Hack to thrash - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Hack to thrash
Old Streetfighter Motorcycle Forum Post 02-26-2019, 01:18 AM   #21
tldave
Local Time: 01:14 PM
Flip Offs: 5
Default Re: Hack to thrash
just gave him 2 more tonight. he made the mistake of opening his mouth and giving me money. really built 1g track bike, and a 2g fuckpile. the group is just called sv650. guaranteed you bought parts that came off bikes i picked up lol. did you buy a gsxr front end from him? if you did it probably came from me. hes starting to understand that volume increases profit.
Old Streetfighter Motorcycle Forum Post 02-26-2019, 03:49 PM   #22
Junkie
re-tarded
Local Time: 10:14 AM
Flip Offs: 3
I'm not on FB anymore after a BS ban just before xmas, was just curious which one
no, none of my front ends came from him. PAIR shit, airbox lid, chain guard, controls, coolant res, clutch cover... I think that's all I've bought from him.
I'd like to find a good 2nd gen tank if you come across one
Old Streetfighter Motorcycle Forum Post 02-26-2019, 11:10 PM   #23
tldave
Flip Offs: 5
color? define good? I just gave him a pristine one someone painted white over yellow, so if you wAnt to make one your own color, hit him up.
Old Streetfighter Motorcycle Forum Post 02-26-2019, 11:12 PM   #24
tldave
Flip Offs: 5
but also, he's sitting on I think 10 bikes he hasn't gotten to yet. At least 10, so he has stuff.
Old Streetfighter Motorcycle Forum Post 03-11-2019, 06:13 AM   #25
MDM
Procrastinator
Flip Offs: 3
Managed to get a few bits done over the weekend...
Fitted the QD fuel filler, the high flow Pipercross air filter and the 'sharks fin' to the underside of the swinging arm (drilled and tapped and threadlocked)
ID:	104074   Click image for larger version
ID:	104076   Click image for larger version
These people High Fived MDM!
Old Streetfighter Motorcycle Forum Post 03-11-2019, 06:18 AM   #26
MDM
Procrastinator
Flip Offs: 3
Also decided to have a bit of a fettle with the gear linkage, and it's now reset as a normal road change.
It meant that the shift rod was very close to the rearset backplate - as in rubbing against it close, so I marked it up with a Sharpie and introduced it to the flapper disc. Clearance created, and a little bit taken off to give some clearance for the shift rod adjuster nut at the peg end too. It now has a very clean shift, just like the standard one was, nowhere near as awkward as it was with the 'race' shift, no doubt helped by ensuring that the linkage angles were all perpendicular to each other...
ID:	104080   Click image for larger version
ID:	104082   Click image for larger version
Old Streetfighter Motorcycle Forum Post 03-11-2019, 06:22 AM   #27
MDM
Procrastinator
Flip Offs: 3
Started setting about doing the valve clearances, in the process getting distracted by fitting new coolant hoses and struggling to get the airbox and carbs off thanks to seized fasteners... Copious penetrating oil and the threat of the grinder will ensure they're off tonight, but will mean that new clips are needed for the front carb boot and front airbox sleeve. I'll order them from Suzuki once I know if I need any replacement valve shims. And I have a pair of injection model cams that I may fit while I'm in there too, I just have to check if I have the right ones... (If I remember right, they need to be injection exhaust cams to go in place of the carb model inlet cams, I think...)
Old Streetfighter Motorcycle Forum Post 03-11-2019, 08:23 AM   #28
yantosh
Local Time: 07:14 PM
Flip Offs: 14
pretty sure i've been tasked with machining the centre out of the plastic top of the air filters in the past
Old Streetfighter Motorcycle Forum Post 03-11-2019, 10:02 AM   #29
MDM
Procrastinator
Flip Offs: 3
I think that would only be of benefit with a modified airbox, which I can't do if I'm going to race in any of the Minitwin classes...
Old Streetfighter Motorcycle Forum Post 03-11-2019, 11:39 AM   #30
Junkie
re-tarded
Flip Offs: 3
the normal cam swap is to use 2nd gen (EFI) intake cams on the intake side, timed normally, and then 1st gen intake cams on the exhaust side. https://www.svrider.com/forum/showthread.php?t=28103 has some info. I preferred the BARF thread but pics are gone.
This user High Fived Junkie!
Thank you for viewing Hack to thrash in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Hack to thrash on Custom Fighters Streetfighter Motorcycle Forum
