Hack to thrash - Page 15 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Hack to thrash
Old Streetfighter Motorcycle Forum Post 08-10-2019, 02:39 AM   #141
Casper
The friendly Ghost.
Local Time: 01:09 PM
Flip Offs: 190
Default Re: Hack to thrash
Subscribing the lazy way, looks good.
Can't leave them alone:2006 Suzuki SV650N, 1994 Yamaha XJ600S and 1979 Suzuki GS750LN
Time to find me a nice DRZ and VStrom...
This user High Fived Casper!
Old Streetfighter Motorcycle Forum Post 08-13-2019, 06:13 AM   #142
MDM
Procrastinator
Local Time: 03:09 PM
Flip Offs: 3
So, having made a cardboard template I cut a sheet of 2mm loominum to shape, and placed it to position the mounting holes to match with the lower rad mount on the front cylinder head, and the rear mount within the upper engine mount spacer. the spacer had to be cut and sized to suit, but then the sheet was bent to make the battery box.
It was drilled to be able to mount the reg/rec and the starter solenoid, and then I made a pitiful attempt at TIGging the folded edges together, I'm not going to show any pics of the end result as it is, frankly, horrific...
ID:	105704   Click image for larger version
These people High Fived MDM!
Old Streetfighter Motorcycle Forum Post 08-13-2019, 10:51 AM   #143
Junkie
re-tarded
Local Time: 12:09 PM
Flip Offs: 3
would look cooler if you picked up a dimple die set and gave it some speed holes
This user High Fived Junkie!
Old Streetfighter Motorcycle Forum Post 08-13-2019, 03:26 PM   #144
MDM
Procrastinator
Flip Offs: 3
I agree Junkie, but for the fact that I don;t want to reduce any strength from the areas that are actually big enough for holes... it's only 2mm ally after all.
Old Streetfighter Motorcycle Forum Post 08-13-2019, 03:30 PM   #145
Junkie
re-tarded
Flip Offs: 3
dimpled holes typically increase rigidity, which is generally more important than strength
I bet you could put a couple holes/dimples in the floor of the battery section itself, close to as large as the floor, with no problems. then a few in the large area too.
Old Streetfighter Motorcycle Forum Post 08-13-2019, 03:46 PM   #146
MDM
Procrastinator
Flip Offs: 3
I've not got access to a dimple die (yet, been meaning to get a couple for a while), and the floor of the box will have the reg/rec mounted under it, but I may return to this version of the battery box at some point in the future anyway, as I'm not especially happy with my handiwork...
But, for now, it is painted and about to be mounted!
This user High Fived MDM!
Old Streetfighter Motorcycle Forum Post 08-13-2019, 10:32 PM   #147
SEBSPEED
V4's FTW
Local Time: 04:09 PM
Flip Offs: 53
You can dimple with a couple mismatched sockets and a bench vise, if you want to give it a try
2015 FOTY VFR750
2016 threads
Turbo 7/11
750 Slingshot
Discussion thread
2017 thread
VFR800 Build
Old Streetfighter Motorcycle Forum Post 08-15-2019, 08:31 AM   #148
MDM
Procrastinator
Flip Offs: 3
I've just seen the price of dimple dies... Seb's idea will be the way to go if I do it!
Old Streetfighter Motorcycle Forum Post 08-15-2019, 11:04 AM   #149
yantosh
Local Time: 09:09 PM
Flip Offs: 14
you know enough folks with lathes......
This user High Fived yantosh!
Old Streetfighter Motorcycle Forum Post 08-15-2019, 03:25 PM   #150
MDM
Procrastinator
Flip Offs: 3
Good point Yan! Did I send you some pics of dimple dies back in the SF days? I sent some to someone, with the thought of doing a 'how to' kind of tech feature...
Thank you for viewing Hack to thrash in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Hack to thrash on Custom Fighters Streetfighter Motorcycle Forum
