Buell XB12Scg 2009 - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > Buell XB12Scg 2009
Old Streetfighter Motorcycle Forum Post 02-04-2015, 12:43 AM   #1
TPEHAK
Active Member
Fighter
Local Time: 07:18 PM
Flipped Off 1 Time in 1 Post
TPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud ofTPEHAK has much to be proud of
Fighter of the Month Fighter of the Month
Default Buell XB12Scg 2009
OK, here is my project. I bought this 2009 Buell XB12Scg Lighting last spring once I've got my driver license. This is my first motorcycle and my first vehicle at the same time.
This is the current condition of the motorcycle:
Stock Buell XB Lighting looks pretty aggressive, but I decided to give it even more streetfighter look.
List of changes:
-Side bar mirrors
-K&N air and oil filters
-Knight Design foot levers
-Scorpio alarm system
-240 mm rear wheel
-Chain conversion
-Motogadget M-Lock
-Motogadget Motoscope mini and Motosigh mini
-LSL Urban Headlight
-R&G turn signals
-Highway foot pegs
-Chopped tail with LED strip integrated turn signals.
So first of all I eliminated the stock mirrors and installed side bar mirrors. I use cheap side bar mirrors ( these ) and they work very well. The only issue is the bar inside diameter slightly bigger then the mirrors fixtures diameter, so I installed shims made of plastic bottle.
The next thing I've done is fender eliminator. I bought the same Buell XB fender eliminator kit like this one . There is a lot of different Buell fender eliminator kits with different styles you can find in the Internet.
Then I bought and installed the new brake pedal and shift pedal. The only reason I did it is the stock shift pedal rubber boot had a crack so I decided to install custom pedals without rubber pieces. These guys made the foot levers for me.
TPEHAK is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived TPEHAK!
Old Streetfighter Motorcycle Forum Post 02-04-2015, 12:44 AM   #2
TPEHAK
Active Member
Fighter
Default Re: Buell XB12Scg 2009
The next huge step was 240 mm rear wheel conversion. Buell XB has a swingarm which fits to 240 wheel like gloves. But the problem is that Buell XB uses wide belt instead chain, so you can't install 240 rear wheel and keep the belt at the same time without the swingarm weldup. So the only way to install 240 mm rear wheel on Buell XB without heavy swingarm modifications is make a chain conversion and install 520 chain. You can find all necessary information about 240 rear wheel conversion fot Buell using this link .
Here is a few pictures of the process:
The stock Buell rear wheel rim prepared for weldup
The widened rim after welding
The rim and the 240 mm tire
Comparing the new rim and the stock Buell 180 mm rear wheel
The rim after powdercoating
Old Streetfighter Motorcycle Forum Post 02-04-2015, 12:45 AM   #3
TPEHAK
Active Member
Fighter
I took all necessary measurements and created the SolidWorks CAD model with special parts (spacers, custom sprockets with offset, etc) and created drawings for all these custom parts
Then I sent the CAD files and the drawings to different places (motorcycle sprockets workshops and another machine shops) and ordered the parts.
Here is the home made 240 mm conversion kit
Here is a few pictures of installation process. After an unsuccessful trying to install the 240 tire by levers I clarified than the best way to install the tire without special tool is long plastic zip ties, no levers, no rim protectors, no brute force, no any tools, just freaking zip ties and 10 minutes!
Notching the swingarm for the chain and the sprocket screws routes.
I have two rear sprockets, the firs one is custom sprocket with offset made of aircraft duralumin, the second one is flat steel sprocket. I decided to use the flat sprocket with the spacer.
Old Streetfighter Motorcycle Forum Post 02-04-2015, 12:51 AM   #4
TPEHAK
Active Member
Fighter
Then I lowered my windscreen.
I bought a new white windscreen
Then taken some plastic plugs and super glue
Then glued these plugs in the old holes
Then made new holes to make the new windscreen lower and covered it by blue Plastidip with Metalizer and Glossifier and installed the windscreen
Old Streetfighter Motorcycle Forum Post 02-04-2015, 01:00 AM   #5
TPEHAK
Active Member
Fighter
But a few weeks ago I had seen a picture with Buell and installed LSL Urban headlight and it looks awesome. So I decided to eliminate the Buell headlight and instrument cluster and install the LSL headlight with motoscope mini and M-lock. I've already ordered the parts and I'm waiting delivery. Here is a picture of a Buell with LSL headlight. Not mine, just for example.
This user High Fived TPEHAK!
Old Streetfighter Motorcycle Forum Post 02-04-2015, 03:44 AM   #6
Casper
The friendly Ghost.
Local Time: 05:18 PM
Flip Offs: 189
Dude!
I wasn't expecting that chain conversion... this is why I like build threads.
I am subscribed to this one.
These people High Fived Casper!
Old Streetfighter Motorcycle Forum Post 02-04-2015, 12:59 PM   #7
F'dup
Hack in a barn
F'dup's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Flip Offs: 35
F'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on hereF'dup spends too much time on here
I'll give you $50 for the stock headlight, shipped to CT...
And
<---------- in before "whiplash"....
And
Really looking good, normally wide tires aren't my thing but that 240 looks good on there...
2017 build off sv650 build thread <---Click here
SV650 b.s.'n and post build off progress on the bike thread thread <---Click here
DR650 supermoto build <--click
2000 R6 build <--click
A bit of vaseline should lube your bush up real nice though. Just make sure that your shaft is a good fit.
F'dup is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-05-2015, 01:40 PM   #8
purpony
Senior Member
Fighterer
purpony's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
Local Time: 08:18 PM
purpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of lightpurpony is a glorious beacon of light
looking good!!
My Buell Build on CustomFighters.com - --> Click Here <--
My second and newer build - --> Click Here <--
-1999 Buell X1
-1996 Buell S1
-1989 Mustang Twin Turbo
-1998 EB V8 Explorer AWD
-2006 EB V6 Explorer 4x4
-2002 Focus SE
-2014 Flex Twin Turbo
purpony is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-06-2015, 10:13 AM   #9
kami
NoObie
Noobie
kami's Avatar on CustomFighters.com Streetfighter Motorcycle Forum
kami is making some friendskami is making some friendskami is making some friendskami is making some friends
TPEHAK - where did you do your wheel..? and if its not a secret - how much you payed..?
kami is offline   Reply With Quote on our streetfighter motorcycle forum
Old Streetfighter Motorcycle Forum Post 02-06-2015, 10:36 PM   #10
TPEHAK
Active Member
Fighter
I sent my wheel to the Kosman
Here are the sizes for Buell XB for 240/40ZR-18 tire
I payed about 600$ . If you are going to have a deal with Kosman I highly recommend you make a phone call before you decide to send them your wheel, it looks like Kosman does not exist anymore, now it is "SK Danger Wheels" and they have new address and new owner. I was waiting my wheel back about 3 months.
As I know Rimspec guys can weldup motorcycle wheels too. A guy from the BuellXB forum payed about 550$ for weldup his Buell rear wheel and about 200$ for powdercoating and polishing works last summer.
Here is an example of a widened rim RimSpec guys made
Thank you for viewing Buell XB12Scg 2009 in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - Buell XB12Scg 2009 on Custom Fighters Streetfighter Motorcycle Forum
