Moving the build here since, it's well... A real built
Here is the begining https://www.customfighters.com/forums/showthread.php?t=136436
And that's were I'm right now
Mods done so far and price of each one:
XT 500..............................................................565
SV650 first gen forks (used).................................130
SV650 first gen Front wheel axle (used)...................30
Front wheel spacer..................................................6
Cafe racer seat (new)............................................35
Fittings for the subframe........................................56
Tubes and metal sheet for the subframe...................25
Subframe welder cost 1..........................................90
Subframe welder cost 2..........................................10
Chopping the stok subframe.....................................0
Headlight (new).....................................................47
Clip-ons (new).......................................................21
Honda GC125 fuell tank (new)................................105
Fuel tank rubber mounts (new)..................................6
Bar end turn lights indicators (new)............................9
Mufler (new)..........................................................51
Yamaha YBR125 speedo drive (used).........................24
Yamaha tank decals (new).......................................12
Harley fork boots (new)............................................5
Bar end mirrors (new).............................................15
Front brake rotor (new)...........................................80
Front brake pads......................................................0
Botom oil line (used)...............................................12
Top clamp (used)....................................................40
Chain adjusters (used).............................................10
GSXR 1k K3 clutch line (used)...................................12
Paint......................................................................45
Front wheel hub with spokes (used)..........................120
Gaskets, o-rings etc for the engine (new)..................195
Wheels spokes and bearings (new)...........................230
Rear foot pegs (used)...............................................15
Custom oil line.........................................................22
Central lock switch (new)..........................................40
SV650 left caliper (used)...........................................45
TT 600 headers (used)..............................................70
Rear caliper repair kit (new)..................................... 25
Fenders (new).........................................................40
Velocity staks (new).................................................45
Truck side marker light (new)....................................10
Flywheel cover (used)...............................................45
Timing chain (new)...................................................60
Anchor points welding...............................................20
Exhaust valves (new)................................................40
CDI box and rear fenders mount welding.....................20
Seat cover...............................................................50
Ergal bolts...............................................................10
Aluminium cylinders, indicator inserts, filter adapter......60
Midpipe...................................................................65
4 screw valve adjusters and carb tuning.....................100
Koso speedo (new)..................................................125
Tail light (new).........................................................35
Total 2928
Sold stock parts:
Fuel tank..............................................................80
Tail plastics ..........................................................45
Seat....................................................................30
Forks...................................................................50
Front caliper.........................................................30
Front brake rotor...................................................30
Total 2663
And a screenshot with date from my phone
Total 2928
Sold stock parts:
Total 2663
