinions of these, these are also candidates to be cut and modified... but that's a ways away.
[IMG]20190504_143948 by andbike, on Flickr[/IMG]
Last, wanted to show the wheels and forks that will be used. The forks are 2001-03 GSXR600. The wheels are DRZ400 hubs (off-road version) laced with 17" Warp 9 supermoto rims. The front wheel will eventually get an aftermarket 320mm rotor.
The wheels and forks were inherited when a good friend passed away a few years back (FUCK CANCER!!!) Eric had started building a KZ400 cafe bike and never got to see it finished, so it will be a nice memento to use this wheels on this bike.
[IMG]20190504_143642 by andbike, on Flickr[/IMG]
Thats it for now. Stay tuned for more, hopefully without the long delays
make that thing forkless is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived make that thing forkless!
Old Streetfighter Motorcycle Forum Post 05-05-2019, 01:58 PM   #12
Senior Fighterer
I did a little more CAD work last night trying to decide on how to fabricate the mount for the shock linkage. First concept is a bent heavy gauge sheet metal bracket...
[IMG]20190405 image 1.4 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]20190405 image 1.5 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
Alternative idea is to stay with tubing and bungs. This is a bit more work to fabricate, but keeps the construction method looking more consistent. I'm probably leaning toward this design...
[IMG]20190405 image 1.3 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]20190405 image 1.2 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
Also wanted to see what it would look like with dual shocks. I might do this for the Dirtbag build...
[IMG]20190405 image 1.0 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]20190405 image 1.1 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
Old Streetfighter Motorcycle Forum Post 05-19-2019, 10:45 PM   #13
Senior Fighterer
A little more CAD progress. Main frame is roughed in. I'm thinking about using inserts for the swingarm pivot mounts so put some circular clamps into the model. Still lots of details to add, followed by lots of fine tuning, but at least starting to look like a motorcycle now...
[IMG]201905019 image 1.0 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]201905019 image 1.1 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
[IMG]201905019 image 1.2 rz350 frame assembly 2019 by andbike, on Flickr[/IMG]
Old Streetfighter Motorcycle Forum Post 05-20-2019, 04:02 AM   #14
MDM
Procrastinator
Flip Offs: 3
Swingarm pivot inserts to, presumably,have an offset pivot point and thus allow for some adjustability?
Old Streetfighter Motorcycle Forum Post 05-20-2019, 04:12 AM   #15
a_morti
Local Time: 12:46 AM
Flip Offs: 24
Strikes me you know your way around chassis geometry well enough to get it right first time and save yourself the trouble of making adjustable pivots?
Old Streetfighter Motorcycle Forum Post 05-20-2019, 05:06 AM   #16
yantosh
Local Time: 11:46 PM
Flip Offs: 14
you could say the same of any of the major manufacturers, but plenty high end and race bikes still have the adjustability
Old Streetfighter Motorcycle Forum Post 05-20-2019, 11:58 AM   #17
Junkie
re-tarded
Local Time: 02:46 PM
Flip Offs: 3
I imagine that has a lot to do with letting you run different height tires, as different manufacturers are different.
Just a guess though.
Old Streetfighter Motorcycle Forum Post 05-20-2019, 12:30 PM   #18
yantosh
Flip Offs: 14
i thought it more to set up bikes for diff riders ?
Old Streetfighter Motorcycle Forum Post 05-20-2019, 01:33 PM   #19
Senior Fighterer
First off thanks for the comments and feedback. The adjustable swingarm pivots are to satisfy three issues...
- the primary idea is to allow for swingarms of different widths or different pivot shaft diameters without needed for shims or spacers. The inserts can be easily turned to different inside diameter and length. As previously mentioned, the swingarm is based on a TZR250 which is fairly wide at the pivot, however they aren't easy to source. If I end up making duplicate frames and selling a few, this will allow users to easily adapt other swinagrms of different widths if they wish. It might not be needed for this reason, in which case see reasons 2 and 3...
- second is to allow fine tuning of the pivot location (as most comments allude to).
- third is the bling factor... this is also important, right?
Old Streetfighter Motorcycle Forum Post 05-21-2019, 04:57 AM   #20
bonehead
Fucking Retard
Fighter
Flip Offs: 3
Flipped Off 5 Times in 3 Posts
bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!bonehead is a wicked helpful, well liked member!
[quote=make that thing forkless;3124674]A little more CAD progress. Main frame is roughed in. I'm thinking about using inserts for the swingarm pivot mounts so put some circular clamps into the model. Still lots of details to add, followed by lots of fine tuning, but at least starting to look like a motorcycle now...
Very interested in what you are doing here, what information do you use to determine the type and size of the tubes to make the frame strong enough, motor mounts are sorta straight forward but what about the other design elements, how many tubes and where?
Many thanks in advance.
bonehead is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived bonehead!
Thank you for viewing RZ350 the 2019 re-frame in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - RZ350 the 2019 re-frame on Custom Fighters Streetfighter Motorcycle Forum
