Jmartin's '82 KZ1000 Build - Page 3 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Jmartin's '82 KZ1000 Build
Old Streetfighter Motorcycle Forum Post 01-02-2017, 12:05 AM   #21
jmartin1110
The Hell You Say!!
jmartin1110's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 05:39 PM
Flip Offs: 53
Flipped Off 12 Times in 9 Posts
jmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on herejmartin1110 spends too much time on here
Default Re: Jmartin's '82 KZ1000 Build
Chain guard wetted out
Side covers in gel coat
1981 Honda SS Build
KZ1000 Discussion Thread
KZ1000 Build Thread
Originally Posted by DrJellyFingers View Post
u gonna look so sexy naked.... I would say no homo, but totally homo since that that sentence can't not be homo
jmartin1110 is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived jmartin1110!
Old Streetfighter Motorcycle Forum Post 01-03-2017, 01:04 AM   #22
jmartin1110
The Hell You Say!!
Flip Offs: 53
Did some work on pulling the massive dent out of the gas tank
It took three days, lots of frustration and a couple of broken dent pullers. I finally was able to pop the rest of the dent out with compressed air
It's still got a minor dent but that will pull easy.
Shiny and fdup were right. The oil cooler lines and t stat look good once the body work is on
1981 Honda SS Build
KZ1000 Build Thread
Old Streetfighter Motorcycle Forum Post 01-11-2017, 10:29 PM   #23
jmartin1110
The Hell You Say!!
Flip Offs: 53
The gel coat on the covers wound up bubbling up. I am out of gel so I had to order more. Once it gets here I will try again. The mold for the chain guard came out perfectly though. I have to do some trimming before I can lay up any carbon. Hopefully get some time this weekend to get it layed up.
1981 Honda SS Build
KZ1000 Build Thread
Old Streetfighter Motorcycle Forum Post 01-16-2017, 09:55 PM   #24
jmartin1110
The Hell You Say!!
Flip Offs: 53
First try at the chain guard was a no go. Second attempt soon
1981 Honda SS Build
KZ1000 Build Thread
Old Streetfighter Motorcycle Forum Post 01-26-2017, 06:08 PM   #25
jmartin1110
The Hell You Say!!
Flip Offs: 53
Picture less update time
So I've been thinking about the chain guard and have decided to scrap the mold. Not because it isn't a good mold and won't work but because it's so narrow it is hard to get the resin spread evenly. Instead I will be doing an overlay. This way it will still be a carbon part but should be much easier to do. I figured I would wax the chain guard and then a few coats of pva just like if I was making a mold and the carbon should pop right off.
Also, I have worked out my front fender. I found a zrx400 front fender on eBay. It has a nice profile and is made for a 17 inch wheel. The only issue I might have is that the zrx400 runs a 110 width tire. Worse case is that I'll have to widen the fender a bit
1981 Honda SS Build
KZ1000 Build Thread
This user High Fived jmartin1110!
Old Streetfighter Motorcycle Forum Post 02-12-2017, 12:28 PM   #26
jmartin1110
The Hell You Say!!
Flip Offs: 53
Got some work done.
I started on the fender first. It had some small damage that I had to fix before it was ready to be molded. I reinforced the back of the fender where the cracks were before I tried to fill them.
Once that was sanded smooth I took 400 grit to the entire fender to get a consistent smooth finish.
Then a couple of coats of was and PVA
Then some gel coat
And there it sits till the gel coat cures. Once it does I will lay some glass
Also layed up some carbon
And moved my ignition to right under the tank
1981 Honda SS Build
KZ1000 Build Thread
Old Streetfighter Motorcycle Forum Post 02-13-2017, 12:13 PM   #27
jmartin1110
The Hell You Say!!
Flip Offs: 53
Got some glass layed yesterday
Also had to make sure it still ran. Don't mind the rust. There is no telling how long that exhaust sat before I bought it
http://s915.photobucket.com/user/jma...nzjpr.mp4.html
1981 Honda SS Build
KZ1000 Build Thread
Old Streetfighter Motorcycle Forum Post 02-14-2017, 11:04 AM   #28
jmartin1110
The Hell You Say!!
Flip Offs: 53
Picked up a couple of things over the weekend. Got the ELR decals ordered. Also ordered everything I was running out of for the paint. Finally bought what I needed to relocate the front tank mounts and some nice and shiny shock nuts.
1981 Honda SS Build
KZ1000 Build Thread
Old Streetfighter Motorcycle Forum Post 02-20-2017, 09:30 AM   #29
jmartin1110
The Hell You Say!!
Flip Offs: 53
I did get some work done this weekend. I finally got the front mounts for the tank sorted. They aren't perfect but they hold the tank solid. Also got the speed sensor mounted. I started working on the carbon fender but got as far as layering the PVA on the mold before it got a bit too chilly so I will try again this evening. Still along way to go and with recent developments I don't know if I am going to have the time to finish it
1981 Honda SS Build
KZ1000 Build Thread
Old Streetfighter Motorcycle Forum Post 02-21-2017, 09:26 AM   #30
jmartin1110
The Hell You Say!!
Flip Offs: 53
I hope this fender comes out good because that was a major pain in the ass to lay up
1981 Honda SS Build
KZ1000 Build Thread
Thank you for viewing Jmartin's '82 KZ1000 Build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Jmartin's '82 KZ1000 Build on Custom Fighters Streetfighter Motorcycle Forum
