Matty`s China Street Quad - Page 9 - Custom Fighters - Custom Streetfighter Motorcycle Forum
Go Back   Custom Fighters - Custom Streetfighter Motorcycle Forum > Non-Streetfighter Motorcycle Discussion > Other Motorcycle Discussion
Other Motorcycle Discussion Anything about any other type of motorcycle goes in here.
CustomFighters.com Streetfighter Motorcycle Forum > Matty`s China Street Quad
View Poll Results: Which road to take?
Fix`n flip 2 28.57%
Full custom rebuild 2 28.57%
No fucks hoontrike 3 42.86%
Voters: 7. You may not vote on this poll
Old Streetfighter Motorcycle Forum Post 06-26-2020, 04:10 PM   #81
Local Time: 11:11 PM
Flipped Off 34 Times in 22 Posts
Default Re: Matty`s China Street Quad
Had a quad-win today (pun intended): Kids ain`t home, neighbors ain`t home, friday night and she-who-must-be-obeyed announced she`s too tired to socialize go play, so to the town I went.
I decided to just simply ram the old balljoint out through the bottom, worked surprisingly well as the ball pushed the bottom cap out and after that I just plucked the nylon insert out.
Took a slice off both top and bottom to get the dimensions closer to correct and to minimize the amount of metal to be removed at later more laborious stages, then found the closest matching socket and drawed a rough circle inside which I need to carve.
(enter about an hour of trying to find my carbide rotary, failing to do so followed by several hours of filing grinding sanding sweating and cursing)
Well, it ain`t pretty but it fits and ain`t going nowhere. I made the hole tapered enough to have to press fit the joint in and while welding waited after each tack for the piece to cool down enough to touch so I don`t dry the innards.
I`m gonna bet the quad will clock out before this.
Ex: Benelli Tornado 900 '06
Ex:Triumph Daytona 955i DSSA '02
Ex:Honda CBR 600 F2 '91
Mattson is online now   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Mattson!
Old Streetfighter Motorcycle Forum Post 06-28-2020, 03:28 PM   #82
Had a funny feeling about this brake disc but could not figure out why. Well turns out, along with the balljoint and contrary to the shop`s promises, this doesn`t fit the BS200S-7 as is either!
A few long clenched fist sighs later I took stock on what I have and what I can do with them, que a spark flying montage and some inspirational music and bam, old brake disc turned into an adapter.
Had to grind these whatchamacallem thingies off the caliper carrier to counter the offset of the adapter.
After straightening the rear axel (couldn`t get it 100% true but I suspect close enough)...
...I got the back end back together. It`s kinda hard to see but I had to grind the allen bolts holding the disc to the adapter flat as they were hitting the carrier. Ain`t getting much any contact with the pads yet but I reckon after a couple spins at the home street they`ll start to grab.
I also painted the now fixed front A-arm, swapped out the other three balljoint rubbers, greased the joints and put the front end back together. As it stands now I am 2x rear hub sand&paint, brake bleed, wheel alignment and an exhaust clamp away from inspection. Possibly next weekend if I can get an appointment, we`ll see.
Old Streetfighter Motorcycle Forum Post 06-30-2020, 06:20 PM   #83
Last minute roadbumps. I started investigating why isn`t the speedometer working contrary to the prior owner`s promises of it been working when the fire accident happened, turns out the speed sender is completely obliterated. The circuit board inside and the sensor itself looks to be intact but the sensor casing not only has a chip missing from the tp of the thread, the entire metal casing has split in two. My guess is the brake disc has warped enough to touch the tip of the sensor and one of the holes in the disc has collided with the sensor tube. Only problems is almost EVERYONE is out of stock so I`m either stuck with waiting for a new sensor for up to a month, or trying to modify a speed sensor from some other ATV to fit mine.
The second issue came when I tried bleeding the brake system. I got all three calipers bled, ran several reservoir tanks worth of fluid through the system to flush it as well as I could, got good brakes on the pedal, buttoned up and cleaned up. Then after about half an hour returning to the quad I pressed the pedal and it`s completely limp again. WTF?! Do I still have air in the system or is my master cylinder ripe for a swap?!
Old Streetfighter Motorcycle Forum Post 07-01-2020, 03:13 PM   #84
Pretty sure I just figured out the issue with the brakes, must have been tired or sth last night as the answer was blatantly obvious at first glance today, so much so I`m kinda embarassed to even tell... You see this thing has the same brake caliper on both sides up front, which means the left side caliper is upside down... You guessed it, caliper off and open the bleed valve, bubbles rush out even without pumping. Re-bled the right side to purge the line, got quite a bit of air out from there too. Pedal seems nice and solid now, report back tomorrow but as it stands I might not need new parts after all.
This user High Fived Mattson!
Old Streetfighter Motorcycle Forum Post 07-02-2020, 03:27 PM   #85
24hrs passed, still got brakes. New speed sensor ordered, if all goes well should have valid inspection and be road legal within July.
Old Streetfighter Motorcycle Forum Post 07-11-2020, 10:35 AM   #86
Now it`s a bolt...
...now it`s a hose nipple.
