FZR 600 RR Build - Custom Fighters - Custom Streetfighter Motorcycle Forum
CustomFighters.com Streetfighter Motorcycle Forum > FZR 600 RR Build
Old Streetfighter Motorcycle Forum Post 06-20-2019, 05:32 PM
RS_Raz
Chief Bodger
Senior Fighterer
Local Time: 05:31 AM
Flip Offs: 9
Default FZR 600 RR Build
I have decided to build a Fightered out Yamaha 3TJ (Japanese Market FZR400RR) with a Thundercat engine coz the frame is sexy & light and the engine bolts straight in... almost.
FZR 3TJ:
This is probably a bad idea because 3TJ stuff is scarce but I don't care. I want it.
Got the frame:
It's been in storage for over 22 years! It's also unregistered so once this is built I'll have the fun of registering it for the first time. Yay.
Got the engine:
The guy I bought it off said he got it off a guy who said it came from a bike which only had 3200 miles on the clock. I think the clocks were broken or the guy was mentally insane. Or both maybe.
RS_Raz is offline
These people High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 06-21-2019, 09:53 AM
Junkie
re-tarded
Local Time: 09:31 PM
Flip Offs: 3
Junkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to allJunkie is a name known to all
Default Re: FZR 600 RR Build
Nice. If you really want to go over the top build a 660
I really wanted an FZR hybrid for a while, I look forward to this. What're your plans for suspension/wheels?
Bikes: naked SV1000 with all the possible bling, WR450SM street legal, 450XCF SM trackbike
Junkie is offline
Old Streetfighter Motorcycle Forum Post 06-21-2019, 05:30 PM
RS_Raz
Chief Bodger
Senior Fighterer
Flip Offs: 9
It has crossed my mind. Is that FZR crank, YZF top end? or the other way round?
I need to build it looking stock-ish initially to help with registration. I'm hoping the fact it has no plastics won't get in the way of that.
Front end will be R6 5EB forks and wheel, FZR1000 clamps, 7/8ths risers, Silver spot calipers.
Rear end will be FZR1000 EXUP hopefully with a blue spot caliper somehow.
It needs to have a pillion seat and I really want to keep the 3TJ tank and tail. Although I don't like the 3TJ tail light much.
Engine needs work. Valves & seats are rusty. Aluminium's corroded:
Bores look very good. Pistons, combustion chambers just need a clean up I think:
WTF:
Water pump housing is nearly corroded right through
I think this guy was storing this engine in the sea:
Man....
RS_Raz is offline
This user High Fived RS_Raz!
Old Streetfighter Motorcycle Forum Post 06-21-2019, 07:20 PM
yantosh
Flip Offs: 13
prob need MSVA ?
yantosh is offline
Old Streetfighter Motorcycle Forum Post 06-21-2019, 11:05 PM
Junkie
re-tarded
Flip Offs: 3
660 is YZF jugs/pistons with FZR crank. Using FZR rods means deck height is correct without a spacer IIRC, but you need to enlarge the small end a bit. You can use either set of cases IIRC. YZF rods can be made to work but then you need to run a spacer under the jug.
and that's pretty much the exact front end I'd run, it's been a long time since I looked at swingarms so I'm not sure there.
Junkie is offline
Old Streetfighter Motorcycle Forum Post 06-22-2019, 03:10 AM
a_morti
Local Time: 06:31 AM
Flip Offs: 24
Originally Posted by yantosh View Post
prob need MSVA ?
If anyone here would know, it's you. Seems like a ballache if so.
Idk what was paid for the frame but I wonder if it wouldn't make more sense to use one with registration?
https://rover.ebay.com/rover/0/0/0?m...2F233261450820
a_morti is offline
Old Streetfighter Motorcycle Forum Post 06-22-2019, 03:52 AM
RS_Raz
Chief Bodger
Senior Fighterer
Flip Offs: 9
prob need MSVA ?
Possibly. I will try to avoid that though.
It probably would make more sense, yes. But I already had the frame when that one was listed. I considered buying that one and selling mine but that one looks like it was parked at the beach for a few years whereas mine looks like it's been in dry storage most of its life.
I'll keep an eye out for the bottom end then. I read that the 2nd gear in these is made of chocolate so I'm sort of expecting to have it all in bits at some point anyways.
Seats clean up ok. Valves might too:
Got clamps. Stem is too long. According to the internet there isn't another stem that can be used in place of the 3TJ... which I don't have. Needs to be 26cm total, this is 28.
Top clamp has holes for risers but has perished bushes pressed in. So I pressed them out:
And scratched it up a bit:
Got a shifter but I think it must've come from that frame that's on ebay. Or maybe it was being stored in the sea with the engine:
I'm gonna nip out to the shed and play while the Mrs isn't looking....
RS_Raz is offline
Old Streetfighter Motorcycle Forum Post 06-22-2019, 04:16 AM
a_morti
Flip Offs: 24
Assuming it fits in the other dimensions (including would it reach the clamping areas of the forks), can the stem be cut, slugged, welded? I have no idea if that's a stupid question.
a_morti is offline
Old Streetfighter Motorcycle Forum Post 06-22-2019, 04:22 AM
a_morti
Flip Offs: 24
You on here yet?
http://www.400greybike.com/forum/viewforum.php?f=79
There's a corresponding FB group.
a_morti is offline
Old Streetfighter Motorcycle Forum Post 06-22-2019, 07:02 AM
RS_Raz
Chief Bodger
Senior Fighterer
Flip Offs: 9
You on here yet?
I'm not yet but there's great info on that site for me. Deffo could be handy if I'm stuck for bits. I'm not on FB tbh.
Yes. I've just sorted it:
Cut, chamfered, tapped a round bar inside, left a couple mm gap between the 2 halves to get decent penetration into the inner bar.
Clamped it up and cranked the mig right up.
It has warped a little bit but it runs smooth in the frame.
What you reckon?
RS_Raz is offline
Thank you for viewing FZR 600 RR Build in the Member Project Bikes section of our streetfighter motorcycle forum. I hope you found it useful!
Member Project Bikes - FZR 600 RR Build on Custom Fighters Streetfighter Motorcycle Forum
