SV1000Reptilia - Page 4 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > SV1000Reptilia
Old Streetfighter Motorcycle Forum Post 10-07-2019, 03:39 PM   #31
Junkie
re-tarded
Local Time: 09:18 PM
Flip Offs: 3
Default Re: SV1000Reptilia
Yes, but no, but yes.
Alum strength, regardless of alloy, is highly dependent on it's heat-treat level. This is the -T(n) in the alloy number, i.e. 6061-T6.
Welding alum will introduces a high heat cycle that will reduce temper to T0 at least in the heat-affected-zone or in the entire part depending on how hot the whole thing gets. So, there goes all your strength... until you re-temper it. Sending the part off for heat-treat after welding will return it to the desired T level.
right, it can be re heat treated, but that isn't something most welders will be equipped to do and it's going to be awfully expensive for a part that size.
Old Streetfighter Motorcycle Forum Post 10-11-2019, 06:09 PM   #32
Leroy
Leroy's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 08:18 AM
Flip Offs: 1
Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!Leroy is an amazingly helpful member with a good attitude!
Winter Buildoff Winner Fighter of the Month
Ok here we go again with a subframe from 899 this time. The reason I've choose to buy this and not build one, is that I'm not sure If I can make it lighter from the OEM. It's a litle complex. Doable to build but complex enough, to give all the efort and money and stay with a heavier subframe at the end.
So 899 subframe it is and the 1199 one is on ebay for selling. I should have it next week.
Leroy is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Leroy!
Old Streetfighter Motorcycle Forum Post 10-11-2019, 11:15 PM   #33
Auser6guy
Active Member
Fighter
Local Time: 12:18 AM
Auser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to all
Default
That seems much easier to work with. If that’s steel I reckon even I could knock something up 😂
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
This user High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 10-12-2019, 05:00 AM   #34
Leroy
Flip Offs: 1
It's piece of cake to make it work. Yes it's made of steel
This user High Fived Leroy!
Old Streetfighter Motorcycle Forum Post 10-16-2019, 07:42 PM   #35
Leroy
Flip Offs: 1
Today I received the subframe. I just had to weigh it.
SV complete tail 10.145 Kg (22.365 pounds)
Panigale complete tail 6.015Kg (13,260 pounds)
Choped litle by litle
Test fit
Bent some tubes
An did a mock up to see how it looks. Sit back, check the angles and give it a look.
It locked good to me. Small, clean. A big smile pop out of my face
But then again, it doesn't looks strong enough to handle the weight of a rear passenger
I had to move the tubes a litle more to the end. It might give me some space to fit the fuell tank in it.
Pretty much this is how the lower tubes will support the subframe.
I will place them between the front and rear seat.
It's temporary. I will buy some squear tube to match it with the frame.
Old Streetfighter Motorcycle Forum Post 10-16-2019, 11:19 PM   #36
mcantar
Fuck it, let's do it live
Local Time: 11:18 PM
Flip Offs: 46
Flipped Off 22 Times in 21 Posts
Fighter of the Year Fighter of the Month
Pick up the Panigale DP Comfort Seat. Looks and feels way better than the standard one.
Turbo Busa v2 2017 Buildoff.
Turbo Busa v1.1
This user High Fived mcantar!
Old Streetfighter Motorcycle Forum Post 10-17-2019, 02:52 AM   #37
Leroy
Flip Offs: 1
I just searched for it. It looks comfy and it's available for the rear seat too. A bit pricey, but I should get it later when the build ends. Especially for the rear, the oem is just for the looks.
Old Streetfighter Motorcycle Forum Post 10-17-2019, 01:13 PM   #38
mcantar
Flip Offs: 46
For the pillion seat I prefer the hard cover.
Turbo Busa v1.1
Old Streetfighter Motorcycle Forum Post 10-17-2019, 04:54 PM   #39
Leroy
Flip Offs: 1
Me too. Most of the time I will use the hard cover. But I and my wife want to escape some times for a ride when the kids are to their grandma. I believe she will enjoy that seat versus the skinny oem
Old Streetfighter Motorcycle Forum Post 11-04-2019, 05:51 PM   #40
Leroy
Flip Offs: 1
Things doesn't flow the way I want. The bad news is that I had ordered the fitings for the subframe, 2 weeks ago and I should had it the last weekend. I hope I will get those fittings this weekend. The good news is that the headlight cowl arrived today
And did a test fit. This is the angle I like
And while I was waiting for the parts I've make my special tool for the engine bolts
I hope I can do some work this weekend...
Thank you for viewing SV1000Reptilia in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - SV1000Reptilia on Custom Fighters Streetfighter Motorcycle Forum
