Hey guys/gals,
I'm swapping out my '92 Kat 600's bulky breather/filter for either 4 individual cone filters that clamp to each carb, or 2 two barrel filters that clamp to carbs 1&2 and 3&4. I have three questions.
1. Which brand filters of each style do you advise?
2. Since the outlet is oval, do I measure the small diameter then the large diameter and purchase the size that is the average of the two?
3. What should I do with the crankcase vent opening/hose that was connected to the airbox? The port is threaded inside like you could plug it with a bolt, which is odd, cause that would not be a good idea.
Thanks!
Thanks!
