Mickís Bandit 1200 - Page 2 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Mickís Bandit 1200
Old Streetfighter Motorcycle Forum Post 03-04-2020, 02:30 AM   #11
Mick
Local Time: 11:09 PM
Mick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to allMick is a name known to all
Default Re: Mickís Bandit 1200
Trying to sort out the rear shock mount location, I figure seeing as Iím using gsxr shock swing arm and linkage then I should set it up to the same travel/ratio parameters, being 130mm rear wheel travel and 65mm shock stroke.
To do this I made a dummy link from some old rig wire the same length as the gsxr dog bone, with this I could experiment different bottom linkage positions.
Next I used a piece of the same wire with two marks on it, one the shock length at full extension and one at full compression, put a loop in the bottom to attach to the bottom shock mount.
Next I set the swing arm to where I wanted full droop (same height as the bandit arm) and used the extended shock mark to draw an arc on som white card, next lift the swing arm 130mm and use the fully compressed mark to mark out another arc, the theory is that where the two arcs intersect is where the top mount needs to be.
This is using the bottom mount (centerstand)
Cleary this wonít work, the intersection would be too far forward, next Iíll try the top original mount
Not too bad, time to start cutting again!!
I cut it twice and itís still too short
Mick is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-07-2020, 04:18 AM   #12
Mick
Picked up some gsxr750 forks, bottom triple, r6 calipers/master and some gsxr600 wheels.
Pressed the bandit stem into the gsxr triple and gave it a light sandblast at work last night.
Looks the part, just need to get or made some fork tube extenders, make up some steering stops and make some spacers for the calipers.
Sometimes although not totally productive, sitting it together like this can help give a glimpse of what it will look like, seems to help with motivation. Still need to make rear shock mounts and a panel under the tank to mount the cdi/fuses.
These people High Fived Mick!
Old Streetfighter Motorcycle Forum Post 03-10-2020, 08:03 AM   #13
Mick
Bottom linkage mount
Some reinforcing
Top shock mount
Welded with a reinforcing plate put in the back, I need this to be strong!
All of this steel plate funnily enough came from a smallish chocolate conche, they were the old beater blades destined for scrap, theyíve been really handy over the years, gate hinges, hf antenna brackets, good stuff.
Mock up time again, needs fork extensions maybe...
Old Streetfighter Motorcycle Forum Post 03-10-2020, 03:01 PM   #14
XxGRYMMxX
Breaking shit...
XxGRYMMxX's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 12:09 AM
Flip Offs: 8
Flipped Off 13 Times in 10 Posts
XxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on hereXxGRYMMxX spends too much time on here
itll be a little taller with tires on there but it does look low. low isnt bad as long as you have clearance though.
They can ban, outlaw, and restrict whatever they please. I'll keep doing whatever the fuck I'm doing, because I don't really give a shit. The only thing that will change is that I'll be breaking their made up bullshit rules while doing it, and I'm comfortable with that.
My Build http://www.customfighters.com/forums...d.php?t=118649
XxGRYMMxX is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived XxGRYMMxX!
Old Streetfighter Motorcycle Forum Post 03-10-2020, 03:03 PM   #15
Local Time: 05:09 AM
yeah, but look at fork tops, sitting low
Old Streetfighter Motorcycle Forum Post 03-10-2020, 06:55 PM   #16
XxGRYMMxX
Breaking shit...
Flip Offs: 8
woah... didnt even see that yan.
Old Streetfighter Motorcycle Forum Post 03-10-2020, 08:39 PM   #17
Mick
Yea I knew the gsxr forks would be 40mm shorter than the original ones, and considered briefly making the back end a little lower to save running a stepped yoke or fork tube extensions, I didn’t end up doing that due to possible clearance issues, I’ve made the back end height the same as what it was with the bandit swing arm when it was running a 94gsxr shock (about 20mm higher than stock), just means I’ll have to get some fork tube extensions.
Also the gsxr swingarm is about 25mm longer than stock so may not wheelie as well
Old Streetfighter Motorcycle Forum Post 03-15-2020, 09:38 AM   #18
929_adam
929_adam's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 501
Flipped Off 166 Times in 132 Posts
929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!929_adam is an amazingly helpful member with a good attitude!
Fork tube extensions???
Gavin Wayne Butts - Greencheezeeta - 10/5/83 - 9/8/09 RIP My Brother
Originally Posted by mpls|cafe|racer
"Knowledge is knowing that you know nothing." That's a motto to live by. There's always someone out there better, more knowledgable, faster, etc. and you can always learn and improve...
AFF.COM
929_adam is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 03-15-2020, 12:34 PM   #19
problem with fork extensions is they can push the locating dia of the legs out the bottom yoke, so need a stepped bottom yoke ,
These people High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 03-17-2020, 06:43 PM   #20
XxGRYMMxX
Breaking shit...
Flip Offs: 8
stepped yokes look cool.
This user High Fived XxGRYMMxX!
Thank you for viewing Mickís Bandit 1200 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Mickís Bandit 1200 on Custom Fighters Streetfighter Motorcycle Forum