Didn`t fancy buying a new carb boot as this one`s already brand new just lacking the vacuum port. Been trying to find one online but with bad luck. Managed to locate a few but both companies not only wanted 10eur to ship a 1.50 part, they also wanted to charge me 20eur for "small order extra" like really?! Took me less time to fab one off an M6 bolt than what I`ve been using online searching.
Speed sensor should arrive monday, given that fixes the speedo I might have a valid road inspection by the end of next week.
Old Streetfighter Motorcycle Forum Post 07-12-2020, 01:57 PM   #87
Gave the fairings a proper wash last night to rinse off all the orange paint dust and slapped on a few go-fast stickers since I happened to have some (another pair in the rear mudguards currently covered by the sun glare)
Today I was planning to try get the carb fine tuned to get rid of that mid range sputter, rolled it on the street and started 'er up. At first it only agreed to idle dying at the first twist of the wrist then refused to start altogether. At first I thought the new vacuum nipple is leaking but since even a buttload of donkey kick didn't do nuffin I suspected it cannot be that. While taking off the carb for further investigation I noticed water droplets all around inside the carb throat. WTF?!
This is how much water I drained off the bowl and the fuel tank!!! So apparently that gas cap isn't sealing worth a damn! Note to self never leave it in the rain if it can be avoided!
I also took off, finished and painted the fog light brackets, and improved the seat front locking lip a little. The fire has melted the original one so the PO had fitted a metal strip in it's place but the roofing screws he fixed it with weren't quite up for the job so I drilled a few holes and put machine screws with nylock nuts in to reinforce the structure and shaped the strip a little to better catch the locating bolt on the frame crossbeam into the slot in the middle. Currently debating with myself whether or not to paint the flywheel inspection cover, and the starter cover orange.
Far as I can tell should be ready for inspection now, trying to get an appt sometime towards the end of the week.
Old Streetfighter Motorcycle Forum Post 07-13-2020, 03:43 PM   #88
I have now officially reached the point of this build where I`m either gonna start laughing maniacally flapping my sleeves around claiming I`m Batman, setting the quad back on fire this time not putting it out, or selling it for the first punter for a dollar...
New speed sender and extension cable fitted, still no speed reading. At first I noticed the extension cable was pinned wrong assuming it should be color for color from the gauge to the sender ( HOW can you mess up three wires?!) changed that, measured everything, I have ground, I have pilot power and I have sensor power, BUT the sensor wire is giving me a constant voltage reading instead of a pulse like it should, I even tried the remnants of the old brake disc in case the new one would be somehow of wrong metal, and failing that with a magnet but it`s not responding at all. So either they sent me a bum sensor, OR my gauge is busted.
NOTHING, NOT ONE THING of this build has gone smoothly or worked properly. I`ve worked with car engines, big motorcycles, RC motors of the ICE kind but this blasted contraption is taking the cake of being the most uncooperative vehicle I`ve ever poked my tools in!!!
Old Streetfighter Motorcycle Forum Post 07-19-2020, 06:25 PM   #89
Not sure if it`s the 13 years as a private contractor or what but I just cannot sit on my hands when there`s stuff to be done. Also might have helped to have spent three years studying as an electronics tech so I might have a certain edge over an average forum user on this but just broke my own record of fully wiring up a gauge cluster. For the heck of it happened to clock the attempt, without counting in the time spent for mapping out the wiring on the quad as normally I`d have a wiring diagram, took me an hour and a half to fully wire this thing in. Ok ok speed sensor needs fitted, a mount made to the handlebar clamps and it needs programming but all wired up functions do work. Apart from a parking light indicator as this cluster does not have one, and that`s required to pass inspection so an external light needs to be fitted for that.
BTW a big shout out to Kimmo57 for offering this Acewell ACE-5856 gauge cluster for me at a VERY affordable price! Pearls for pigs IMO to fit this kind of a computer on a quad like this but what needs must.
Old Streetfighter Motorcycle Forum Post 07-21-2020, 11:50 AM   #90
A small thing but still a thing... Made this mount plate off a piece of scrap so it's not particularily clean. Meant to be a temporary thing but if I know myself at all it'll turn into a permanent one, and I have to live with myself every day so...
Could have made the groove more shallow since I decided to bend the bracket back. Oh well I'll make the permanent one better (as if...)
I managed to trace down a 14mm hose block for the coolant temp sensor but to get that means a trip to the city so gonna wait til sth more comes up to make it more worthwhile.
I also fiddled with different options on how to mount the new speed sensor to the rear, proply gonna drill a hole through the sprocket to fit the magnet bolt onto it and mount the sensor under the swingarm. I was thinking whether or not to make a bracket then bolt it onto one of the underswing mudguard bolt holes since I won't be fitting it back on but swiftly solved that problem by promptly snapping a tap into the thread when cleaning it up. Yea, thanks, guess I'll just weld the bracket on then...
Right side rear rim has been painted with the first color but the paint seems to dry reeeeally slowly so gonna let it cure for a week to make sure the masking tape won't lift the paint off.
Thank you for viewing Matty`s China Street Quad in the Other Motorcycle Discussion section of our streetfighter motorcycle forum. I hope you found it useful!
Other Motorcycle Discussion - Matty`s China Street Quad on Custom Fighters Streetfighter Motorcycle Forum
