AusEr6Guys build - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > AusEr6Guys build
Old Streetfighter Motorcycle Forum Post 01-12-2019, 03:41 PM   #1
Auser6guy
Active Member
Fighter
Local Time: 07:59 AM
Auser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to allAuser6guy is a name known to all
Default AusEr6Guys build
Hi people, Ive been reading with interest for a while and finally bit the bullet and started modding by bike.
So far ive taken what is a stock 2010 ER6, swapped in some forks and brakes from ninja1000,Top triple from a 03 z1000, a swing arm from a 2015 versys, added a drag bar and shorter levers. A tail light with integrated indicators, and LED headlight.
Still to go is a 6inch rear wheel, a front cowl and a smaller gauge as well as one day take the plunge and shorten the tail.
ID:	103598   Click image for larger version
ID:	103600   Click image for larger version
Auser6guy is offline   Reply With Quote on our streetfighter motorcycle forum
These people High Fived Auser6guy!
Old Streetfighter Motorcycle Forum Post 01-12-2019, 03:42 PM   #2
Auser6guy
Active Member
Fighter
Default Re: AusEr6Guys build
Please ignore the gauge. It’s fitted just enough so i can ride
Old Streetfighter Motorcycle Forum Post 01-13-2019, 08:24 AM   #3
ROBBO
MAJOR FOOKIN' CATASTROPHY
Flip Offs: 643
Looks good mate . Good work so far .
ROBBO' 2009
Old Streetfighter Motorcycle Forum Post 01-13-2019, 10:49 AM   #4
Junkie
re-tarded
Local Time: 04:59 AM
Flip Offs: 3
will a 6" wheel/190 tire fit in the swingarm? That's a lotta tire for a bike that size.
Old Streetfighter Motorcycle Forum Post 01-14-2019, 10:52 PM   #5
Auser6guy
Active Member
Fighter
Apparently yes, according to the questionable Indonesian gentleman I met over the internet. He said its a straight swap, and you can fit a 180, 190 or a 200. Time will tell as im waiting on the shipping at the moment.
The gauge I bought reads fuel full at 5-7 ohms and empty at 98 ohms
The standard fuel sender is full at 8 ohms and empty at 210 ohms.
By my reckoning i need a 200 ohm resistor in parallel with the sender to get it accurate can someone confirm im on the right track?
The new gauge also requires a 34hz signal to read correctly at 60kmh(35mph in the old money) by my calculations the front sprocket with a single pulse per rev will yield 24hz. Anyone done any speedo healing via a cheap and nasty,easy to install method ?
Old Streetfighter Motorcycle Forum Post 01-15-2019, 01:53 PM   #6
Junkie
re-tarded
Flip Offs: 3
https://www.youtube.com/watch?v=X3oYH4JuGOw
that one?
and yes, with a 6" you can reasonably run any of those tires, although a 180 will run out of lean angle a little earlier than the 190 or 200
Old Streetfighter Motorcycle Forum Post 01-20-2019, 05:11 AM   #7
Auser6guy
Active Member
Fighter
All things look like a headlight cowl to a man with a Dremel....
Old Streetfighter Motorcycle Forum Post 01-20-2019, 05:14 AM   #8
Auser6guy
Active Member
Fighter
A ninja 300 front screen. I might make another one bit wider to cover more of the forks.
Old Streetfighter Motorcycle Forum Post 06-04-2019, 06:33 AM   #9
Auser6guy
Active Member
Fighter
Update. 6 inch rear fitted with 180 rear tyre. A 190 would probably fit but the 200 will not.
Bought 330mm brembo front discs and 250mm rear disc and caliber from the same 2015 Versys that I got the aluminium swing arm from. Got a z1000 master cylinder to go on shortly.
The R1 shock im adapting is coming together. The spring has been swapped to 1100lbs(21kg/mm)
Ive got another low rise handlebar to try.
Ill post a few pics to tell the story eh ?
Old Streetfighter Motorcycle Forum Post 06-04-2019, 06:41 AM   #10
Auser6guy
Active Member
Fighter
Default
Details of the r1 shock here https://www.customfighters.com/forum...d.php?t=137106
Thank you for viewing AusEr6Guys build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - AusEr6Guys build on Custom Fighters Streetfighter Motorcycle Forum
